iptables rules set from Tailscale are overwritten by Balena?
If someone else has the same or similar issue, our workaround is to let Tailscale start last and use a sleep time before starting it. This seems to work consistently.
  tailscale:
    image: tailscale-image
    # Tailscale needs to start delayed to be able to fix iptables after Balena has booted.
    command: sh -c "
      sleep 30;
      if [ -z $TAILSCALE_KEY ]; then
        echo 'Set TAILSCALE_KEY to activate.';
        sleep infinity;
      else
        (sleep 10 &&
          tailscale up --accept-routes --advertise-routes=$TAILSCALE_SUBNETS --authkey=$TAILSCALE_KEY --hostname=$BALENA_DEVICE_NAME_AT_INIT
        ) & tailscaled --state /data/tailscaled.state;
      fi"
    restart: always
    network_mode: host
    # The hope is that balena made the changes after all servics started, including this one,
    # and with the 30s delay the tailscale stuff gets applied last consistently.
    depends_on:
      - everyOtherContainer
    privileged: true
    cap_add:
      - NET_ADMIN
    volumes:
      - 'data-volume:/data'
    devices:
      - /dev/net/tun:/dev/net/tun
