Os --version 5.0.1.prod
I had to back to previous version because the current version was not detecting either of the two modems
lsusb
Bus 001 Device 005: ID 3566:2001 Mobile Mobile
Bus 001 Device 004: ID 3566:2001 Mobile Mobile
root@3ad3f10:~# dmesg | grep -i usb
[ 0.181028] usbcore: registered new interface driver usbfs
[ 0.181117] usbcore: registered new interface driver hub
[ 0.181203] usbcore: registered new device driver usb
[ 0.181647] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.181916] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.551781] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.553581] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.553618] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.554099] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.554131] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.554155] usb usb1: Product: xHCI Host Controller
[ 0.554176] usb usb1: Manufacturer: Linux 5.15.92-v8 xhci-hcd
[ 0.554197] usb usb1: SerialNumber: 0000:01:00.0
[ 0.555128] hub 1-0:1.0: USB hub found
[ 0.556640] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.556673] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.556698] usb usb2: Product: xHCI Host Controller
[ 0.556719] usb usb2: Manufacturer: Linux 5.15.92-v8 xhci-hcd
[ 0.556740] usb usb2: SerialNumber: 0000:01:00.0
[ 0.557622] hub 2-0:1.0: USB hub found
[ 0.561055] usbcore: registered new interface driver uas
[ 0.561179] usbcore: registered new interface driver usb-storage
[ 0.561326] usbcore: registered new interface driver usbserial_generic
[ 0.561374] usbserial: USB Serial support registered for generic
[ 0.573759] usbcore: registered new interface driver usbhid
[ 0.573768] usbhid: USB HID core driver
[ 0.808456] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.958979] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.959012] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.959026] usb 1-1: Product: USB2.0 Hub
[ 0.960684] hub 1-1:1.0: USB hub found
[ 1.256396] usb 1-1.4: new high-speed USB device number 3 using xhci_hcd
[ 1.372179] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.01
[ 1.372209] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.372220] usb 1-1.4: Product: USB2.1 Hub
[ 1.372230] usb 1-1.4: Manufacturer: Generic
[ 1.374427] hub 1-1.4:1.0: USB hub found
[ 1.672414] usb 1-1.4.1: new high-speed USB device number 4 using xhci_hcd
[ 1.775550] usb 1-1.4.1: New USB device found, idVendor=3566, idProduct=2001, bcdDevice=ff.ff
[ 1.775580] usb 1-1.4.1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1.775593] usb 1-1.4.1: Product: Mobile
[ 1.775604] usb 1-1.4.1: Manufacturer: Mobile
[ 1.775615] usb 1-1.4.1: SerialNumber: 123456789ABCD
[ 1.778739] usb-storage 1-1.4.1:1.0: USB Mass Storage device detected
[ 1.779506] scsi host0: usb-storage 1-1.4.1:1.0
[ 1.860455] usb 1-1.4.3: new high-speed USB device number 5 using xhci_hcd
[ 1.963089] usb 1-1.4.3: New USB device found, idVendor=3566, idProduct=2001, bcdDevice= 1.02
[ 1.963121] usb 1-1.4.3: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1.963132] usb 1-1.4.3: Product: Mobile
[ 1.963142] usb 1-1.4.3: Manufacturer: Mobile
[ 1.963151] usb 1-1.4.3: SerialNumber: 123456789ABCD
[ 2.052385] usb 1-1.4.4: new high-speed USB device number 6 using xhci_hcd
[ 2.163764] usb 1-1.4.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.01
[ 2.163809] usb 1-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.163827] usb 1-1.4.4: Product: USB2.1 Hub
[ 2.163843] usb 1-1.4.4: Manufacturer: Generic
[ 2.166746] hub 1-1.4.4:1.0: USB hub found
[ 8.298126] usbcore: registered new interface driver cdc_ether
[ 8.323978] rndis_host 1-1.4.3:1.0 usb0: register 'rndis_host' at usb-0000:01:00.0-1.4.3, RNDIS device, aa:3d:2a:2f:92:38
[ 8.324172] usbcore: registered new interface driver rndis_host
[ 8.363427] usbcore: registered new interface driver brcmfmac
[ 8.694637] rndis_host 1-1.4.3:1.0 enp1s0u1u4u3: renamed from usb0
One defaults to storage and one defaults into cdc_ether
But when I plug each on the laptop they work both fine
