How to make bootable pendrive for windows 10 from iso file using rufus?
Hello, These resources might help you:
Run the Rufus application and select the OS file and USB drive in which you want to flash the OS. After that Rufus will flash the OS easily.
Although you can also use the alternative of Rufus, that is Etcher, It is fast and more reliable. For more information about etcher, you can go through this link https://etcherpc.com/
