How to pin a device to release from Github Actions?
Is there a way to use a token from Github Actions to dynamically pin a device to a release?
This is useful for automating testing through a balena virtual machine.
It is available through Balena CLI it seems…
You could do it by using the Balena CLI on GitHub actions. Either by using an action such as…
Or you could just manually install it as part of the action in a previous step…
Thanks @shawaj! Yea, I already rely heavily on Github Actions for working with Balena, You can see my workflows here: edt-offline/.github at main Ā· digidem/edt-offline Ā· GitHub
Unfortunately is seems we’re only able to pin entire fleets, not single devices through the Balena cli.
@luandro as I understand it, you can do individual devices as well. It’s just not documented in the balena documentation.
But I believe if you use the Balena CLI help function it shows as available there
@shawaj doesn’t seem like it. Not even fleet pin is documented on cli’s help. My intuition says it should be something like: balena device <uid> pin <release>
Any other commands I should try to see if this exists?
I’ve created an issue for this.
So it looks like the command is balena device pin <uuid> [releaseToPinTo]
See here full output of balena help --verbose:
% balena help --verbose
USAGE
$ balena [COMMAND] [OPTIONS]
PRIMARY COMMANDS
  login                                  login to balena
  push <fleetOrDevice>                   build release images on balenaCloud servers or on a local mode device
  logs <device>                          show device logs
  ssh <fleetOrDevice> [service]          open a SSH prompt on a device's host OS or service container
  fleets                                 list all fleets
  fleet <fleet>                          display information about a single fleet
  devices                                list all devices
  device <uuid>                          show info about a single device
  tunnel <deviceOrFleet>                 tunnel local ports to your balenaOS device
  preload <image>                        preload a release on a disk image (or Edison zip archive)
  build [source]                         build a project locally
  deploy <fleet> [image]                 deploy a single image or a multicontainer project to a balena fleet
  join [deviceIpOrHostname]              move a local device to a fleet on another balena server
  leave [deviceIpOrHostname]             remove a local device from its balena fleet
  scan                                   scan for balenaOS devices on your local network
ADDITIONAL COMMANDS
  api-key generate <name>                generate a new balenaCloud API key
  config generate                        generate a config.json file
  config inject <file>                   inject a config.json file to a balenaOS image or attached media
  config read                            read the config.json file of a balenaOS image or attached media
  config reconfigure                     interactively reconfigure a balenaOS image file or attached media
  config write <key> <value>             write a key-value pair to the config.json file of an OS image or attached media
  device deactivate <uuid>               deactivate a device
  device identify <uuid>                 identify a device
  device init                            initialize a device with balenaOS
  device local-mode <uuid>               get or manage the local mode status for a device
  device move <uuid(s)>                  move one or more devices to another fleet
  device os-update <uuid>                start a Host OS update for a device
  device pin <uuid> [releaseToPinTo]     pin a device to a release
  device public-url <uuid>               get or manage the public URL for a device
  device purge <uuid>                    purge data from a device
  device reboot <uuid>                   restart a device
  device register <fleet>                register a new device
  device rename <uuid> [newName]         rename a device
  device restart <uuid>                  restart containers on a device
  device rm <uuid(s)>                    remove one or more devices
  device shutdown <uuid>                 shutdown a device
  device track-fleet <uuid>              make a device track the fleet's pinned release
  devices supported                      list the supported device types (like 'raspberrypi3' or 'intel-nuc')
  env add <name> [value]                 add env or config variable to fleets, devices or services
  env rename <id> <value>                change the value of a config or env var for a fleet, device or service
  env rm <id>                            remove a config or env var from a fleet, device or service
  envs                                   list the environment or config variables of a fleet, device or service
  fleet create <name>                    create a fleet
  fleet pin <slug> [releaseToPinTo]      pin a fleet to a release
  fleet purge <fleet>                    purge data from a fleet
  fleet rename <fleet> [newName]         rename a fleet
  fleet restart <fleet>                  restart a fleet
  fleet rm <fleet>                       remove a fleet
  fleet track-latest <slug>              make this fleet track the latest release
  key <id>                               display an SSH key
  key add <name> [path]                  add an SSH key to balenaCloud
  key rm <id>                            remove an SSH key from balenaCloud
  keys                                   list the SSH keys in balenaCloud
  local configure <target>               (Re)configure a balenaOS drive or image
  local flash <image>                    flash an image to a drive
  logout                                 logout from balena
  note <|note>                           set a device note
  orgs                                   list all organizations
  os build-config <image> <device-type>  prepare a configuration file for use by the 'os configure' command
  os configure <image>                   configure a previously downloaded balenaOS image
  os download <type>                     download an unconfigured OS image
  os initialize <image>                  initialize an os image for a device
  os versions <type>                     show available balenaOS versions for the given device type
  release <commitOrId>                   get info for a release
  release finalize <commitOrId>          finalize a release
  release invalidate <commitOrId>        invalidate a release
  release validate <commitOrId>          validate a release
  releases <fleet>                       list all releases of a fleet
  settings                               print current settings
  support <action>                       grant or revoke support access for devices or fleets
  tag rm <tagKey>                        remove a tag from a fleet, device or release
  tag set <tagKey> [value]               set a tag on a fleet, device or release
  tags                                   list all tags for a fleet, device or release
  util available-drives                  list available drives
  version                                display version information for the balena CLI and/or Node.js
  whoami                                 display account information for current user
GLOBAL OPTIONS
  --help, -h                             display command help
  --debug                                enable debug output
  --unsupported                          prevent exit with an error as per Deprecation Policy
                                         See: https://git.io/JRHUW#deprecation-policy
Deprecation Policy Reminder
The balena CLI enforces its deprecation policy by exiting with an error a year
after the release of the next major version, unless the --unsupported option is
used. Find out more at: https://git.io/JRHUW#deprecation-policy
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
Perfect, thanks @shawaj!
No probs :raised_hands:
