Does the dashboard need to be running for the quote to change?
No. The device only tries to load a quote from the API once and if that fails you get the ‘sorry folks’ message until the following day when it will try again.
Though that was the idea.
It was Ok at 14:00
23.10.20 14:00:14 (+0100) main INFO:root:Display type: InkyPHAT_SSD1608
23.10.20 14:00:14 (+0100) main INFO:root:Display dimensions: W 250 x H 122
23.10.20 14:00:15 (+0100) main INFO:root:Message: Duct tape is like the force. It has a light side, a dark side, and it holds the universe together.
23.10.20 14:00:15 (+0100) main INFO:root:Font size: 8
23.10.20 14:00:18 (+0100) main INFO:root:Done drawing
I’ll keep an eye on it.
Thank you.
instead of an inkyphat display I’m using one from Waveshare - would that make a difference in my ability to display?
Getting the error:
inkyshot Traceback (most recent call last):
inkyshot File “/usr/app/update-display.py”, line 302, in
inkyshot display = inky.auto()
inkyshot File “/usr/local/lib/python3.7/site-packages/inky/auto.py”, line 66, in auto
inkyshot raise RuntimeError(“No EEPROM detected! You must manually initialise your Inky board.”)
inkyshot RuntimeError: No EEPROM detected! You must manually initialise your Inky board.
Any thoughts from the community would be amazing! Thanks
