[Build] [main] Step 12/19 : ENV MOD_DIR example_module
[Build] [main] ---> Using cache
[Build] [main] ---> 25ca1d7c7f90
[Build] [main] Step 13/19 : ENV MOD_PATH="$MOD_PATH"
[Build] [main] ---> 7e374e5a855e
[Build] [main] Step 14/19 : COPY --from=kernel-build /usr/src/app/output/ "$MOD_PATH"
Some services failed to build:
main: COPY failed: stat usr/src/app/output/: file does not exist
Additional information may be available with the `--debug` flag.
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
7ser23@Sergio-MP-M2 kernel-module-build-master %
running with --debug does not give any extra help. Was someone successful running the example. I change the OS Variable to the current one and same issue.
I am running a raspberri4 if that helps. Thank you
FROM ubuntu:jammy-20220531 as kernel-build
ARG DEBIAN_FRONTEND=noninteractive
ENV TZ=America/La_Paz
RUN apt-get update && \
apt-get install -y \
awscli \
bc \
bison \
build-essential \
curl \
flex \
git \
libelf-dev \
libssl-dev \
wget
WORKDIR /usr/src/app
# Clones the kernel builder repository
#RUN git clone https://github.com/balena-os/kernel-module-build.git .
# You can switch to a specific commit of the kernel builder if you want to ensure consistent builds
# git reset --hard f889851c5d00890b51b27c63eaa59a976063265a
# Copy your kernel source from your local build context to the build directory
#COPY example_module .
COPY . .
# Set the name of the directory where you have copied your kernel source in the step above
ENV MOD_DIR "example_module"
# Set the balena OS version you intend to use
ENV OS_VERSION '2023.1.0'
# Start the build
#RUN BALENA_MACHINE_NAME=%%BALENA_MACHINE_NAME%% ./build.sh build --device %%BALENA_MACHINE_NAME%% --os-version "$OS_VERSION" --src "$MOD_DIR"
RUN BALENA_MACHINE_NAME=raspberrypi4-64 ./build.sh build --device raspberrypi4-64 --os-version "$OS_VERSION" --src "$MOD_DIR"
#RUN BALENA_MACHINE_NAME=${BALENA_MACHINE_NAME} ./build.sh build --device ${BALENA_MACHINE_NAME} --os-version "$OS_VERSION" --src "$MOD_DIR"
FROM alpine
# Set the directory where you would like your kernel source
ARG MOD_PATH=/etc/output
# Required for access when the container starts
# Copy the built kernel module into your app
COPY --from=kernel-build /usr/src/app/output "$MOD_PATH"
# Copy the startup script for loading the modules
COPY --from=kernel-build /usr/src/app/run.sh /usr/src/app/run.sh
# Start the script that loads the modules.
ENTRYPOINT ["sh", "/usr/src/app/run.sh"]
# Run your usual service with CMD
CMD exec /bin/sh -c "trap : TERM INT; sleep 9999999999d & wait"
