I’m trying to make Edison work with the Arduino Breakout board + Grove adapter + Grove-LCD RGB Backlight board. The LCD works as an I2C device, and it’s one of the examples in Edison’s mraa code.
I can’t make that work, seems like the i2c-designware-pci module crashes (see log below). Not sure if it’s a resin system’s problem, I basically use the same hardware as in this instructable (software is pretty much the same just using Intel’s own image, instead of resin’s).
Here’s the repo of the resin docker used.
The error message I get:
terminate called after throwing an instance of 'std::runtime_error'
what(): upm::Jhd1313m1::Jhd1313m1(int, int, int): Unable to initialise the LCD controller
Aborted
The kernel log from dmesg:
[ 47.155146] ------------[ cut here ]------------
[ 47.155194] WARNING: at /var/lib/yocto/edison/build/production/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f0
49a_c03195ed6e-r0/linux/drivers/i2c/busses/i2c-designware-core.c:1236 i2c_dw_xfer+0x1d2/0x5b0()
[ 47.155212] Device: i2c-designware-pci
controller timed out
[ 47.155228] Modules linked in: xt_connmark iptable_mangle usb_f_acm u_serial g_multi libcomposite bcm_bt_lpm bcm4334x(O)
[ 47.155302] CPU: 0 PID: 596 Comm: python Tainted: G W O 3.10.17-yocto-standard #1
[ 47.155317] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
[ 47.155332] f36a9d58 f36a9d58 f36a9d20 c1958c77 f36a9d48 c123e92e c1bf5700 f36a9d74
[ 47.155390] 000004d4 c16cac62 c16cac62 f5c3d800 f36a9e18 f5c3d824 f36a9d60 c123e983
[ 47.155445] 00000009 f36a9d58 c1bf5700 f36a9d74 f36a9d94 c16cac62 c1bf5724 000004d4
[ 47.155502] Call Trace:
[ 47.155538] [<c1958c77>] dump_stack+0x16/0x18
[ 47.155569] [<c123e92e>] warn_slowpath_common+0x5e/0x80
[ 47.155597] [<c16cac62>] ? i2c_dw_xfer+0x1d2/0x5b0
[ 47.155623] [<c16cac62>] ? i2c_dw_xfer+0x1d2/0x5b0
[ 47.155650] [<c123e983>] warn_slowpath_fmt+0x33/0x40
[ 47.155677] [<c16cac62>] i2c_dw_xfer+0x1d2/0x5b0
[ 47.155706] [<c16c5095>] __i2c_transfer+0x55/0x70
[ 47.155733] [<c16c5e7d>] i2c_transfer+0x4d/0xc0
[ 47.155760] [<c16c61b2>] i2c_smbus_xfer+0x222/0x5d0
[ 47.155792] [<c126c13b>] ? update_rq_clock.part.74+0x12b/0x150
[ 47.155825] [<c12c6491>] ? tracing_is_on+0x11/0x30
[ 47.155855] [<c1565b82>] ? _copy_from_user+0x42/0x60
[ 47.155882] [<c16c7ce8>] i2cdev_ioctl_smbus+0x148/0x280
[ 47.155912] [<c1961825>] ? sub_preempt_count+0x55/0xe0
[ 47.155939] [<c195dff5>] ? _raw_spin_lock_irqsave+0x25/0x30
[ 47.155966] [<c16c81d9>] i2cdev_ioctl+0x49/0x1e0
[ 47.155993] [<c12636f7>] ? hrtimer_try_to_cancel+0x37/0xf0
[ 47.156022] [<c16c8190>] ? i2cdev_ioctl_rdrw.isra.7+0x210/0x210
[ 47.156049] [<c132b376>] do_vfs_ioctl+0x2f6/0x540
[ 47.156078] [<c150a5fa>] ? inode_has_perm.isra.41.constprop.78+0x3a/0x50
[ 47.156105] [<c150a697>] ? file_has_perm+0x87/0x90
[ 47.156134] [<c1263200>] ? hrtimer_get_res+0x40/0x40
[ 47.156161] [<c150aa5c>] ? selinux_file_ioctl+0x4c/0xf0
[ 47.156187] [<c132b620>] SyS_ioctl+0x60/0x80
[ 47.156216] [<c195e738>] syscall_call+0x7/0xb
[ 47.156237] ---[ end trace d74811bc5a47ec94 ]---
[ 47.156259] i2c-designware-pci 0000:00:09.1: ===== REGISTER DUMP (i2c) =====
[ 47.156339] i2c-designware-pci 0000:00:09.1: DW_IC_CON: 0x65
[ 47.156412] i2c-designware-pci 0000:00:09.1: DW_IC_TAR: 0x3e
[ 47.156484] i2c-designware-pci 0000:00:09.1: DW_IC_SS_SCL_HCNT: 0x2f8
[ 47.156556] i2c-designware-pci 0000:00:09.1: DW_IC_SS_SCL_LCNT: 0x37b
[ 47.156628] i2c-designware-pci 0000:00:09.1: DW_IC_FS_SCL_HCNT: 0x87
[ 47.156700] i2c-designware-pci 0000:00:09.1: DW_IC_FS_SCL_LCNT: 0x10a
[ 47.156772] i2c-designware-pci 0000:00:09.1: DW_IC_INTR_STAT: 0x0
[ 47.156842] i2c-designware-pci 0000:00:09.1: DW_IC_INTR_MASK: 0x246
[ 47.156914] i2c-designware-pci 0000:00:09.1: DW_IC_RAW_INTR_STAT: 0x10
[ 47.156986] i2c-designware-pci 0000:00:09.1: DW_IC_RX_TL: 0x20
[ 47.157057] i2c-designware-pci 0000:00:09.1: DW_IC_TX_TL: 0x20
[ 47.157128] i2c-designware-pci 0000:00:09.1: DW_IC_ENABLE: 0x1
[ 47.157198] i2c-designware-pci 0000:00:09.1: DW_IC_STATUS: 0x2
[ 47.157268] i2c-designware-pci 0000:00:09.1: DW_IC_TXFLR: 0x2
[ 47.157339] i2c-designware-pci 0000:00:09.1: DW_IC_RXFLR: 0x0
[ 47.157409] i2c-designware-pci 0000:00:09.1: DW_IC_TX_ABRT_SOURCE: 0x0
[ 47.157479] i2c-designware-pci 0000:00:09.1: DW_IC_DATA_CMD: 0x0
[ 47.157549] i2c-designware-pci 0000:00:09.1: ===============================
[ 47.157616] sending NMI to all CPUs:
[ 47.157639] NMI backtrace for cpu 0
[ 47.157651] CPU: 0 PID: 596 Comm: python Tainted: G W O 3.10.17-yocto-standard #1
[ 47.157656] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
[ 47.157663] task: f5db26f0 ti: f36a8000 task.ti: f36a8000
[ 47.157671] EIP: 0060:[<c12213bb>] EFLAGS: 00000206 CPU: 0
[ 47.157684] EIP is at default_send_IPI_mask_logical+0x8b/0xd0
[ 47.157691] EAX: 00000000 EBX: 03000000 ECX: c1c88660 EDX: fffff000
[ 47.157697] ESI: 00000206 EDI: 00000002 EBP: f36a9d44 ESP: f36a9d34
[ 47.157704] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 47.157711] CR0: 8005003b CR2: b6e8b000 CR3: 31559000 CR4: 001007f0
[ 47.157717] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 47.157721] DR6: ffff0ff0 DR7: 00000400
[ 47.157724] Stack:
[ 47.157747] 00000800 00002710 f36a9e18 f5c3d824 f36a9d50 c12214d0 00002710 f36a9d60
[ 47.157767] c122163c c1b67531 f5c3d800 f36a9d94 c16caeca f64eb864 c1b8a18c 00000000
[ 47.157787] c1bccdb3 00000000 f5c3d898 00000001 00000000 f5c3d898 00000000 c1cd1b88
[ 47.157790] Call Trace:
[ 47.157807] [<c12214d0>] default_send_IPI_all+0x60/0x70
[ 47.157821] [<c122163c>] arch_trigger_all_cpu_backtrace+0x4c/0x80
[ 47.157835] [<c16caeca>] i2c_dw_xfer+0x43a/0x5b0
[ 47.157849] [<c16c5095>] __i2c_transfer+0x55/0x70
[ 47.157862] [<c16c5e7d>] i2c_transfer+0x4d/0xc0
[ 47.157875] [<c16c61b2>] i2c_smbus_xfer+0x222/0x5d0
[ 47.157892] [<c126c13b>] ? update_rq_clock.part.74+0x12b/0x150
[ 47.157910] [<c12c6491>] ? tracing_is_on+0x11/0x30
[ 47.157924] [<c1565b82>] ? _copy_from_user+0x42/0x60
[ 47.157938] [<c16c7ce8>] i2cdev_ioctl_smbus+0x148/0x280
[ 47.157952] [<c1961825>] ? sub_preempt_count+0x55/0xe0
[ 47.157965] [<c195dff5>] ? _raw_spin_lock_irqsave+0x25/0x30
[ 47.157979] [<c16c81d9>] i2cdev_ioctl+0x49/0x1e0
[ 47.157992] [<c12636f7>] ? hrtimer_try_to_cancel+0x37/0xf0
[ 47.158007] [<c16c8190>] ? i2cdev_ioctl_rdrw.isra.7+0x210/0x210
[ 47.158019] [<c132b376>] do_vfs_ioctl+0x2f6/0x540
[ 47.158033] [<c150a5fa>] ? inode_has_perm.isra.41.constprop.78+0x3a/0x50
[ 47.158047] [<c150a697>] ? file_has_perm+0x87/0x90
[ 47.158061] [<c1263200>] ? hrtimer_get_res+0x40/0x40
[ 47.158075] [<c150aa5c>] ? selinux_file_ioctl+0x4c/0xf0
[ 47.158087] [<c132b620>] SyS_ioctl+0x60/0x80
[ 47.158102] [<c195e738>] syscall_call+0x7/0xb
[ 47.158222] Code: b3 ff ff 89 f8 09 d0 80 ce 04 83 ff 02 0f 44 c2 8b 15 54 8b c8 c1 89 82 00 b3 ff ff f7 c6 00 02 00 00 74 1
4 e8 d7 03 0b 00 56 9d <83> c4 04 5b 5e 5f 5d c3 90 8d 74 26 00 56 9d e8 c1 ff 0a 00 83
[ 47.158232] NMI backtrace for cpu 1
[ 47.158247] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W O 3.10.17-yocto-standard #1
[ 47.158252] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 466 2014.06.23:19.20.05
[ 47.158260] task: f6c8bd30 ti: f6e22000 task.ti: f6e22000
[ 47.158269] EIP: 0060:[<c15ae58e>] EFLAGS: 00200046 CPU: 1
[ 47.158281] EIP is at intel_idle+0x8e/0xe0
[ 47.158288] EAX: 00000052 EBX: 00000040 ECX: 00000001 EDX: 00000000
[ 47.158294] ESI: 00000052 EDI: c1cc0a08 EBP: f6e23f30 ESP: f6e23f18
[ 47.158301] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 47.158308] CR0: 8005003b CR2: b7251000 CR3: 01dcc000 CR4: 001007f0
[ 47.158314] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 47.158318] DR6: ffff0ff0 DR7: 00000400
[ 47.158321] Stack:
[ 47.158343] 00000006 00000002 00000001 c1cc0960 f7402400 c1cc0a08 f6e23f54 c16f7dd1
[ 47.158364] 00000002 000002df f64ae593 0000000a f6e22000 c1cc0960 00000098 f6e23f74
[ 47.158383] c16f7f12 c1cc0960 00000001 f7402400 f6e22000 00000000 00000000 f6e23f7c
[ 47.158386] Call Trace:
[ 47.158408] [<c16f7dd1>] cpuidle_enter_state+0x31/0xd0
[ 47.158425] [<c16f7f12>] cpuidle_idle_call+0xa2/0x220
[ 47.158441] [<c120821d>] arch_cpu_idle+0xd/0x30
[ 47.158454] [<c12846b5>] cpu_startup_entry+0x65/0x200
[ 47.158469] [<c194e6a7>] start_secondary+0x230/0x235
[ 47.158590] Code: 8b 42 08 a8 08 75 24 31 c9 8d 42 08 89 ca 0f 01 c8 0f ae f0 89 f6 89 e0 25 00 e0 ff ff 8b 40 08 a8 08 75 0
7 b1 01 89 f0 0f 01 c9 <85> 1d 58 09 cc c1 75 0d 8d 55 f0 b8 05 00 00 00 e8 5d e0 cd ff
[ 47.159232] i2c-6: recovery ignore
Any suggestions?
