Latest NUC 11TNH
Latest generation of NUC Gen 11 is not identifying either the network adapter or WIFI for Balena 2.68.1+rev1.
Using Generic x86-64 Balena 2.58.6+rev1 properly detects the network adapter, still no WIFI.
lspci:
00:00.0 Host bridge: Intel Corporation Device 9a04 (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Device 9a78 (rev 01)
00:06.0 PCI bridge: Intel Corporation Device 9a09 (rev 01)
00:07.0 PCI bridge: Intel Corporation Device 9a25 (rev 01)
00:07.2 PCI bridge: Intel Corporation Device 9a27 (rev 01)
00:08.0 System peripheral: Intel Corporation Device 9a11 (rev 01)
00:0d.0 USB controller: Intel Corporation Device 9a13 (rev 01)
00:0d.2 USB controller: Intel Corporation Device 9a1b (rev 01)
00:0d.3 USB controller: Intel Corporation Device 9a1d (rev 01)
00:14.0 USB controller: Intel Corporation Device a0ed (rev 20)
00:14.2 RAM memory: Intel Corporation Device a0ef (rev 20)
00:14.3 Network controller: Intel Corporation Device a0f0 (rev 20)
00:15.0 Serial bus controller [0c80]: Intel Corporation Device a0e8 (rev 20)
00:15.1 Serial bus controller [0c80]: Intel Corporation Device a0e9 (rev 20)
00:16.0 Communication controller: Intel Corporation Device a0e0 (rev 20)
00:17.0 SATA controller: Intel Corporation Device a0d3 (rev 20)
00:1d.0 PCI bridge: Intel Corporation Device a0b1 (rev 20)
00:1f.0 ISA bridge: Intel Corporation Device a082 (rev 20)
00:1f.3 Audio device: Intel Corporation Device a0c8 (rev 20)
00:1f.4 SMBus: Intel Corporation Device a0a3 (rev 20)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device a0a4 (rev 20)
58:00.0 Ethernet controller: Intel Corporation Device 15f2 (rev 03)
lsusb:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 8087:0026 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
CPU Info:
vendor_id : GenuineIntel
cpu family : 6
model : 140
model name : 11th Gen Intel(R) Coreā„¢ i3-1115G4 @ 3.00GHz
stepping : 1
microcode : 0x6c
cpu MHz : 3915.844
cache size : 6144 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 27
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l2 invpcid_single cdp_l2 ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid movdiri movdir64b md_clear flush_l1d arch_capabilities
bugs : spectre_v1 spectre_v2 spec_store_bypass swapgs
bogomips : 5990.40
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
ETA on NUC11 support or work around for WiFi?
Hi, thanks for reporting this. Support for the 11th Gen NUC is already being considered and progress can be tracked in Add support for Intel NUC 11th Gen Ā· Issue #344 Ā· balena-os/balena-intel Ā· GitHub. I have linked that issue to this ticket so we will update here once it is resolved.
Hi, can you provide the full dmesg please?
[ 0.000000] Linux version 5.2.10-yocto-standard (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 SMP Fri Oct 23 09:05:55 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/bzImage root=UUID=ba1eadef-543d-45a9-9cf7-30193f640e55 rootwait intel_idle.max_cstate=1
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ā€˜x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ā€˜SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ā€˜AVX registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: ā€˜AVX-512 opmask’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: ā€˜AVX-512 Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: ā€˜AVX-512 ZMM_Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: ā€˜Protection Keys User registers’
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using ā€˜compacted’ format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000038168fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000038169000-0x0000000040b79fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040b7a000-0x0000000040c45fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000040c46000-0x0000000040ce7fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000040ce8000-0x00000000416d1fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000416d2000-0x00000000417fefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000417ff000-0x00000000417fffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000041800000-0x0000000047ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000048f00000-0x000000004f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001b07fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0x40c8a000 ACPI 2.0=0x40c8a014 SMBIOS=0x414df000 SMBIOS 3.0=0x414de000 MEMATTR=0x2faab018 ESRT=0x3405f098
[ 0.000000] SMBIOS 3.3.0 present.
[ 0.000000] DMI: Intel(R) Client Systems NUC11TNHi3/NUC11TNBi3, BIOS TNTGL357.0043.2020.1223.1022 12/23/2020
[ 0.000000] tsc: Detected 3000.000 MHz processor
[ 0.000664] tsc: Detected 2995.200 MHz TSC
[ 0.000664] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000665] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000669] last_pfn = 0x1b0800 max_arch_pfn = 0x400000000
[ 0.000673] MTRR default type: uncachable
[ 0.000673] MTRR fixed ranges enabled:
[ 0.000674] 00000-9FFFF write-back
[ 0.000674] A0000-BFFFF uncachable
[ 0.000675] C0000-FFFFF write-protect
[ 0.000675] MTRR variable ranges enabled:
[ 0.000676] 0 base 004A000000 mask 7FFF000000 write-back
[ 0.000676] 1 base 0048000000 mask 7FFE000000 write-back
[ 0.000677] 2 base 0040000000 mask 7FF8000000 write-back
[ 0.000677] 3 base 0000000000 mask 7FC0000000 write-back
[ 0.000677] 4 base 0100000000 mask 7F00000000 write-back
[ 0.000678] 5 disabled
[ 0.000678] 6 disabled
[ 0.000678] 7 disabled
[ 0.000678] 8 disabled
[ 0.000679] 9 disabled
[ 0.001681] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002291] e820: update [mem 0x4b000000-0xffffffff] usable ==> reserved
[ 0.002295] last_pfn = 0x41800 max_arch_pfn = 0x400000000
[ 0.017793] esrt: Reserving ESRT space from 0x000000003405f098 to 0x000000003405f170.
[ 0.017804] check: Scanning 1 areas for low memory corruption
[ 0.017807] Using GB pages for direct mapping
[ 0.017809] BRK [0x161601000, 0x161601fff] PGTABLE
[ 0.017810] BRK [0x161602000, 0x161602fff] PGTABLE
[ 0.017811] BRK [0x161603000, 0x161603fff] PGTABLE
[ 0.017824] BRK [0x161604000, 0x161604fff] PGTABLE
[ 0.017825] BRK [0x161605000, 0x161605fff] PGTABLE
[ 0.017872] BRK [0x161606000, 0x161606fff] PGTABLE
[ 0.017884] BRK [0x161607000, 0x161607fff] PGTABLE
[ 0.017884] BRK [0x161608000, 0x161608fff] PGTABLE
[ 0.017909] Secure boot could not be determined
[ 0.017921] ACPI: Early table checksum verification disabled
[ 0.017924] ACPI: RSDP 0x0000000040C8A014 000024 (v02 INTEL )
[ 0.017927] ACPI: XSDT 0x0000000040C89728 0000F4 (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017930] ACPI: FACP 0x0000000040C3F000 000114 (v06 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017934] ACPI: DSDT 0x0000000040BE4000 05A4E8 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017936] ACPI: FACS 0x0000000040CE4000 000040
[ 0.017938] ACPI: MCFG 0x0000000040C43000 00003C (v01 INTEL NUC11TNB 0000002B MSFT 00000097)
[ 0.017939] ACPI: SSDT 0x0000000040C40000 00255D (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017942] ACPI: FIDT 0x0000000040BE3000 00009C (v01 INTEL NUC11TNB 0000002B AMI 00010013)
[ 0.017944] ACPI: SSDT 0x0000000040BE0000 002C9F (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017945] ACPI: SSDT 0x0000000040BDC000 003350 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017947] ACPI: SSDT 0x0000000040BD0000 00B192 (v02 INTEL NUC11TNB 00001000 INTL 20191018)
[ 0.017949] ACPI: HPET 0x0000000040C45000 000038 (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017951] ACPI: APIC 0x0000000040C44000 00012C (v04 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017953] ACPI: SSDT 0x0000000040BC9000 006243 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017954] ACPI: SSDT 0x0000000040BC8000 000D01 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017956] ACPI: NHLT 0x0000000040BC7000 00002D (v00 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017958] ACPI: UEFI 0x0000000040C77000 000048 (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017960] ACPI: LPIT 0x0000000040BC6000 0000CC (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017961] ACPI: SSDT 0x0000000040BC2000 002720 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017963] ACPI: SSDT 0x0000000040BC1000 00012A (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017965] ACPI: DBGP 0x0000000040BC0000 000034 (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017967] ACPI: DBG2 0x0000000040BBF000 000054 (v00 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017969] ACPI: DMAR 0x0000000040BBE000 0000B8 (v02 INTEL NUC11TNB 0000002B 01000013)
[ 0.017970] ACPI: SSDT 0x0000000040BBD000 000902 (v02 INTEL NUC11TNB 00000000 INTL 20191018)
[ 0.017972] ACPI: SSDT 0x0000000040BBC000 000144 (v02 INTEL NUC11TNB 0000002B INTL 20191018)
[ 0.017974] ACPI: BGRT 0x0000000040BBB000 000038 (v01 INTEL NUC11TNB 0000002B AMI 00010013)
[ 0.017976] ACPI: TPM2 0x0000000040BBA000 00004C (v04 INTEL NUC11TNB 0000002B AMI 00000000)
[ 0.017978] ACPI: PTDT 0x0000000040BB9000 000D44 (v00 INTEL NUC11TNB 0000002B MSFT 0100000D)
[ 0.017979] ACPI: WSMT 0x0000000040BC5000 000028 (v01 INTEL NUC11TNB 0000002B AMI 00010013)
[ 0.017981] ACPI: FPDT 0x0000000040BB8000 000044 (v01 INTEL NUC11TNB 0000002B AMI 01000013)
[ 0.017987] ACPI: Local APIC address 0xfee00000
[ 0.018358] No NUMA configuration found
[ 0.018359] Faking a node at [mem 0x0000000000000000-0x00000001b07fffff]
[ 0.018364] NODE_DATA(0) allocated [mem 0x1b07d5000-0x1b07fffff]
[ 0.018466] Zone ranges:
[ 0.018467] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.018468] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.018468] Normal [mem 0x0000000100000000-0x00000001b07fffff]
[ 0.018469] Device empty
[ 0.018469] Movable zone start for each node
[ 0.018472] Early memory node ranges
[ 0.018472] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.018473] node 0: [mem 0x0000000000100000-0x0000000038168fff]
[ 0.018473] node 0: [mem 0x00000000417ff000-0x00000000417fffff]
[ 0.018474] node 0: [mem 0x0000000100000000-0x00000001b07fffff]
[ 0.018845] Zeroed struct page in unavailable ranges: 65272 pages
[ 0.018846] Initmem setup node 0 [mem 0x0000000000001000-0x00000001b07fffff]
[ 0.018847] On node 0 totalpages: 952584
[ 0.018847] DMA zone: 64 pages used for memmap
[ 0.018848] DMA zone: 24 pages reserved
[ 0.018848] DMA zone: 3998 pages, LIFO batch:0
[ 0.018874] DMA32 zone: 3526 pages used for memmap
[ 0.018875] DMA32 zone: 225642 pages, LIFO batch:63
[ 0.022357] Normal zone: 11296 pages used for memmap
[ 0.022358] Normal zone: 722944 pages, LIFO batch:63
[ 0.028746] ACPI: PM-Timer IO Port: 0x1808
[ 0.028747] ACPI: Local APIC address 0xfee00000
[ 0.028752] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.028753] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.028753] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.028754] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.028754] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.028755] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.028755] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.028756] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.028756] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.028756] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.028757] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.028757] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.028758] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.028758] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.028759] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.028759] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.028843] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.028844] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.028845] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.028846] ACPI: IRQ0 used by override.
[ 0.028847] ACPI: IRQ9 used by override.
[ 0.028848] Using ACPI (MADT) for SMP configuration information
[ 0.028849] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.028854] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.028865] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.028866] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.028867] PM: Registered nosave memory: [mem 0x38169000-0x40b79fff]
[ 0.028868] PM: Registered nosave memory: [mem 0x40b7a000-0x40c45fff]
[ 0.028868] PM: Registered nosave memory: [mem 0x40c46000-0x40ce7fff]
[ 0.028869] PM: Registered nosave memory: [mem 0x40ce8000-0x416d1fff]
[ 0.028869] PM: Registered nosave memory: [mem 0x416d2000-0x417fefff]
[ 0.028870] PM: Registered nosave memory: [mem 0x41800000-0x47ffffff]
[ 0.028870] PM: Registered nosave memory: [mem 0x48000000-0x48efffff]
[ 0.028871] PM: Registered nosave memory: [mem 0x48f00000-0x4f7fffff]
[ 0.028871] PM: Registered nosave memory: [mem 0x4f800000-0xbfffffff]
[ 0.028872] PM: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ 0.028872] PM: Registered nosave memory: [mem 0xd0000000-0xfdffffff]
[ 0.028872] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.028873] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.028873] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.028874] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.028874] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.028874] PM: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[ 0.028875] PM: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.028875] PM: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[ 0.028876] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.028876] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.028877] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.028878] [mem 0x4f800000-0xbfffffff] available for PCI devices
[ 0.028879] Booting paravirtualized kernel on bare hardware
[ 0.028882] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.028886] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.029059] percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u524288
[ 0.029063] pcpu-alloc: s188416 r8192 d28672 u524288 alloc=1*2097152
[ 0.029064] pcpu-alloc: [0] 0 1 2 3
[ 0.029077] Built 1 zonelists, mobility grouping on. Total pages: 937674
[ 0.029078] Policy zone: Normal
[ 0.029079] Kernel command line: BOOT_IMAGE=/boot/bzImage root=UUID=ba1eadef-543d-45a9-9cf7-30193f640e55 rootwait intel_idle.max_cstate=1
[ 0.032125] Calgary: detecting Calgary via BIOS EBDA area
[ 0.032126] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.039793] Memory: 3538200K/3810336K available (16387K kernel code, 2869K rwdata, 5844K rodata, 13912K init, 5596K bss, 272136K reserved, 0K cma-reserved)
[ 0.039920] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.039930] ftrace: allocating 52636 entries in 206 pages
[ 0.052580] rcu: Hierarchical RCU implementation.
[ 0.052582] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.052583] Tasks RCU enabled.
[ 0.052584] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.052584] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.054441] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[ 0.055093] random: crng done (trusting CPU’s manufacturer)
[ 0.055110] Console: colour dummy device 80x25
[ 0.055218] printk: console [tty0] enabled
[ 0.055231] ACPI: Core revision 20190509
[ 0.055764] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[ 0.055872] hpet clockevent registered
[ 0.055987] APIC: Switch to symmetric I/O mode setup
[ 0.055990] DMAR: Host address width 39
[ 0.055991] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.055995] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 69e2ff0505e
[ 0.055996] DMAR: DRHD base: 0x000000fed85000 flags: 0x0
[ 0.056000] DMAR: dmar1: reg_base_addr fed85000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.056001] DMAR: DRHD base: 0x000000fed86000 flags: 0x0
[ 0.056005] DMAR: dmar2: reg_base_addr fed86000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.056006] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.056011] DMAR: dmar3: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.056013] DMAR: RMRR base: 0x0000004b000000 end: 0x0000004f7fffff
[ 0.056015] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 3
[ 0.056016] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.056017] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.060714] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.060716] x2apic enabled
[ 0.060777] Switched APIC routing to cluster x2apic.
[ 0.073243] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.077906] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b2c8ec87c7, max_idle_ns: 440795278598 ns
[ 0.077911] Calibrating delay loop (skipped), value calculated using timer frequency… 5990.40 BogoMIPS (lpj=2995200)
[ 0.077914] pid_max: default: 32768 minimum: 301
[ 0.079982] LSM: Security Framework initializing
[ 0.079986] Yama: becoming mindful.
[ 0.080494] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.080765] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.080911] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.080920] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.081096] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.081126] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.081188] process: using mwait in idle threads
[ 0.081190] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.081191] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.081192] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.081194] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.081195] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.081197] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.081198] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.081368] Freeing SMP alternatives memory: 52K
[ 0.082997] TSC deadline timer enabled
[ 0.083012] smpboot: CPU0: 11th Gen Intel(R) Coreā„¢ i3-1115G4 @ 3.00GHz (family: 0x6, model: 0x8c, stepping: 0x1)
[ 0.083086] Performance Events: PEBS fmt4±baseline, generic architected perfmon, full-width counters, Intel PMU driver.
[ 0.083090] … version: 5
[ 0.083091] … bit width: 48
[ 0.083092] … generic registers: 8
[ 0.083092] … value mask: 0000ffffffffffff
[ 0.083093] … max period: 00007fffffffffff
[ 0.083094] … fixed-purpose events: 4
[ 0.083094] … event mask: 0000000f000000ff
[ 0.083112] rcu: Hierarchical SRCU implementation.
[ 0.083789] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.083826] smp: Bringing up secondary CPUs …
[ 0.083877] x86: Booting SMP configuration:
[ 0.083878] … node #0, CPUs: #1 #2 #3
[ 0.085419] smp: Brought up 1 node, 4 CPUs
[ 0.085419] smpboot: Max logical packages: 1
[ 0.085419] smpboot: Total of 4 processors activated (23961.60 BogoMIPS)
[ 0.086074] devtmpfs: initialized
[ 0.086074] x86/mm: Memory block size: 128MB
[ 0.086158] PM: Registering ACPI NVS region [mem 0x40c46000-0x40ce7fff] (663552 bytes)
[ 0.086158] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.086158] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.086158] xor: automatically using best checksumming function avx
[ 0.086158] pinctrl core: initialized pinctrl subsystem
[ 0.086912] PM: RTC time: 20:34:34, date: 2021-05-12
[ 0.087009] NET: Registered protocol family 16
[ 0.087062] audit: initializing netlink subsys (disabled)
[ 0.087065] audit: type=2000 audit(1620851674.031:1): state=initialized audit_enabled=0 res=1
[ 0.087065] EISA bus registered
[ 0.087065] cpuidle: using governor ladder
[ 0.087065] cpuidle: using governor menu
[ 0.087065] ACPI: bus type PCI registered
[ 0.087065] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.087065] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.087065] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[ 0.087065] PCI: Using configuration type 1 for base access
[ 0.087135] ENERGY_PERF_BIAS: Set to ā€˜normal’, was ā€˜performance’
[ 0.088453] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.088453] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.105910] raid6: avx512x4 gen() 62867 MB/s
[ 0.122910] raid6: avx512x4 xor() 32419 MB/s
[ 0.139911] raid6: avx512x2 gen() 53738 MB/s
[ 0.156910] raid6: avx512x2 xor() 31287 MB/s
[ 0.173911] raid6: avx512x1 gen() 45820 MB/s
[ 0.190911] raid6: avx512x1 xor() 26623 MB/s
[ 0.207911] raid6: avx2x4 gen() 46015 MB/s
[ 0.224911] raid6: avx2x4 xor() 26847 MB/s
[ 0.241911] raid6: avx2x2 gen() 46457 MB/s
[ 0.258911] raid6: avx2x2 xor() 30949 MB/s
[ 0.275910] raid6: avx2x1 gen() 36960 MB/s
[ 0.292911] raid6: avx2x1 xor() 22066 MB/s
[ 0.309910] raid6: sse2x4 gen() 14617 MB/s
[ 0.326912] raid6: sse2x4 xor() 8658 MB/s
[ 0.343912] raid6: sse2x2 gen() 13957 MB/s
[ 0.360912] raid6: sse2x2 xor() 8640 MB/s
[ 0.377914] raid6: sse2x1 gen() 13480 MB/s
[ 0.394912] raid6: sse2x1 xor() 6980 MB/s
[ 0.394913] raid6: using algorithm avx512x4 gen() 62867 MB/s
[ 0.394914] raid6: … xor() 32419 MB/s, rmw enabled
[ 0.394915] raid6: using avx512x2 recovery algorithm
[ 0.394958] ACPI: Added _OSI(Module Device)
[ 0.394959] ACPI: Added _OSI(Processor Device)
[ 0.394960] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.394960] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.394962] ACPI: Added OSI(Linux-Dell-Video)
[ 0.394962] ACPI: Added OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.394963] ACPI: Added OSI(Linux-HPI-Hybrid-Graphics)
[ 0.454543] ACPI: 11 ACPI AML tables successfully acquired and loaded
[ 0.465566] ACPI: Dynamic OEM Table Load:
[ 0.465573] ACPI: SSDT 0xFFFF8A716A9EC000 0001CB (v02 PmRef Cpu0Psd 00003000 INTL 20191018)
[ 0.465772] ACPI: _SB
.PR00: OSC native thermal LVT Acked
[ 0.467776] ACPI: Dynamic OEM Table Load:
[ 0.467780] ACPI: SSDT 0xFFFF8A716A9AB400 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20191018)
[ 0.468134] ACPI: Dynamic OEM Table Load:
[ 0.468138] ACPI: SSDT 0xFFFF8A716A50B000 000689 (v02 PmRef Cpu0Ist 00003000 INTL 20191018)
[ 0.468583] ACPI: Dynamic OEM Table Load:
[ 0.468586] ACPI: SSDT 0xFFFF8A716A9A9800 000266 (v02 PmRef Cpu0Hwp 00003000 INTL 20191018)
[ 0.469093] ACPI: Dynamic OEM Table Load:
[ 0.469098] ACPI: SSDT 0xFFFF8A716BD7D000 0008E7 (v02 PmRef ApIst 00003000 INTL 20191018)
[ 0.469560] ACPI: Dynamic OEM Table Load:
[ 0.469564] ACPI: SSDT 0xFFFF8A716A50A800 00048A (v02 PmRef ApHwp 00003000 INTL 20191018)
[ 0.469950] ACPI: Dynamic OEM Table Load:
[ 0.469953] ACPI: SSDT 0xFFFF8A716A50E800 0004D4 (v02 PmRef ApPsd 00003000 INTL 20191018)
[ 0.470334] ACPI: Dynamic OEM Table Load:
[ 0.470337] ACPI: SSDT 0xFFFF8A716A509000 00048A (v02 PmRef ApCst 00003000 INTL 20191018)
[ 0.473021] ACPI: EC: EC started
[ 0.473022] ACPI: EC: interrupt blocked
[ 0.473037] ACPI: _SB
.PC00.LPCB.H_EC: Used as first EC
[ 0.473038] ACPI: _SB
.PC00.LPCB.H_EC: GPE=0x6e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.473040] ACPI: _SB
.PC00.LPCB.H_EC: Boot DSDT EC used to handle transactions
[ 0.473041] ACPI: Interpreter enabled
[ 0.473077] ACPI: (supports S0 S3 S4 S5)
[ 0.473078] ACPI: Using IOAPIC for interrupt routing
[ 0.473111] PCI: Using host bridge windows from ACPI; if necessary, use ā€œpci=nocrsā€ and report a bug
[ 0.474811] ACPI: Enabled 7 GPEs in block 00 to 7F
[ 0.504048] ACPI: Power Resource [PXP] (on)
[ 0.689542] ACPI: Power Resource [PXP] (off)
[ 0.690456] ACPI: Power Resource [PXP] (off)
[ 0.691697] ACPI: Power Resource [PXP] (off)
[ 0.697722] ACPI: Power Resource [PAUD] (on)
[ 0.700085] ACPI: Power Resource [V0PR] (on)
[ 0.700191] ACPI: Power Resource [V1PR] (on)
[ 0.700292] ACPI: Power Resource [V2PR] (on)
[ 0.702734] ACPI: Power Resource [PXTC] (on)
[ 0.703002] ACPI: Power Resource [PTPL] (on)
[ 0.703555] ACPI: Power Resource [PXTC] (on)
[ 0.704194] ACPI: Power Resource [PXTC] (on)
[ 0.705985] ACPI: Power Resource [WRST] (on)
[ 0.714066] ACPI: Power Resource [TBT0] (on)
[ 0.714289] ACPI: Power Resource [TBT1] (on)
[ 0.714504] ACPI: Power Resource [D3C] (on)
[ 0.973010] ACPI: Power Resource [FN00] (off)
[ 0.973068] ACPI: Power Resource [FN01] (off)
[ 0.973125] ACPI: Power Resource [FN02] (off)
[ 0.973183] ACPI: Power Resource [FN03] (off)
[ 0.973239] ACPI: Power Resource [FN04] (off)
[ 0.973870] ACPI: Power Resource [PIN] (off)
[ 0.974173] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[ 0.974178] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.977248] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.982832] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 0.985025] PCI host bridge to bus 0000:00
[ 0.985027] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.985029] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.985030] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.985031] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.985032] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.985033] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ 0.985034] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ 0.985035] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.985036] pci_bus 0000:00: root bus resource [mem 0x4f800000-0xbfffffff window]
[ 0.985037] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.985039] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.985065] pci 0000:00:00.0: [8086:9a04] type 00 class 0x060000
[ 0.985914] pci 0000:00:02.0: [8086:9a78] type 00 class 0x030000
[ 0.985924] pci 0000:00:02.0: reg 0x10: [mem 0x603c000000-0x603cffffff 64bit]
[ 0.985929] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.985933] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.985945] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.985969] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[ 0.985971] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[ 0.985975] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[ 0.985976] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[ 0.986272] pci 0000:00:06.0: [8086:9a09] type 01 class 0x060400
[ 0.986335] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.986348] pci 0000:00:06.0: PTM enabled (root), 4dns granularity
[ 0.986741] pci 0000:00:07.0: [8086:9a25] type 01 class 0x060400
[ 0.987022] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.987342] pci 0000:00:07.2: [8086:9a27] type 01 class 0x060400
[ 0.987620] pci 0000:00:07.2: PME# supported from D0 D3hot D3cold
[ 0.987991] pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
[ 0.988002] pci 0000:00:08.0: reg 0x10: [mem 0x603d1b3000-0x603d1b3fff 64bit]
[ 0.988322] pci 0000:00:0d.0: [8086:9a13] type 00 class 0x0c0330
[ 0.988338] pci 0000:00:0d.0: reg 0x10: [mem 0x603d190000-0x603d19ffff 64bit]
[ 0.988392] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.988948] pci 0000:00:0d.2: [8086:9a1b] type 00 class 0x0c0340
[ 0.988948] pci 0000:00:0d.2: reg 0x10: [mem 0x603d140000-0x603d17ffff 64bit]
[ 0.988948] pci 0000:00:0d.2: reg 0x18: [mem 0x603d1b2000-0x603d1b2fff 64bit]
[ 0.988968] pci 0000:00:0d.2: supports D1 D2
[ 0.988969] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.989212] pci 0000:00:0d.3: [8086:9a1d] type 00 class 0x0c0340
[ 0.989225] pci 0000:00:0d.3: reg 0x10: [mem 0x603d100000-0x603d13ffff 64bit]
[ 0.989231] pci 0000:00:0d.3: reg 0x18: [mem 0x603d1b1000-0x603d1b1fff 64bit]
[ 0.989263] pci 0000:00:0d.3: supports D1 D2
[ 0.989264] pci 0000:00:0d.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.989643] pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
[ 0.989671] pci 0000:00:14.0: reg 0x10: [mem 0x603d180000-0x603d18ffff 64bit]
[ 0.989774] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.990272] pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
[ 0.990297] pci 0000:00:14.2: reg 0x10: [mem 0x603d1a8000-0x603d1abfff 64bit]
[ 0.990310] pci 0000:00:14.2: reg 0x18: [mem 0x603d1b0000-0x603d1b0fff 64bit]
[ 0.990651] pci 0000:00:14.3: [8086:a0f0] type 00 class 0x028000
[ 0.990681] pci 0000:00:14.3: reg 0x10: [mem 0x603d1a4000-0x603d1a7fff 64bit]
[ 0.990809] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.991455] pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
[ 0.992348] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.995836] pci 0000:00:15.1: [8086:a0e9] type 00 class 0x0c8000
[ 0.996738] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.999966] pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
[ 0.999997] pci 0000:00:16.0: reg 0x10: [mem 0x603d1ad000-0x603d1adfff 64bit]
[ 1.000093] pci 0000:00:16.0: PME# supported from D3hot
[ 1.000485] pci 0000:00:17.0: [8086:a0d3] type 00 class 0x010601
[ 1.000507] pci 0000:00:17.0: reg 0x10: [mem 0x6a500000-0x6a501fff]
[ 1.000516] pci 0000:00:17.0: reg 0x14: [mem 0x6a503000-0x6a5030ff]
[ 1.000525] pci 0000:00:17.0: reg 0x18: [io 0x3090-0x3097]
[ 1.000535] pci 0000:00:17.0: reg 0x1c: [io 0x3080-0x3083]
[ 1.000544] pci 0000:00:17.0: reg 0x20: [io 0x3060-0x307f]
[ 1.000553] pci 0000:00:17.0: reg 0x24: [mem 0x6a502000-0x6a5027ff]
[ 1.000607] pci 0000:00:17.0: PME# supported from D3hot
[ 1.001000] pci 0000:00:1d.0: [8086:a0b1] type 01 class 0x060400
[ 1.001138] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.001164] pci 0000:00:1d.0: PTM enabled (root), 4dns granularity
[ 1.001582] pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
[ 1.002001] pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040300
[ 1.002077] pci 0000:00:1f.3: reg 0x10: [mem 0x603d1a0000-0x603d1a3fff 64bit]
[ 1.002146] pci 0000:00:1f.3: reg 0x20: [mem 0x603d000000-0x603d0fffff 64bit]
[ 1.002311] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 1.002653] pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
[ 1.002725] pci 0000:00:1f.4: reg 0x10: [mem 0x603d1ac000-0x603d1ac0ff 64bit]
[ 1.002758] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 1.003082] pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
[ 1.003102] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 1.003470] pci 0000:01:00.0: [1cd7:0052] type 00 class 0x040000
[ 1.003485] pci 0000:01:00.0: reg 0x10: [mem 0x6a400000-0x6a43ffff]
[ 1.003559] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot
[ 1.003607] pci 0000:00:06.0: PCI bridge to [bus 01]
[ 1.003610] pci 0000:00:06.0: bridge window [mem 0x6a400000-0x6a4fffff]
[ 1.003642] pci 0000:00:07.0: PCI bridge to [bus 02-2c]
[ 1.003646] pci 0000:00:07.0: bridge window [mem 0x5e000000-0x6a1fffff]
[ 1.003650] pci 0000:00:07.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 1.003682] pci 0000:00:07.2: PCI bridge to [bus 2d-57]
[ 1.003686] pci 0000:00:07.2: bridge window [mem 0x50000000-0x5c1fffff]
[ 1.003690] pci 0000:00:07.2: bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[ 1.003852] pci 0000:58:00.0: [8086:15f2] type 00 class 0x020000
[ 1.003886] pci 0000:58:00.0: reg 0x10: [mem 0x6a200000-0x6a2fffff]
[ 1.003920] pci 0000:58:00.0: reg 0x1c: [mem 0x6a300000-0x6a303fff]
[ 1.004052] pci 0000:58:00.0: PME# supported from D0 D3hot D3cold
[ 1.004179] pci 0000:00:1d.0: PCI bridge to [bus 58]
[ 1.004183] pci 0000:00:1d.0: bridge window [mem 0x6a200000-0x6a3fffff]
[ 1.009630] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.009717] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 1.009801] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.009885] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.009970] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.010054] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.010137] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.010221] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 1.023096] ACPI: EC: interrupt unblocked
[ 1.023115] ACPI: EC: event unblocked
[ 1.023136] ACPI: _SB_.PC00.LPCB.H_EC: GPE=0x6e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 1.023137] ACPI: _SB_.PC00.LPCB.H_EC: Boot DSDT EC used to handle transactions and events
[ 1.023225] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 1.023225] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 1.023225] pci 0000:00:02.0: vgaarb: bridge control possible
[ 1.023225] vgaarb: loaded
[ 1.023225] SCSI subsystem initialized
[ 1.023225] libata version 3.00 loaded.
[ 1.023225] ACPI: bus type USB registered
[ 1.023225] usbcore: registered new interface driver usbfs
[ 1.023225] usbcore: registered new interface driver hub
[ 1.023225] usbcore: registered new device driver usb
[ 1.023225] pps_core: LinuxPPS API ver. 1 registered
[ 1.023225] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.023225] PTP clock support registered
[ 1.023225] EDAC MC: Ver: 3.0.0
[ 1.023942] Registered efivars operations
[ 1.037011] Advanced Linux Sound Architecture Driver Initialized.
[ 1.037011] PCI: Using ACPI for IRQ routing
[ 1.110576] PCI: pci_cache_line_size set to 64 bytes
[ 1.110838] pci 0000:00:1f.5: can’t claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 1.111057] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 1.111058] e820: reserve RAM buffer [mem 0x38169000-0x3bffffff]
[ 1.111058] e820: reserve RAM buffer [mem 0x41800000-0x43ffffff]
[ 1.111058] e820: reserve RAM buffer [mem 0x1b0800000-0x1b3ffffff]
[ 1.111127] Bluetooth: Core ver 2.22
[ 1.111130] NET: Registered protocol family 31
[ 1.111131] Bluetooth: HCI device and connection manager initialized
[ 1.111133] Bluetooth: HCI socket layer initialized
[ 1.111134] Bluetooth: L2CAP socket layer initialized
[ 1.111135] Bluetooth: SCO socket layer initialized
[ 1.111137] NetLabel: Initializing
[ 1.111138] NetLabel: domain hash size = 128
[ 1.111139] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.111146] NetLabel: unlabeled traffic allowed by default
[ 1.111156] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.111156] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
[ 1.112925] clocksource: Switched to clocksource tsc-early
[ 1.164485] VFS: Disk quotas dquot_6.6.0
[ 1.164495] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.164538] pnp: PnP ACPI init
[ 1.164977] system 00:00: [io 0x0a00-0x0a0f] has been reserved
[ 1.164978] system 00:00: [io 0x0a10-0x0a2f] has been reserved
[ 1.164979] system 00:00: [io 0x0a30-0x0a4f] has been reserved
[ 1.164981] system 00:00: [io 0x0a50-0x0a6f] has been reserved
[ 1.164982] system 00:00: [io 0x0a70-0x0a7f] has been reserved
[ 1.164983] system 00:00: [io 0x0a80-0x0a8f] has been reserved
[ 1.164986] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.165479] pnp 00:01: [dma 0 disabled]
[ 1.165500] pnp 00:01: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.165598] system 00:02: [io 0x0680-0x069f] has been reserved
[ 1.165600] system 00:02: [io 0x164e-0x164f] has been reserved
[ 1.165602] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.165697] system 00:03: [io 0x1854-0x1857] has been reserved
[ 1.165699] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.166283] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 1.166299] system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 1.166300] system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 1.166301] system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 1.166302] system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 1.166303] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 1.166305] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 1.166306] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 1.166308] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.168686] system 00:05: [io 0x1800-0x18fe] could not be reserved
[ 1.168688] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 1.168689] system 00:05: [mem 0xfe04c000-0xfe04ffff] has been reserved
[ 1.168690] system 00:05: [mem 0xfe050000-0xfe0affff] has been reserved
[ 1.168691] system 00:05: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[ 1.168693] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 1.168694] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 1.168695] system 00:05: [mem 0xfd000000-0xfd68ffff] has been reserved
[ 1.168696] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[ 1.168697] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 1.168699] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.168966] system 00:06: [io 0x2000-0x20fe] has been reserved
[ 1.168968] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.169150] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.169340] pnp: PnP ACPI: found 8 devices
[ 1.174612] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.174615] pci_bus 0000:00: max bus depth: 1 pci_try_num: 2
[ 1.174623] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[ 1.174626] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[ 1.174629] pci 0000:00:07.0: BAR 13: assigned [io 0x4000-0x4fff]
[ 1.174630] pci 0000:00:07.2: BAR 13: assigned [io 0x5000-0x5fff]
[ 1.174632] pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
[ 1.174980] pci 0000:00:15.1: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
[ 1.175331] pci 0000:00:1f.5: BAR 0: assigned [mem 0x4f800000-0x4f800fff]
[ 1.175347] pci 0000:00:06.0: PCI bridge to [bus 01]
[ 1.175350] pci 0000:00:06.0: bridge window [mem 0x6a400000-0x6a4fffff]
[ 1.175354] pci 0000:00:07.0: PCI bridge to [bus 02-2c]
[ 1.175355] pci 0000:00:07.0: bridge window [io 0x4000-0x4fff]
[ 1.175358] pci 0000:00:07.0: bridge window [mem 0x5e000000-0x6a1fffff]
[ 1.175361] pci 0000:00:07.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 1.175365] pci 0000:00:07.2: PCI bridge to [bus 2d-57]
[ 1.175367] pci 0000:00:07.2: bridge window [io 0x5000-0x5fff]
[ 1.175370] pci 0000:00:07.2: bridge window [mem 0x50000000-0x5c1fffff]
[ 1.175372] pci 0000:00:07.2: bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[ 1.175376] pci 0000:00:1d.0: PCI bridge to [bus 58]
[ 1.175394] pci 0000:00:1d.0: bridge window [mem 0x6a200000-0x6a3fffff]
[ 1.175402] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 1.175403] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 1.175404] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.175405] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
[ 1.175406] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
[ 1.175407] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
[ 1.175408] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
[ 1.175409] pci_bus 0000:00: resource 11 [mem 0x000f0000-0x000fffff window]
[ 1.175410] pci_bus 0000:00: resource 12 [mem 0x4f800000-0xbfffffff window]
[ 1.175411] pci_bus 0000:00: resource 13 [mem 0x4000000000-0x7fffffffff window]
[ 1.175412] pci_bus 0000:01: resource 1 [mem 0x6a400000-0x6a4fffff]
[ 1.175413] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 1.175414] pci_bus 0000:02: resource 1 [mem 0x5e000000-0x6a1fffff]
[ 1.175415] pci_bus 0000:02: resource 2 [mem 0x6020000000-0x603bffffff 64bit pref]
[ 1.175416] pci_bus 0000:2d: resource 0 [io 0x5000-0x5fff]
[ 1.175417] pci_bus 0000:2d: resource 1 [mem 0x50000000-0x5c1fffff]
[ 1.175418] pci_bus 0000:2d: resource 2 [mem 0x6000000000-0x601bffffff 64bit pref]
[ 1.175419] pci_bus 0000:58: resource 1 [mem 0x6a200000-0x6a3fffff]
[ 1.175553] NET: Registered protocol family 2
[ 1.175625] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.175634] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.175666] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.175711] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.175729] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.175738] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.175778] NET: Registered protocol family 1
[ 1.175870] RPC: Registered named UNIX socket transport module.
[ 1.175871] RPC: Registered udp transport module.
[ 1.175872] RPC: Registered tcp transport module.
[ 1.175873] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.175874] NET: Registered protocol family 44
[ 1.175884] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.176452] PCI: CLS 64 bytes, default 64
[ 1.180351] DMAR: Intel-IOMMU force enabled due to platform opt in
[ 1.180367] DMAR: No ATSR found
[ 1.180392] DMAR: dmar2: Using Queued invalidation
[ 1.180395] DMAR: dmar1: Using Queued invalidation
[ 1.180397] DMAR: dmar0: Using Queued invalidation
[ 1.180399] DMAR: dmar3: Using Queued invalidation
[ 1.180520] pci 0000:00:00.0: DMAR: Hardware identity mapping
[ 1.180523] pci 0000:00:02.0: DMAR: Hardware identity mapping
[ 1.180525] pci 0000:00:06.0: DMAR: Hardware identity mapping
[ 1.180526] pci 0000:00:08.0: DMAR: Hardware identity mapping
[ 1.180527] pci 0000:00:0d.0: DMAR: Hardware identity mapping
[ 1.180528] pci 0000:00:0d.2: DMAR: Hardware identity mapping
[ 1.180529] pci 0000:00:0d.3: DMAR: Hardware identity mapping
[ 1.180530] pci 0000:00:14.0: DMAR: Hardware identity mapping
[ 1.180531] pci 0000:00:14.2: DMAR: Hardware identity mapping
[ 1.180533] pci 0000:00:14.3: DMAR: Hardware identity mapping
[ 1.180534] pci 0000:00:15.0: DMAR: Hardware identity mapping
[ 1.180535] pci 0000:00:15.1: DMAR: Hardware identity mapping
[ 1.180536] pci 0000:00:16.0: DMAR: Hardware identity mapping
[ 1.180537] pci 0000:00:17.0: DMAR: Hardware identity mapping
[ 1.180538] pci 0000:00:1d.0: DMAR: Hardware identity mapping
[ 1.180539] pci 0000:00:1f.0: DMAR: Hardware identity mapping
[ 1.180540] pci 0000:00:1f.3: DMAR: Hardware identity mapping
[ 1.180541] pci 0000:00:1f.4: DMAR: Hardware identity mapping
[ 1.180543] pci 0000:00:1f.5: DMAR: Hardware identity mapping
[ 1.180545] pci 0000:01:00.0: DMAR: Hardware identity mapping
[ 1.180547] pci 0000:58:00.0: DMAR: Hardware identity mapping
[ 1.180548] DMAR: Setting RMRR:
[ 1.180549] pci 0000:00:02.0: DMAR: Ignoring identity map for HW passthrough [0x4b000000 - 0x4f7fffff]
[ 1.180551] DMAR: Prepare 0-16MiB unity mapping for LPC
[ 1.180552] pci 0000:00:1f.0: DMAR: Ignoring identity map for HW passthrough [0x0 - 0xffffff]
[ 1.180586] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 1.180618] pci 0000:00:00.0: Adding to iommu group 0
[ 1.180623] pci 0000:00:02.0: Adding to iommu group 1
[ 1.180632] pci 0000:00:06.0: Adding to iommu group 2
[ 1.180647] pci 0000:00:07.0: Adding to iommu group 3
[ 1.180656] pci 0000:00:07.2: Adding to iommu group 3
[ 1.180661] pci 0000:00:08.0: Adding to iommu group 4
[ 1.180671] pci 0000:00:0d.0: Adding to iommu group 5
[ 1.180676] pci 0000:00:0d.2: Adding to iommu group 5
[ 1.180681] pci 0000:00:0d.3: Adding to iommu group 5
[ 1.180724] pci 0000:00:14.0: Adding to iommu group 6
[ 1.180728] pci 0000:00:14.2: Adding to iommu group 6
[ 1.180756] pci 0000:00:14.3: Adding to iommu group 6
[ 1.180765] pci 0000:00:15.0: Adding to iommu group 7
[ 1.180771] pci 0000:00:15.1: Adding to iommu group 7
[ 1.180779] pci 0000:00:16.0: Adding to iommu group 8
[ 1.180783] pci 0000:00:17.0: Adding to iommu group 9
[ 1.180807] pci 0000:00:1d.0: Adding to iommu group 10
[ 1.180819] pci 0000:00:1f.0: Adding to iommu group 11
[ 1.180825] pci 0000:00:1f.3: Adding to iommu group 11
[ 1.180831] pci 0000:00:1f.4: Adding to iommu group 11
[ 1.180836] pci 0000:00:1f.5: Adding to iommu group 11
[ 1.180840] pci 0000:01:00.0: Adding to iommu group 2
[ 1.180860] pci 0000:58:00.0: Adding to iommu group 10
[ 1.181659] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b2c8ec87c7, max_idle_ns: 440795278598 ns
[ 1.181673] clocksource: Switched to clocksource tsc
[ 1.181690] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 1.181958] check: Scanning for low memory corruption every 60 seconds
[ 1.182678] Initialise system trusted keyrings
[ 1.182687] Key type blacklist registered
[ 1.182713] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 1.183409] zbud: loaded
[ 1.183577] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.183746] NFS: Registering the id_resolver key type
[ 1.183748] Key type id_resolver registered
[ 1.183749] Key type id_legacy registered
[ 1.183751] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.183770] fuse: init (API version 7.31)
[ 1.184382] async_tx: api initialized (async)
[ 1.184385] Key type asymmetric registered
[ 1.184386] Asymmetric key parser ā€˜x509’ registered
[ 1.184391] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.184412] io scheduler mq-deadline registered
[ 1.184413] io scheduler kyber registered
[ 1.184656] pcieport 0000:00:06.0: PME: Signaling with IRQ 124
[ 1.184816] pcieport 0000:00:07.0: PME: Signaling with IRQ 125
[ 1.184830] pcieport 0000:00:07.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.185029] pcieport 0000:00:07.2: PME: Signaling with IRQ 126
[ 1.185043] pcieport 0000:00:07.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.185298] pcieport 0000:00:1d.0: PME: Signaling with IRQ 127
[ 1.185406] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.185421] hv_vmbus: registering driver hv_pci
[ 1.185438] hv_vmbus: registering driver hyperv_fb
[ 1.185444] efifb: probing for efifb
[ 1.185451] efifb: framebuffer at 0x4000000000, using 1920k, total 1920k
[ 1.185452] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 1.185453] efifb: scrolling: redraw
[ 1.185454] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.186481] Console: switching to colour frame buffer device 100x37
[ 1.187467] fb0: EFI VGA frame buffer device
[ 1.187482] intel_idle: does not run on family 6 model 140
[ 1.187605] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.187634] ACPI: Sleep Button [SLPB]
[ 1.187659] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.187684] ACPI: Power Button [PWRB]
[ 1.187707] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.187734] ACPI: Power Button [PWRF]
[ 1.188511] Monitor-Mwait will be used to enter C-1 state
[ 1.188513] Monitor-Mwait will be used to enter C-2 state
[ 1.188514] Monitor-Mwait will be used to enter C-3 state
[ 1.189552] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.189567] ACPI: Thermal Zone [TZ00] (64 C)
[ 1.189688] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.213073] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.214347] Linux agpgart interface v0.103
[ 1.223855] loop: module loaded
[ 1.224523] mtip32xx Version 1.3.1
[ 1.225161] zram: Added device: zram0
[ 1.225771] Uniform Multi-Platform E-IDE driver
[ 1.227742] ide_generic: please use ā€œprobe_mask=0x3fā€ module parameter for probing all legacy ISA IDE ports
[ 1.229006] legacy IDE will be removed in 2021, please switch to libata
Report any missing HW support to linux-ide@vger.kernel.org
[ 1.230282] Probing IDE interface ide0…
[ 1.753122] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 1.753886] legacy IDE will be removed in 2021, please switch to libata
[ 1.755594] Probing IDE interface ide1…
[ 2.278133] ide1 at 0x170-0x177,0x376 on irq 15
[ 2.278872] ide-gd driver 1.18
[ 2.279709] hv_vmbus: registering driver hv_storvsc
[ 2.280854] ahci 0000:00:17.0: version 3.0
[ 2.281186] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 2.281919] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds
[ 2.282940] scsi host0: ahci
[ 2.283718] ata1: SATA max UDMA/133 abar m2048@0x6a502000 port 0x6a502100 irq 128
[ 2.284850] Error: Driver ā€˜pata_platform’ is already registered, aborting…
[ 2.285734] libphy: Fixed MDIO Bus: probed
[ 2.286544] tun: Universal TUN/TAP device driver, 1.6
[ 2.287420] PPP generic driver version 2.4.2
[ 2.288292] Fusion MPT base driver 3.04.20
[ 2.288988] Copyright (c) 1999-2008 LSI Corporation
[ 2.289589] Fusion MPT SPI Host driver 3.04.20
[ 2.290231] Fusion MPT SAS Host driver 3.04.20
[ 2.290815] Fusion MPT misc device (ioctl) driver 3.04.20
[ 2.291539] mptctl: Registered with Fusion MPT base driver
[ 2.292134] mptctl: /dev/mptctl @ (major,minor=10,220)
[ 2.292696] pd: pd version 1.05, major 45, cluster 64, nice 0
[ 2.293986] pda: Autoprobe failed
[ 2.294527] pd: no valid drive found
[ 2.295164] pf: pf version 1.04, major 47, cluster 64, nice 0
[ 2.296044] pf: No ATAPI disk detected
[ 2.296608] ehci_hcd: USB 2.0 ā€˜Enhanced’ Host Controller (EHCI) Driver
[ 2.297172] ehci-pci: EHCI PCI platform driver
[ 2.297717] ehci-platform: EHCI generic platform driver
[ 2.298290] ohci_hcd: USB 1.1 ā€˜Open’ Host Controller (OHCI) Driver
[ 2.298836] ohci-pci: OHCI PCI platform driver
[ 2.299434] ohci-platform: OHCI generic platform driver
[ 2.300008] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.300586] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 2.301151] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 2.302746] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[ 2.303909] xhci_hcd 0000:00:0d.0: cache line size of 64 is not supported
[ 2.304576] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.02
[ 2.305166] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.305713] usb usb1: Product: xHCI Host Controller
[ 2.306298] usb usb1: Manufacturer: Linux 5.2.10-yocto-standard xhci-hcd
[ 2.306849] usb usb1: SerialNumber: 0000:00:0d.0
[ 2.307554] hub 1-0:1.0: USB hub found
[ 2.308118] hub 1-0:1.0: 1 port detected
[ 2.308734] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 2.309297] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 2.309823] xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.310410] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.02
[ 2.310940] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.311485] usb usb2: Product: xHCI Host Controller
[ 2.312024] usb usb2: Manufacturer: Linux 5.2.10-yocto-standard xhci-hcd
[ 2.312556] usb usb2: SerialNumber: 0000:00:0d.0
[ 2.313228] hub 2-0:1.0: USB hub found
[ 2.313782] hub 2-0:1.0: 4 ports detected
[ 2.314904] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.315514] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 2.317190] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[ 2.318334] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 2.319124] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.02
[ 2.319717] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.320343] usb usb3: Product: xHCI Host Controller
[ 2.320901] usb usb3: Manufacturer: Linux 5.2.10-yocto-standard xhci-hcd
[ 2.321539] usb usb3: SerialNumber: 0000:00:14.0
[ 2.322239] hub 3-0:1.0: USB hub found
[ 2.322833] hub 3-0:1.0: 12 ports detected
[ 2.324384] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.324966] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 2.325528] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.326164] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.02
[ 2.326740] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.327364] usb usb4: Product: xHCI Host Controller
[ 2.327928] usb usb4: Manufacturer: Linux 5.2.10-yocto-standard xhci-hcd
[ 2.328479] usb usb4: SerialNumber: 0000:00:14.0
[ 2.329138] hub 4-0:1.0: USB hub found
[ 2.329693] hub 4-0:1.0: 4 ports detected
[ 2.330634] usbcore: registered new interface driver usb-storage
[ 2.331226] usbcore: registered new interface driver usbserial_generic
[ 2.331760] usbserial: USB Serial support registered for generic
[ 2.332346] i8042: PNP: No PS/2 controller found.
[ 2.332878] hv_vmbus: registering driver hyperv_keyboard
[ 2.333569] mousedev: PS/2 mouse device common for all mice
[ 2.334292] rtc_cmos rtc_cmos: RTC can wake from S4
[ 2.336064] rtc_cmos rtc_cmos: registered as rtc0
[ 2.336598] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 2.337158] i2c /dev entries driver
[ 2.337792] device-mapper: uevent: version 1.0.3
[ 2.338428] device-mapper: ioctl: 4.40.0-ioctl (2019-01-18) initialised: dm-devel@redhat.com
[ 2.339007] platform eisa.0: Probing EISA bus 0
[ 2.339562] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 2.340131] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 2.340692] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 2.341274] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 2.341790] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 2.342346] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 2.342832] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 2.343347] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 2.343808] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 2.344294] platform eisa.0: EISA: Detected 0 cards
[ 2.344747] intel_pstate: Intel P-state driver initializing
[ 2.345905] intel_pstate: HWP enabled
[ 2.346409] sdhci: Secure Digital Host Controller Interface driver
[ 2.346864] sdhci: Copyright(c) Pierre Ossman
[ 2.347372] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.347886] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.348394] EFI Variables Facility v0.08 2004-May-17
[ 2.363194] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.363664] hv_vmbus: registering driver hid_hyperv
[ 2.364171] usbcore: registered new interface driver usbhid
[ 2.364612] usbhid: USB HID core driver
[ 2.365067] hv_utils: Registering HyperV Utility Driver
[ 2.365503] hv_vmbus: registering driver hv_utils
[ 2.365946] hv_vmbus: registering driver hv_balloon
[ 2.366458] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[ 2.366918] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.367524] IPVS: ipvs loaded.
[ 2.368141] NET: Registered protocol family 10
[ 2.370433] Segment Routing with IPv6
[ 2.370896] NET: Registered protocol family 17
[ 2.371392] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.372395] Key type dns_resolver registered
[ 2.373136] mce: Using 19 MCE banks
[ 2.373598] RAS: Correctable Errors collector initialized.
[ 2.374097] microcode: sig=0x806c1, pf=0x80, revision=0x6c
[ 2.374810] microcode: Microcode Update Driver: v2.2.
[ 2.374867] resctrl: L2 allocation detected
[ 2.375793] resctrl: L2DATA allocation detected
[ 2.376276] resctrl: L2CODE allocation detected
[ 2.376729] sched_clock: Marking stable (2375364020, 911412)->(2384548549, -8273117)
[ 2.377343] registered taskstats version 1
[ 2.377813] Loading compiled-in X.509 certificates
[ 2.379070] Loaded X.509 cert ā€˜Build time autogenerated kernel key: 6d91104e4cd118f45e452145ba8f441c9b8789e9’
[ 2.380160] zswap: loaded using pool lzo/zbud
[ 2.382368] Key type big_key registered
[ 2.382896] Key type trusted registered
[ 2.384269] Key type encrypted registered
[ 2.384791] ima: Allocated hash algorithm: sha1
[ 2.401365] ima: Error Communicating to TPM chip
[ 2.402567] ima: Error Communicating to TPM chip
[ 2.403551] ima: Error Communicating to TPM chip
[ 2.404509] ima: Error Communicating to TPM chip
[ 2.405455] ima: Error Communicating to TPM chip
[ 2.406395] ima: Error Communicating to TPM chip
[ 2.407273] ima: Error Communicating to TPM chip
[ 2.408156] ima: Error Communicating to TPM chip
[ 2.412125] No architecture policies found
[ 2.412559] evm: Initialising EVM extended attributes:
[ 2.413028] evm: security.selinux
[ 2.413523] evm: security.SMACK64
[ 2.414008] evm: security.SMACK64EXEC
[ 2.414485] evm: security.SMACK64TRANSMUTE
[ 2.414942] evm: security.SMACK64MMAP
[ 2.415387] evm: security.apparmor
[ 2.415830] evm: security.ima
[ 2.416258] evm: security.capability
[ 2.416636] evm: HMAC attrs: 0x1
[ 2.418986] PM: Magic number: 5:48:599
[ 2.419372] serial8250 serial8250: hash matches
[ 2.420132] rtc_cmos rtc_cmos: setting system clock to 2021-05-12T20:34:36 UTC (1620851676)
[ 2.420585] ALSA device list:
[ 2.420952] No soundcards found.
[ 2.591118] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.599283] ata1.00: ATA-9: C6308, S0222A0, max UDMA/133
[ 2.599925] ata1.00: 125045424 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 2.610645] ata1.00: configured for UDMA/133
[ 2.611631] scsi 0:0:0:0: Direct-Access ATA C6308 2A0 PQ: 0 ANSI: 5
[ 2.612636] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.612767] sd 0:0:0:0: [sda] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[ 2.614054] sd 0:0:0:0: [sda] Write Protect is off
[ 2.614678] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.614836] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.617375] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 2.618682] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.626346] Freeing unused decrypted memory: 2040K
[ 2.628798] Freeing unused kernel image memory: 13912K
[ 2.631073] Write protecting the kernel read-only data: 24576k
[ 2.632329] Freeing unused kernel image memory: 2008K
[ 2.633087] Freeing unused kernel image memory: 300K
[ 2.640226] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.640681] Run /init as init process
[ 2.649962] usb 3-10: new full-speed USB device number 2 using xhci_hcd
[ 2.727723] zram0: detected capacity change from 0 to 950763520
[ 2.777245] usb 3-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 2.777890] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.942474] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.951572] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.018643] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 3.148949] systemd[1]: /lib/systemd/system/chronyd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/chrony/chronyd.pid \xe2\x86\x92 /run/chrony/chronyd.pid; please update the unit file accordingly.
[ 3.236007] sch_fq_codel: module verification failed: signature and/or required key missing - tainting kernel
[ 3.301101] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.447077] evbug: Connected device: input0 (Sleep Button at PNP0C0E/button/input0)
[ 3.447079] evbug: Connected device: input1 (Power Button at PNP0C0C/button/input0)
[ 3.447080] evbug: Connected device: input2 (Power Button at LNXPWRBN/button/input0)
[ 3.463027] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.465147] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.478522] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.480659] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 3.481380] evbug: Connected device: input3 (PC Speaker at isa0061/input0)
[ 3.482797] cfg80211: Loaded X.509 cert ā€˜sforshee: 00b28ddf47aef9cea7’
[ 3.491606] usbcore: registered new interface driver btusb
[ 3.494105] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
[ 3.495845] Bluetooth: hci0: Device revision is 2
[ 3.496548] Bluetooth: hci0: Secure boot is enabled
[ 3.497253] Bluetooth: hci0: OTP lock is enabled
[ 3.497961] Bluetooth: hci0: API lock is enabled
[ 3.498638] Bluetooth: hci0: Debug lock is disabled
[ 3.499332] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 3.505012] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 3.506557] cryptd: max_cpu_qlen set to 1000
[ 3.508238] Error: Driver ā€˜pcspkr’ is already registered, aborting…
[ 3.510146] Intel(R) 2.5G Ethernet Linux Driver - version 0.0.1-k
[ 3.510926] Copyright(c) 2018 Intel Corporation.
[ 3.514495] Intel(R) Wireless WiFi driver for Linux
[ 3.515264] Copyright(c) 2003- 2015 Intel Corporation
[ 3.515343] iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
[ 3.529533] snd_hda_intel 0000:00:1f.3: enabling device (0000 → 0002)
[ 3.531199] snd_hda_intel 0000:00:1f.3: number of I/O streams is 16, forcing separate stream tags
[ 3.542504] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[ 3.543412] iwlwifi 0000:00:14.3: Found debug configuration: 0
[ 3.544678] iwlwifi 0000:00:14.3: loaded firmware version 48.954cff6d.0 op_mode iwlmvm
[ 3.548790] AVX2 version of gcm_enc/dec engaged.
[ 3.549662] AES CTR mode by8 optimization enabled
[ 3.552425] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input4
[ 3.553475] evbug: Connected device: input4 (HDA Intel HDMI/DP,pcm=3 at ALSA)
[ 3.554148] zram: Can’t change algorithm for initialized device
[ 3.575539] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x354
[ 3.583771] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 3.585098] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[ 3.627293] igc 0000:58:00.0: 4.000 Gb/s available PCIe bandwidth (5 GT/s x1 link)
[ 3.628252] igc 0000:58:00.0 eth0: MAC: 54:b2:03:9e:be:52
[ 3.667289] igc 0000:58:00.0 enp88s0: renamed from eth0
[ 4.631924] iwlwifi 0000:00:14.3: Collecting data: trigger 15 fired.
[ 4.632625] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4.633252] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -1891312816
[ 4.633858] iwlwifi 0000:00:14.3: Loaded firmware version: 48.954cff6d.0
[ 4.634556] iwlwifi 0000:00:14.3: 0xF1AD81A9 | ADVANCED_SYSASSERT
[ 4.635192] iwlwifi 0000:00:14.3: 0x91DCF35F | trm_hw_status0
[ 4.635808] iwlwifi 0000:00:14.3: 0x15D19AFF | trm_hw_status1
[ 4.636470] iwlwifi 0000:00:14.3: 0xA9605C6A | branchlink2
[ 4.637102] iwlwifi 0000:00:14.3: 0xC8747A13 | interruptlink1
[ 4.637696] iwlwifi 0000:00:14.3: 0xEDD53FC9 | interruptlink2
[ 4.638314] iwlwifi 0000:00:14.3: 0xD3C63ADF | data1
[ 4.638896] iwlwifi 0000:00:14.3: 0xFF808EB2 | data2
[ 4.639536] iwlwifi 0000:00:14.3: 0xCA81D233 | data3
[ 4.640114] iwlwifi 0000:00:14.3: 0xCF9FBA9B | beacon time
[ 4.640633] iwlwifi 0000:00:14.3: 0x3AD8E34D | tsf low
[ 4.641236] iwlwifi 0000:00:14.3: 0x211248A5 | tsf hi
[ 4.641772] iwlwifi 0000:00:14.3: 0x51CA8AB4 | time gp1
[ 4.642342] iwlwifi 0000:00:14.3: 0x4898AB3E | time gp2
[ 4.642850] iwlwifi 0000:00:14.3: 0xAFF3B6A5 | uCode revision type
[ 4.643408] iwlwifi 0000:00:14.3: 0xCC6D720B | uCode version major
[ 4.643915] iwlwifi 0000:00:14.3: 0x24C8A9A8 | uCode version minor
[ 4.644409] iwlwifi 0000:00:14.3: 0x6C7311C5 | hw version
[ 4.644916] iwlwifi 0000:00:14.3: 0xFC1A7E6C | board version
[ 4.645395] iwlwifi 0000:00:14.3: 0xF659365A | hcmd
[ 4.645837] iwlwifi 0000:00:14.3: 0x6106E5A1 | isr0
[ 4.646331] iwlwifi 0000:00:14.3: 0x5DC99500 | isr1
[ 4.646775] iwlwifi 0000:00:14.3: 0x4DB99DBB | isr2
[ 4.647247] iwlwifi 0000:00:14.3: 0xAEF6C1F1 | isr3
[ 4.647655] iwlwifi 0000:00:14.3: 0x1451BA84 | isr4
[ 4.648084] iwlwifi 0000:00:14.3: 0x68A00A24 | last cmd Id
[ 4.648450] iwlwifi 0000:00:14.3: 0x3F4FFBFB | wait_event
[ 4.648826] iwlwifi 0000:00:14.3: 0xAED665AE | l2p_control
[ 4.649242] iwlwifi 0000:00:14.3: 0xEE804D1A | l2p_duration
[ 4.649605] iwlwifi 0000:00:14.3: 0xA7580A16 | l2p_mhvalid
[ 4.649951] iwlwifi 0000:00:14.3: 0xED99D771 | l2p_addr_match
[ 4.650305] iwlwifi 0000:00:14.3: 0xA05F77F1 | lmpm_pmg_sel
[ 4.650632] iwlwifi 0000:00:14.3: 0x3C082858 | timestamp
[ 4.650958] iwlwifi 0000:00:14.3: 0xCAF5B809 | flow_handler
[ 4.651315] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 4.651629] iwlwifi 0000:00:14.3: Status: 0x00000000, count: 7
[ 4.651960] iwlwifi 0000:00:14.3: 0x201013F1 | ADVANCED_SYSASSERT
[ 4.652293] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 4.652611] iwlwifi 0000:00:14.3: 0xC008D49C | umac branchlink2
[ 4.652935] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
[ 4.653246] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
[ 4.653564] iwlwifi 0000:00:14.3: 0x00000003 | umac data1
[ 4.653883] iwlwifi 0000:00:14.3: 0x20000302 | umac data2
[ 4.654195] iwlwifi 0000:00:14.3: 0x01300504 | umac data3
[ 4.654505] iwlwifi 0000:00:14.3: 0x00000030 | umac major
[ 4.654812] iwlwifi 0000:00:14.3: 0x954CFF6D | umac minor
[ 4.655143] iwlwifi 0000:00:14.3: 0x00006138 | frame pointer
[ 4.655467] iwlwifi 0000:00:14.3: 0xC0887F58 | stack pointer
[ 4.655755] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[ 4.656089] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 4.656418] iwlwifi 0000:00:14.3: Fseq Registers:
[ 4.656748] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_ERROR_CODE
[ 4.657095] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_TOP_INIT_VERSION
[ 4.657442] iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
[ 4.657791] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 4.658137] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4.658489] iwlwifi 0000:00:14.3: 0xAF57BD77 | FSEQ_ALIVE_TOKEN
[ 4.658845] iwlwifi 0000:00:14.3: 0x01668444 | FSEQ_CNVI_ID
[ 4.659223] iwlwifi 0000:00:14.3: 0x7E33ADBE | FSEQ_CNVR_ID
[ 4.659585] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 4.659942] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[ 4.660334] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.660725] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.661141] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x60a5, CPU2 Status: 0x3
[ 4.661476] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 4.661817] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 4.675446] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 5.018382] Bluetooth: hci0: Waiting for firmware download to complete
[ 5.018866] Bluetooth: hci0: Firmware loaded in 1491834 usecs
[ 5.019286] Bluetooth: hci0: Waiting for device to boot
[ 5.034952] Bluetooth: hci0: Device booted in 15311 usecs
[ 5.035841] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 5.050944] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 5.123924] Adding 928476k swap on /dev/zram0. Priority:-2 extents:1 across:928476k SSFS
[ 5.212321] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.213044] Bluetooth: BNEP filters: protocol multicast
[ 5.213779] Bluetooth: BNEP socket layer initialized
[ 6.535224] Bridge firewalling registered
[ 6.558543] audit: type=1325 audit(1620851680.438:2): table=nat family=2 entries=5
[ 6.560240] audit: type=1325 audit(1620851680.440:3): table=filter family=2 entries=4
[ 6.562737] audit: type=1325 audit(1620851680.442:4): table=filter family=2 entries=6
[ 6.564395] audit: type=1325 audit(1620851680.444:5): table=filter family=2 entries=8
[ 6.566795] audit: type=1325 audit(1620851680.446:6): table=filter family=2 entries=10
[ 6.568417] audit: type=1325 audit(1620851680.448:7): table=filter family=2 entries=11
[ 6.570251] audit: type=1325 audit(1620851680.450:8): table=filter family=2 entries=12
[ 6.580950] Initializing XFRM netlink socket
[ 6.593825] audit: type=1325 audit(1620851680.468:9): table=nat family=2 entries=7
[ 6.595126] audit: type=1325 audit(1620851680.475:10): table=nat family=2 entries=8
[ 6.598895] audit: type=1325 audit(1620851680.478:11): table=filter family=2 entries=12
[ 6.730587] br-825f8367776a: port 1(veth25188f3) entered blocking state
[ 6.731368] br-825f8367776a: port 1(veth25188f3) entered disabled state
[ 6.732755] device veth25188f3 entered promiscuous mode
[ 6.733659] br-825f8367776a: port 1(veth25188f3) entered blocking state
[ 6.734411] br-825f8367776a: port 1(veth25188f3) entered forwarding state
[ 6.735183] IPv6: ADDRCONF(NETDEV_CHANGE): br-825f8367776a: link becomes ready
[ 6.736136] br-825f8367776a: port 1(veth25188f3) entered disabled state
[ 6.762189] br-825f8367776a: port 2(vethafb87f4) entered blocking state
[ 6.762980] br-825f8367776a: port 2(vethafb87f4) entered disabled state
[ 6.763804] device vethafb87f4 entered promiscuous mode
[ 6.764620] br-825f8367776a: port 2(vethafb87f4) entered blocking state
[ 6.765390] br-825f8367776a: port 2(vethafb87f4) entered forwarding state
[ 6.873618] br-825f8367776a: port 3(veth03440f4) entered blocking state
[ 6.874401] br-825f8367776a: port 3(veth03440f4) entered disabled state
[ 6.875472] device veth03440f4 entered promiscuous mode
[ 6.876315] br-825f8367776a: port 3(veth03440f4) entered blocking state
[ 6.877036] br-825f8367776a: port 3(veth03440f4) entered forwarding state
[ 6.885623] supervisor0: port 1(veth9df1ab1) entered blocking state
[ 6.886371] supervisor0: port 1(veth9df1ab1) entered disabled state
[ 6.887150] device veth9df1ab1 entered promiscuous mode
[ 6.887960] supervisor0: port 1(veth9df1ab1) entered blocking state
[ 6.888668] supervisor0: port 1(veth9df1ab1) entered forwarding state
[ 6.889374] IPv6: ADDRCONF(NETDEV_CHANGE): supervisor0: link becomes ready
[ 6.893953] br-825f8367776a: port 2(vethafb87f4) entered disabled state
[ 6.894501] br-825f8367776a: port 3(veth03440f4) entered disabled state
[ 6.895025] supervisor0: port 1(veth9df1ab1) entered disabled state
[ 6.939929] br-825f8367776a: port 4(veth885a1ce) entered blocking state
[ 6.940666] br-825f8367776a: port 4(veth885a1ce) entered disabled state
[ 6.941451] device veth885a1ce entered promiscuous mode
[ 6.942533] br-825f8367776a: port 4(veth885a1ce) entered blocking state
[ 6.943285] br-825f8367776a: port 4(veth885a1ce) entered forwarding state
[ 7.139498] eth0: renamed from veth92fd2ef
[ 7.151768] br-825f8367776a: port 4(veth885a1ce) entered disabled state
[ 7.152591] IPv6: ADDRCONF(NETDEV_CHANGE): veth25188f3: link becomes ready
[ 7.153336] br-825f8367776a: port 1(veth25188f3) entered blocking state
[ 7.153880] br-825f8367776a: port 1(veth25188f3) entered forwarding state
[ 7.323204] eth0: renamed from veth4eec6da
[ 7.330091] IPv6: ADDRCONF(NETDEV_CHANGE): vethafb87f4: link becomes ready
[ 7.330924] br-825f8367776a: port 2(vethafb87f4) entered blocking state
[ 7.331717] br-825f8367776a: port 2(vethafb87f4) entered forwarding state
[ 7.343171] eth0: renamed from veth79a17f8
[ 7.353461] systemd-udevd[28]: Starting version 241
[ 7.354207] eth1: renamed from vethc178f85
[ 7.362100] IPv6: ADDRCONF(NETDEV_CHANGE): veth03440f4: link becomes ready
[ 7.362874] br-825f8367776a: port 3(veth03440f4) entered blocking state
[ 7.363647] br-825f8367776a: port 3(veth03440f4) entered forwarding state
[ 7.364745] IPv6: ADDRCONF(NETDEV_CHANGE): veth9df1ab1: link becomes ready
[ 7.365620] supervisor0: port 1(veth9df1ab1) entered blocking state
[ 7.366458] supervisor0: port 1(veth9df1ab1) entered forwarding state
[ 7.375218] eth0: renamed from veth6afbef7
[ 7.383358] IPv6: ADDRCONF(NETDEV_CHANGE): veth885a1ce: link becomes ready
[ 7.384256] br-825f8367776a: port 4(veth885a1ce) entered blocking state
[ 7.385093] br-825f8367776a: port 4(veth885a1ce) entered forwarding state
[ 7.481891] systemd-udevd[28]: Starting version 241
[ 7.765259] media: loading out-of-tree module taints kernel.
[ 7.774612] media: Linux media interface: v0.10
[ 7.814506] videodev: Linux video capture interface: v2.00
[ 7.840411] systemd-udevd[29]: Starting version 241
[ 7.972163] Eco Capture 0000:01:00.0: enabling device (0000 → 0002)
[ 7.973940] [173: mw_cap_probe]MSI Enabled
[ 7.973967] [179: mw_cap_probe]dma 64 OK!
[ 7.974020] [233:_GetDeviceCapsByProductID]ProductID: 0152, BoardIndex: 00, Instance: 00
[ 8.402548] [373: _init_devices]Init devices successful!
[ 8.521039] [443: _init_devices]i2c init
[ 8.761930] [529: _init_devices]Init devices channel successful!
[ 8.761987] Eco Capture 0000:01:00.0: DMAR: 32bit DMA uses non-identity mapping
[ 8.773263] [868:house_keeping_thread_proc]house keeping thread started
[ 8.773332] Eco Capture: V4L2 device registered as video0
[ 8.775342] [232: mw_cap_probe]Eco Capture capture probe OK!
[ 8.797258] [536: mw_v4l2_stop_generating]entering function mw_v4l2_stop_generating
[ 8.797300] [748: v4l2_sg_queue_streamoff]not streaming
[ 8.830313] [986: _GetSignalStatus]V_LOCKED_RAW == 0
[ 8.889933] [173:video_capture_StartInput]StartInput, Interlaced: 0, Pos: 192, 41, Size: 1920x1080
[ 8.970959] [536: mw_v4l2_stop_generating]entering function mw_v4l2_stop_generating
[ 8.971000] [748: v4l2_sg_queue_streamoff]not streaming
[ 8.988266] [536: mw_v4l2_stop_generating]entering function mw_v4l2_stop_generating
[ 8.988307] [748: v4l2_sg_queue_streamoff]not streaming
[ 9.100026] [536: mw_v4l2_stop_generating]entering function mw_v4l2_stop_generating
[ 9.100053] [748: v4l2_sg_queue_streamoff]not streaming
[ 10.422555] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 11.192039] igc 0000:58:00.0 enp88s0: igc: enp88s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 11.297157] IPv6: ADDRCONF(NETDEV_CHANGE): enp88s0: link becomes ready
Thank you for sharing logs, just letting you know this is still being worked on. We’ll let you know as we have some updates
Thank you for your support!
Please let me know if we can provide you anything further.
We are looking forward to deploying these into our fleet, so whatever we can do we will.
Hi @clawcock sorry for the late reply here, but we have now released proper NUC 11 support, and I have tested both Ethernet and WiFi as functional on my NUC11. Thanks!
