Jetson orin nano eMMC : UART /dev/ttyTHS1 not working
I can’t use the UART /dev/ttyTHS1 correctly. I tried with a GPS or a Bluetooth over UART. Everything is working as expected when I don’t use a balena based Host but doesn’t work with Balena.
I talk about using pin 8 and 10
I know there is this link Jetson Nano UART (/dev/ttyTHS1) not working but it doesn’t provide any solution.
I use OS version 6.4.0
For example, with Bluetooth, I have the following issue in dmesg : [ 184.829759] Bluetooth: hci0: command 0x1009 tx timeout
when using Balena, here is the output of dmesg | grep serial
[    0.184621] usbcore: registered new interface driver usbserial_generic
[    0.184641] usbserial: USB Serial support registered for generic
[    3.597651] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.598640] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
And here is the output when using Jetpack (so when it works) :
[    3.376154] serial-tegra 3100000.serial: RX in PIO mode
[    3.376158] serial-tegra 3100000.serial: TX in PIO mode
[    3.376220] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.376696] serial-tegra 3140000.serial: RX in PIO mode
[    3.376701] serial-tegra 3140000.serial: TX in PIO mode
[    3.376739] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
Any idea on this one ?
I found something really interesting !
  • I have connected RX to TX (loopback) so pin 8 to 10.
  • I open one terminal : echo "placeholder" > /dev/ttyTHS1
  • I open another terminal : cat -v /dev/ttyTHS1
What I receive is : ^@^@^@^@^@^@^@^@der so seems like first characters are truncated. Here is what I see in dmesg :
[  715.007379] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0x60011, cbfrsynra=0xc04, cb=0
[  715.009643] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[  715.009658] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: Route Sanity error ((null))
[  716.806316] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x802fc000, fsynr=0x1d0011, cbfrsynra=0x404, cb=0
[  716.806403] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[  716.806410] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: Route Sanity error ((null))
If I send a smaller message like echo "test" > /dev/ttyTHS1, I don’t run into any issue (cat returns “test” aswell and I don’t see anything in dmesg.
If anyone understands why this issue occurs…
Hello @avanmalleghem could you please confirm what board are you using? Is this the devkit?
In the meantime, a colleague pointed to me that you have a similar issue than here @avanmalleghem
Feel free to share more details of your device tree so we can help you more!
Yes it is on the devkit !
I tried to rebuild the DTB by removing the lines related to dma and it solves the issue !
Thanks for the link.
Awesome @avanmalleghem thanks for sharing!
In my case, I use Balena’s feature to overwrite the DTB through the device configuration, changing it to tegra234-p3768-0000+p3767-0005-nv-super-ths1-no-dma.dtb.
However, I still have an issue with the Jetson’s TX line when it is connected to an Orange Cube Autopilot. I found that it works correctly when I add a 20 kΩ pull-down resistor on this pin, and after that, it works like a charm.
