E: The repository ‘cdrom://Linux Mint 22.2 Zara - Release amd64 20250828 noble Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Read error - read (5: Input/output error)
W: You may want to run apt-get update to correct these problems
E: The package cache file is corrupted
mint@mint:~$ wget http://ftp.cz.debian.org/debian/pool/main/g/gdk-pixbuf-xlib/libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb
–2025-12-28 16:43:32-- http://ftp.cz.debian.org/debian/pool/main/g/gdk-pixbuf-xlib/libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb
Resolving ftp.cz.debian.org … 78.128.211.127, 2001:718:1:1f:50:56ff:feee:127
Connecting to ftp.cz.debian.org |78.128.211.127|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 47960 (47K) [application/vnd.debian.binary-package]
Saving to: ‘libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb’
libgdk-pixbuf-xlib- 100%[===================>] 46.84K 199KB/s in 0.2s
2025-12-28 16:43:33 (199 KB/s) - ‘libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb’ saved [47960/47960]
mint@mint:~$ sudo dpkg -i libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb~
dpkg: error: cannot access archive ‘libgdk-pixbuf-xlib-2.0-0_2.40.2-2_i386.deb~’: No such file or directory
mint@mint:~$ sudo apt install -i libgdk-pixbuf-2.0-0
E: Command line option ‘i’ [from -i] is not understood in combination with the other options.
mint@mint:~$ sudo apt install ./balena-etcher_2.1.4_amd64.deb
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Note, selecting ‘balena-etcher’ instead of ‘./balena-etcher_2.1.4_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
balena-etcher : Depends: libgdk-pixbuf2.0-0 but it is not installable
E: Unable to correct problems, you have held broken packages.
mint@mint:~$ sudo apt install libgdk-pixbuf-2.0-0
libgdk-pixbuf-2.0-0 is already the newest version (2.42.10+dfsg-3ubuntu3.2).
0 upgraded, 0 newly installed, 0 to remove and 223 not upgraded.
mint@mint:~$ sudo apt install libgdk-pixbuf-2.0-dev
libgdk-pixbuf-2.0-dev is already the newest version (2.42.10+dfsg-3ubuntu3.2).
mint@mint:~$
