Hi seems like the ARM build hangs while building LibreSSL:
[Build] checking size of time_t... 4
[Build] ** Warning, this system is unable to represent times past 2038
[Build] ** It will behave incorrectly when handling valid RFC5280 dates
[Info] Still working...
Works fine on x64 builds though.
The build command in Dockerfile.template, looks like this, nothing special:
FROM resin/raspberrypi3-alpine-buildpack-deps:latest AS builder
RUN wget https://github.com/libressl-portable/portable/archive/v2.6.4.tar.gz\
&& tar -xvf v2.6.4.tar.gz\
&& cd portable-2.6.4\
&& ./autogen.sh\
&& ./configure --prefix="/usr/local/ssl"\
&& make check\
&& make install
@ab1 I’ve just taken a look at this issue, and the dockerfile you provided. The tweaked file below builds, evenutally. The autogen.sh takes a really long time, but then the next push uses the cached layer so don’t worry too much.
RUN apk --update add libtool autoconf automake
&& ./autogen.sh\
&& make check\
&& make install
CMD echo "hello world!"
