to lower the entry barrier for others and for me as a reminder, here are my steps to get belena cli operational in Windows Subsystem for Linux 2.
It can probably also be used under Linux (in a VM), but since I have full access to WSL2’s file system (Microsoft, Stack Overflow), I finally decided to go for it because it saves me some problems.
At least that’s what I thought in the beginning.
PREPERATION
Before you start, follow Ask Ubuntu and put Root CA in
/usr/local/share/ca-certificates/<subfolder if you like>
and run
sudo update-ca-certificates
If you certificate is .cer you convert it into pem/cer as explained on Stack Overflow:
First you need to figure out if it is either in either in der or pem encoding by echoing its content and see if it is shows a endless string, as described in the answer of eis, depend on the result you do one of the following
openssl x509 -inform der -in certnew.cer -out ymcert.pem
openssl x509 -inform der -in certnew.cer -out ymcert.crt
openssl x509 -in certnew.cer -out ymcert.pem
openssl x509 -in certnew.cer -out ymcert.crt
This will avoid that you get
$ nvm ls-remote
N/A
as described in node.js - NVM on WSL2: cannot install Node, version not found - Stack Overflow
INSTALL
Step
npm
Than start following NPM Installation, balena CLI Advanced Installation Options
(github.com) (in short: Install balena-cli on windows 10 wsl (github.com)) -
Step
cli
But before you do the actual install ofbalena-cli, after you installednpmby doing
$ npm install balena-cli --global --production --unsafe-perm
you have to run one of:
$ export NODE_EXTRA_CA_CERTS="/usr/local/share/ca-certificates/Zscaler/Zscaler Root CA.crt"
$ export NODE_EXTRA_CA_CERTS="/usr/local/share/ca-certificates/Zscaler/Zscaler Root CA.pem"
otherwise you run into gyp ERR! stack Error: unable to get local issuer certificate · Issue #979 · nodejs/help (github.com) -
Step
sudo configuration
as theclipath is not as given as in balena-cli/INSTALL-LINUX.md at master · balena-io/balena-cli (github.com). It is rather like/home/<user>/.nvm/versions/node/v12.22.9/bin/
Do learn the right path you can do$ whereis balena.
how to use balena scan ???
so balena cli does run in WSL2 but story has to be continued as balean scan will fail as WSL2 is NAT’d through an Hyper-V Ethernet Adapter, so it won’t reach the clients on the same network as on the host out-of-the-box.
the www is full of discussion, see here my reads
- windows 10 WSL ubuntu unable to ping anything - Super User
- Easiest WSL2 Bridge Network (without Hyper-V Virtual Network Manager) – Developer Monkey (develmonk.com)
- [WSL 2] NIC Bridge mode 🖧 (Has TCP Workaround🔨) · Issue #4150 · microsoft/WSL (github.com)
- Accessing network applications with WSL | Microsoft Docs
- windows subsystem for linux - WSL2 network unreachable - Stack Overflow
- ruby on rails - Connecting to WSL2 server via local network - Stack Overflow
Currently I cannot tell if I can spare the time for another trail&error approach to get it working.
MISCELLANEOUS
do you wonder what curl -o- means, see bash - Unclear curl command -o- - Stack Overflow
first time configuring the linux Sudoers file, as me?
- what is this: How To Use visudo (unixtutorial.org)
- why
nano (vi)ask me to save it assudoers.tmp: linux mint - How can I add lines into my sudoers file? - Unix & Linux Stack Exchange - Configuring the linux Sudoers file - Linux.com
- Linux visudo command help and examples (computerhope.com)
Do you think, you created but don't know how to uninstall, see here
As I don't have all mind, my resource used
- A quick reference list of vi editor commands (iu.edu)
- Unix / Linux Print Environment Variables Command - nixCraft (cyberciti.biz)
- Refresher of
$PATHon linux: wikiHow, Super User, Stack Overflow - don’t forget
:or"or unintended asspacebash - How to fix “not a valid identifier” error after setting environment variables? - Ask Ubuntu
