When I include systemd in the install packages, the error goes away. However I get connection refused when trying to connect to the port remotely. Also when I ssh into the container i’m able to see outputs for gpsd -V and /dev/ttyACM0
Hi @seesoe , the first thing that comes to mind is that you are using the balenalib base images and trying to enable a systemd service. The set of balenalib images are not 1-to-1 compatible with resin/ base images, one of the more significant changes is that systemd is no longer included in the base image. You can see a list of the major changes here: https://www.balena.io/docs/reference/base-images/base-images/#major-changes .
@shaunmulligan, thank you for the info, makes sense, didn’t think it would be as easy as apt-get systemd. I setup the dockerfile like the examples you suggested. I ran into 2 issues. Both were fixed with the following 2 lines being added.
RUN ["chmod", "+x", "/usr/bin/entry.sh"]
RUN ["chmod", "644", "/etc/systemd/system/balena.service"]
Then when the service started I hang at this, not sure what it means or to do from here with it.
[Logs] [2019-5-16 22:46:37] Started service 'gpsd sha256:49d2dceed38a035cbd8d7122b4e2150209526325a153daa1558d067f4a5e4e2e'
[Logs] [2019-5-16 22:46:37] [gpsd] Systemd init system enabled.
[Logs] [2019-5-16 22:46:37] [gpsd] systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[Logs] [2019-5-16 22:46:37] [gpsd] Created symlink /etc/systemd/system/systemd-udevd.service → /dev/null.
[Logs] [2019-5-16 22:46:37] [gpsd] Detected virtualization docker.
[Logs] [2019-5-16 22:46:37] [gpsd] Detected architecture arm.
[Logs] [2019-5-16 22:46:37] [gpsd] Set hostname to <6d054ef3ddb8>.
[Logs] [2019-5-16 22:46:38] [gpsd] kmod-static-nodes.service: Cannot add dependency job, ignoring: Unit kmod-static-nodes.service is masked.
[Logs] [2019-5-16 22:46:37] [gpsd] Failed to install release agent, ignoring: No such file or directory
[Logs] [2019-5-16 22:46:38] [gpsd] systemd-udevd.service: Cannot add dependency job, ignoring: Unit systemd-udevd.service is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] sys-fs-fuse-connections.mount: Cannot add dependency job, ignoring: Unit sys-fs-fuse-connections.mount is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] systemd-remount-fs.service: Cannot add dependency job, ignoring: Unit systemd-remount-fs.service is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] sys-kernel-config.mount: Cannot add dependency job, ignoring: Unit sys-kernel-config.mount is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] dev-hugepages.mount: Cannot add dependency job, ignoring: Unit dev-hugepages.mount is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] getty.target: Cannot add dependency job, ignoring: Unit getty.target is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] systemd-logind.service: Cannot add dependency job, ignoring: Unit systemd-logind.service is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] display-manager.service: Cannot add dependency job, ignoring: Unit display-manager.service is masked.
[Logs] [2019-5-16 22:46:38] [gpsd] systemd-udevd-kernel.socket: Socket service systemd-udevd.service not loaded, refusing.
[Logs] [2019-5-16 22:46:38] [gpsd] systemd-udevd-control.socket: Socket service systemd-udevd.service not loaded, refusing.
I read in another post that udev could be conflicting with the host, I removed ENV INITSYSTEM on and I believe the service is started now. But still can’t connect to the service at ip:2947.
[Logs] [2019-5-16 23:00:21] Started service 'gpsd sha256:04fe139d7416c52d01a9d1bedf95bd79aee1bc1401226cdadb1e6cec19f391da'
[Logs] [2019-5-16 23:00:21] [gpsd] Synchronizing state of gpsd.service with SysV service script with /lib/systemd/systemd-sysv-install.
[Logs] [2019-5-16 23:00:21] [gpsd] Executing: /lib/systemd/systemd-sysv-install enable gpsd
I created a simple node script that ran on the same service as gpsd and was able to communicate with the gpsd service with localhost:2947. I moved my code to a test service to see if I can still communicate with the service however the connection keeps getting refused, tried 0.0.0.0, and 127.0.0.1 with no luck.
Do I need to configure some sort of network param on the services to be able to communicate to the gpsd socket?
Hi @seesoe, when you have several services, each of them will have its own IP in a local network created by docker (or in this case, balenaEngine). This is described in this doc https://docs.docker.com/compose/networking/ though the balena supervisor implements a subset of those features (e.g. Links aren’t supported). But in your case, you should be able to talk with the gpsd service from the test service by hitting gpsd:2947 instead of localhost:2947. Note that you only need to have expose in the gpsd service, and you don’t need the ports definition unless you want to access the gpsd service from outside the device (in which case you can have ports without expose). Hope this helps!
@seesoe I’m not familiar with gpsd, but is it possible that it’s only listening on the loopback interface? Judging from these docs http://www.catb.org/gpsd/gpsd.html I think you might need to add a -G flag, since as far as the container knows, the other service is on an external interface
@pcarranzav, That did it! I don’t know how I missed that flag in the docs . Makes total sense though, gpsd does all it can to keep data on the machine unless -G It even says Socket disconnected.
Final solution systemd
gpsd /dev/ttyACM0 -F /var/run/gpsd.sock -G
var listener = new gpsd.Listener({
port: 2947,
hostname: 'gpsd',
logger: console,
parse: true
Hi folks,
I struggled with the same issue with GPSD.
Handing off the service to systemd isn’t best practice for a container. The running container process should always be pid 1. That way if the process crashes the engine can restart the container.
Using the method above i.e. “sleep infinity”, in the case where gpsd crashes your container won’t restart. GPSD let’s us start it in non-daemon mode which is super useful.
Also over permissive access can be dangerous.
If it helps here’s what I’ve been using. Admittedly, I’m not using a non-root user. It’s on the todo list.
Dockerfile
FROM balenalib/raspberrypi3-alpine
RUN apk add --no-cache gpsd gpsd-clients
CMD /usr/sbin/gpsd -N -n -G /dev/ttyAMA0
It’s being some time since you posted. Hope you can help me.
I am trying to migrate my raspberry pi 4 project to a multicontainer project using BALENA.
I use a USB GPS that works like a charm in my current setup (home assistant installed into raspbian buster OS).I just installed gpsd package and a component in home assistant, with no further configurations, home assistant is able to pull data from the USB GPS sensor via GPSD.
Now, trying to set it up with Balena, I configured a GPSD service in a multicontainer project (with home assistant and MQTT containers too) from:
