IOT2000 Intel AC3160 WiFi module compatibility
Hi!
We are testing resin.io on a Siemens IOT2040 that we have previously used with the example image (v 2.1.3) from Siemens.
On the device we have installed the Intel AC3160 WiFi module on the mini PCI-Express slot, that was correctly running with standard os (plug & play), but with the resin os is not recognised and then is not usable.
Is it a driver issue?
Thanks for the support.
hey @aleph.solutions, yeah this sounds like the resinOS image for the IoT2000 just doesn’t have the driver enabled in the kernel. I am sure @telphan or @floion can get it added if you raise an issue on https://github.com/resin-os/resin-iot2000
Thank you @shaunmulligan!
