How to source a environment when connecting remotely?
Hello guys!
From time to time, I open a remote terminal from the resin dashboard. I need to run some commands that only work after I executed this two lines:
source /opt/ros/kinetic/setup.bash
source /catkin_ws/devel/setup.bash
But I don’t want to run this two lines every time I open a terminal. Is there a way to execute them automatically?
Hey @hecontreraso,
I haven’t tested this yet, but you should just be able to put them in ~/.bash_profile? Then when you ssh into the container it should login and run the set up scripts.
It worked in .bashrc
thanks (:
