im trying to send my balenafin to sleep using the integrated rtc ds1307, i followed this post after enabling the rtc i can successfully see it on the x68 address on bus 3 using i2cdetect with status UU, but when i try to run rtcwake i get the following error:
$ sudo rtcwake -s 10
rtcwake: cannot open /sys/class/rtc/rtc0/device/power/power/wakeup: No such file or directory
rtcwake: /dev/rtc0 not enabled for wakeup events
running cat /proc/driver/rtc gives me no errors and returns me the correct rtc time, using sudo hwclock -w or -r i can successfully interact with the rtc too
adding dtoverlay=i2c-rtc,ds1307,wakeup-source to /boot/config.txt doesn’t fix the issue either.
Can you provide a -mode option to rtcwake and try this again? If that doesn’t work let’s check whether wakeup-alarm are actually working. Try a manual sleep timer via something like:
sudo sh -c ‘echo "+00-00-00 00:00:10" > /sys/class/rtc/rtc0/wakealarm'
Note: You would need to put the fin manually to sleep for this to work. If that is working then rtc should be fine.
supplying a mode to the rtcwake with rtcwake -m mem -s 10 gives a syntax error for some reason, im using raspbian v0.1.0 dowloaded from the official balenafin website
Now regarding the manual sleep, i dont have the wakealarm file in /sys/class/rtc/rtc0/
so i can’t even do it manually
