Kernel crash after device connecting to my wifi access point
Hey,
I use a BalenaFin with image 2.60.1+rev5. I try to create a wifi access point with my balena Fin. Based with your projects of balena-playground, I am able to create hotspot. When an external device try to connect to hotspot my balenafin crash. You can find kernel log of crash attached.kernel_error_wifi_manager.log (10.2 KB)
Do you have any explications ?
Ben
Hello @benat
Can you please clarify which project it is?
Also, have you tried out wifi-connect(GitHub - balena-os/wifi-connect: Easy WiFi setup for Linux devices from your mobile phone or laptop)?
We have an easy way to add it to a project via the wifi connect block! It allows you to create access points
Hope this is helpful
I try few method to create hotspot wifi. I tried your wifi-connect project and I have the same behavior.
Today I downgraded balenaos version to 2.58.3 (recommended version) and I don’t have kernel crash.
I checked the changelog file of balena-raspberry project but I don’t know what recipe introduce this bug.
Ben
Hi there, it seems as though there is no 2.60.1 OS release for the balena fin, the latest supported OS version for the fin is 2.58.3 (https://www.balena.io/os/#download) - this probably explains why you were having problems before, glad to know the problem is solved.
