Can't get I2C to work on raspberry pi zero 2
I’m trying to make I2C work in a node image on the Raspberry PI zero 2 but I get the following error:
root@430725c5441d:~# modprobe i2c-dev
modprobe: FATAL: Module i2c-dev not found in directory /lib/modules/5.10.78-v8
Any tips on how to make it work ?
thanks !
I got it to work by adding a label in my docker-compose:
labels:
  io.balena.features.kernel-modules: '1'
Perhaps this should be more clear in the documentation ?
Hello @natcl thank you for your message and posting the solution!
I will check the docs and try to improve it in order to reduce friction to the developers!
Let me know if we can help you more!
Thanks !
On this page, it would help a lot:
Agreed. I lost a day troubleshooting this one.
