I have some coral devices running balenaOS but I could not figure it out how to keep the devices online. Maybe is some simple switch I’m missing but it’s hard to found an answer. So… is there a way to automatically turn on the coral device whenever power is supplied?
What is currently happening is that when I connect the usb-c connector to the power it lits the ethernet orange light, but doesn’t turn the device on. Then, if I remove the usb-c, it blinks the red power led, and when I reconnect the usb-c, device boots ok.
If the power is removed for more than what seems to be ~20 seconds, I would need to perform the entire process again (connect-disconnect-connect).
What if I want to have my device always on? (eg.: after power outages device should be back online) – I’d even say that seems to be the most common case for balena devices. That seems to work just fine for raspberry pi’s, for example.
Any hints?
