I’ve decided to go deeper than I had previously with containerized computing but I realized that I had, what seems to be, an odd question. If I were to containerize an application with a necessary GUI, (Kodi and a Plex client, are my primary examples) would I be able to access their GUI’s from the local machine? This is the only thing right now keeping me from jumping into containers fully since the Raspberry Pi that I want to repurpose is currently a small media center triple-booting Raspbian, Libreelec, and Lakka.
Thanks for any help you can give me on this issue.
I don’t think I made myself clear. I was talking about trying to access the containers from the same machine they’re hosted on. Is there a way to do that built in to BalenaOS or would I be building it myself?
If what you mean is to communicate with various containers locally, you can set network_mode: 'host' in the docker-compose.yml file that defines your application’s various services. You can then communicate freely between containers via bound ports on localhost. This feature is documented here.
I hope this information helps, but please let us know if we are still missing something!
