Is pandas library in pyhton supported by Balena ?
I’m trying to install pandas to use some function in a pyhton code but I encounter some difficuties to install it. I tried to put it in requirements.txt and I also tried directly from DockerFile via pip install pandas but both are not working. I’m wondering if pandas is available on balena. (btw I’m using python 3 stretch image)
Thank you for your help !
Hugo
Hello @Hugo thanks for your question!
Is there any restriction why you are using the python 3 stretch image? did you try with other images with python? what error do you get?
Thanks @HughCalum for your message and welcome to the balena community!
@Hugo did you solve your problem using the Panda library?
Indeed I solved it partially. There is a way to implement it via Dockerfile as shown here:
FROM python:3
RUN apt-get update && apt-get install -y --no-install-recommends
build-essential
python-dev
WORKDIR /usr/src/app
RUN pip install --no-cache-dir flask pandas
COPY . ./
ENV UDEV=1
CMD [“python”, “-u”, “app.py”]
But the thing is that I want to stay on python stretch and I want to use sudo command in my python code(and the compilation is 20 min this way). When I try to upload via requirements it did not work . I have this error : ERROR: Could not find a version that satisfies the requirement pandas==2.0.2. I tried different version and it didn’t work . Indeed I aslo want to upload numpy library and it didn’t work too seems that PEP 517 is not working I have this error when I put numpy in requirements: ERROR: Could not build wheels for numpy which use PEP 517 and cannot be installed directly / ERROR: Failed building wheel for numpy.
Is someone having the same issue ? I’m still stuck on it.
BR,
Hugo
