One-to-many kernels modules needs to be build in order support multiple balenaOS versions.
The below example is for usb, but can be changed to support other kernel modules.
Note: Not all modules can be loaded dynamically, see Custom ResinOS and OS update
FROM resin/intel-nuc-buildpack-deps:stretch AS kernelbuilder1
RUN apt-get update && apt-get install -y --no-install-recommends \
bc \
ENV KERNEL_MAJOR_VERSION=v4.x \
KERNEL_VERSION=4.12.12 \
RESIN_OS_VERSION=2.13.6%2Brev1.dev
# tutorial from here: https://wiki.archlinux.org/index.php/Compile_kernel_module
# ideas from here: https://github.com/resin-io-playground/kernel-module-build
RUN cd /usr/src \
&& wget https://mirrors.edge.kernel.org/pub/linux/kernel/${KERNEL_MAJOR_VERSION}/linux-${KERNEL_VERSION}.tar.gz \
&& tar xzf linux-${KERNEL_VERSION}.tar.gz \
&& wget https://files.resin.io/images/intel-nuc/${RESIN_OS_VERSION}/kernel_modules_headers.tar.gz \
&& tar xzf kernel_modules_headers.tar.gz
RUN cd /usr/src \
&& cd linux-${KERNEL_VERSION} \
&& cp ../kernel_modules_headers/.config ../kernel_modules_headers/Module.symvers . \
&& sed -i 's/# CONFIG_USB_XXX is not set/CONFIG_USB_XXX=m/g' .config \
&& make modules_prepare \
&& make M=drivers/usb \
&& make M=drivers/usb modules_install
