I have set up my Balena Minecraft Server from the blog, and under edit files is written: The files are in the folder named “serverfiles” at the root directory. but ther is no serverfiles map under root.
Hi Jereon
Can you share the configuration you used to connect to the SCP server?
Hi Jeroen,
It looks like those files are actually located at the root of the filesystem, with the path /serverfiles, instead of /root/serverfiles. Let me know if you can’t find them there.
