Git Push Stuck on Writing Objects
Resin / Raspberry Pi setup is good, attempting to follow instructions per https://github.com/resin-io-projects/simple-server-node.
All works well until the final step (git push resin master), and the command hangs indefinitely on ‘Writing objects’, stays stuck at 54%. I have tried this from a separate workstation, with exactly the same results. Any thoughts?
C:\simple-server-node> git push resin master
Counting objects: 55, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (33/33), done.
Writing objects: 54% (30/55)
Hey @clayshek,
Welcome to resin! I just ran a build on a new app and it all looks okay for me (logs attached below). Can you describe you setup a bit so we can try narrow down the issue.
shaun-mbp-2:Desktop hobochild$ cd simple-server-node/
shaun-mbp-2:simple-server-node hobochild$ git remote add resin shaun_projects@git.resin.io:shaun_projects/testgit.git
shaun-mbp-2:simple-server-node hobochild$ git push resin master
Compressing objects: 100% (54/54), done.
Writing objects: 100% (55/55), 379.40 KiB | 0 bytes/s, done.
Total 55 (delta 22), reused 0 (delta 0)
[Info]     Starting build for shaun_projects/testgit, user shaun_projects
[Info]     Dashboard link: https://dashboard.resin.io/apps/520304/devices
[Info]     Building on ARM01
[Info]     Fetching base image
[==================================================>] 100%
[Info]     Building Dockerfile.template project
[Build]    Step 1/7 : FROM resin/raspberrypi3-node:6-slim
[Build]     ---> 5f3054b374ff
[Build]    Step 2/7 : WORKDIR /usr/src/app
[Build]     ---> 5b63ae90ccec
[Build]    Removing intermediate container 2c5ff897cc9c
[Build]    Step 3/7 : COPY package.json package.json
[Build]     ---> 137770f7485d
[Build]    Removing intermediate container d0d31ef9f0e8
[Build]    Step 4/7 : RUN JOBS=MAX npm install --production --unsafe-perm && npm cache clean && rm -rf /tmp/*
[Build]     ---> Running in ab30f6489dd7
[Build]    simple-server-node@1.0.0 /usr/src/app
[Build]    └─┬ express@4.15.4
[Build]      ├─┬ accepts@1.3.4
[Build]      │ ├─┬ mime-types@2.1.16
[Build]      │ │ └── mime-db@1.29.0
[Build]      │ └── negotiator@0.6.1
[Build]      ├── array-flatten@1.1.1
[Build]      ├── content-disposition@0.5.2
[Build]      ├── content-type@1.0.2
[Build]      ├── cookie@0.3.1
[Build]      ├── cookie-signature@1.0.6
[Build]      ├─┬ debug@2.6.8
[Build]      │ └── ms@2.0.0
[Build]      ├── depd@1.1.1
[Build]      ├── encodeurl@1.0.1
[Build]      ├── escape-html@1.0.3
[Build]      ├── etag@1.8.0
[Build]      ├─┬ finalhandler@1.0.4
[Build]      │ └── unpipe@1.0.0
[Build]      ├── fresh@0.5.0
[Build]      ├── merge-descriptors@1.0.1
[Build]      ├── methods@1.1.2
[Build]      ├─┬ on-finished@2.3.0
[Build]      │ └── ee-first@1.1.1
[Build]      ├── parseurl@1.3.1
[Build]      ├── path-to-regexp@0.1.7
[Build]      ├─┬ proxy-addr@1.1.5
[Build]      │ ├── forwarded@0.1.0
[Build]      │ └── ipaddr.js@1.4.0
[Build]      ├── qs@6.5.0
[Build]      ├── range-parser@1.2.0
[Build]      ├─┬ send@0.15.4
[Build]      │ ├── destroy@1.0.4
[Build]      │ ├─┬ http-errors@1.6.2
[Build]      │ │ └── inherits@2.0.3
[Build]      │ └── mime@1.3.4
[Build]      ├── serve-static@1.12.4
[Build]      ├── setprototypeof@1.0.3
[Build]      ├── statuses@1.3.1
[Build]      ├─┬ type-is@1.6.15
[Build]      │ └── media-typer@0.3.0
[Build]      ├── utils-merge@1.0.0
[Build]      └── vary@1.1.1
[Build]     ---> e8549021a788
[Build]    Removing intermediate container ab30f6489dd7
[Build]    Step 5/7 : COPY . ./
[Build]     ---> cd5fbe6223b2
[Build]    Removing intermediate container b014ba9f5f96
[Build]    Step 6/7 : ENV INITSYSTEM on
[Build]     ---> Running in f93de4056177
[Build]     ---> 82026fa1a623
[Build]    Removing intermediate container f93de4056177
[Build]    Step 7/7 : CMD npm start
[Build]     ---> Running in 411fc00f9932
[Build]     ---> 855f565b4953
[Build]    Removing intermediate container 411fc00f9932
[Build]    Successfully built 855f565b4953
[Build]    Successfully tagged registry2.resin.io:443/testgit/0a40648adc7806d049bf6172e44e98aa5f53bedb:latest
[Success]  Image created successfully
[Info]     Verifying image integrity...
[Success]  Image passed integrity checks!
[Info]     Uploading image to registry...
[Success]  Image uploaded successfully!
[Info]     Check your dashboard for device download progress:
[Info]       https://dashboard.resin.io/apps/520304/devices
[Info]     Build took 1 minute and 5 seconds
[Info]     Image size: 171.15 MB (+ 1.33 MB from resin/raspberrypi3-node:6-slim)
			        >\/7
			    _.-(6'  \
			   (=___._/` \
			     j    < _\
			 _.-' :      ``.
			 \ r=._\        `.
			<`\\_  \         .`-.
			 \ r-7  `-. ._  ' .  `\
			  \`,      `-.`7  7)   )
			   \/         \|  \'  / `-._
			           <.'_.''
Tip: Talk to other resin.io users in the https://gitter.im/resin-io/chat chat room!
To shaun_projects@git.resin.io:shaun_projects/testgit.git
 * [new branch]      master -> master
shaun-mbp-2:simple-server-node hobochild$ date
Thu 24 Aug 2017 22:01:08 BST
From your logs it looks like you are running on windows. Which git client are you using. perhaps trying with git bash or another one might help?
Correct, running on Windows. I have same results from both Windows 10 & Win 7 Enterprise. Updated to the latest version of Git (2.14.1.windows.1) on one of those to try to rectify the issue, no change. On v 2.12.0.windows.1 on the other laptop. Was trying with Git command, just tried git bash, same results, hanging on Writing objects. My ssh key was imported to resin.io from Github without issue.
@clayshek, are you having any trouble running git push to other repos?
I’m not, tested to several others, working fine.
Interesting, I’ll keep looking into it and let you know what I find.
Thanks. I just tried using the hello-python project, no change in behavior:
PS C:> git clone git@github.com:alexandrosm/hello-python.git
Cloning into ‘hello-python’…
remote: Counting objects: 80, done.
remote: Total 80 (delta 0), reused 0 (delta 0), pack-reused 80
Receiving objects: 100% (80/80), 9.78 KiB | 1.22 MiB/s, done.
Resolving deltas: 100% (16/16), done.
PS C:> cd .\hello-python
PS C:\hello-python> git remote add resin gh_clayshek@git.resin.io:gh_clayshek/pifleetapp.git
PS C:\hello-python> git push resin master
Compressing objects: 100% (62/62), done.
Writing objects: 62% (50/80)
Stalls here indefinitely.
@clayshek, It’s possible there’s an issue with the SSH key type. Could you try the following:
  • Create a new project with just a Dockerfile
  • In the Dockerfile, put FROM resin/raspberrypi3-debian
  • run git init, git add Dockerfile, etc. and try pushing again
@clayshek, you might also try running GIT_SSH_COMMAND="ssh -v" git push resin master to see if we can get a little more info
So a bit of further troubleshooting and I seem to be on to something, thanks to your suggestion to use GIT_SSH_COMMAND=“ssh -v” git push…
Pretty much any regular git command that interacts with the resin git server (git clone, git push) is getting hung up at some point. However, when I run it as above to spit out more verbose info, it works. Seems like an info response is being returned, and my terminal isn’t handling it. I see this with both git from windows command line / powershell, as well as git bash, and experiencing this on multiple machines / Windows OS. Still digging further, I may vaguely recall this from some time ago as a git / Windows related bug. However, interesting that I don’t see this problem with github, or my internal gitlab enterprise servers.
Hey @clayshek,
Do you think that you could provide us with the log of the failed commands by adding extra verbosity with GIT_SSH_COMMAND=“ssh -vvv” ? That will give our backend team more to work with while troubleshooting this.
Best, Kostas
Looks like this is related to using Pageant (Putty) for ssh key management. I had my GIT setup configured that way, and has worked elsewhere as mentioned prior. That was the default when running any git command (GIT_SSH environment variable set to ‘C:\Program Files (x86)\PuTTY\plink.exe’), however, when running GIT_SSH_COMMAND that overrides it, taking pageant out of the picture, and everything works find on the Resin git server.
Below is output of the commands run with GIT_TRACE=2, showing the difference. I updated to latest version of putty software (0.70) but issue still exists. I have just removed it from the picture by deleting the GIT_SSH env var, and using git bash with ssh-agent. Works fine now. Others using putty / pageant may experience same.
~/simple-server-node (master)
$ GIT_TRACE=2 git push resin master
21:37:42.241072 git.c:328
trace: built-in: git ‘push’ ‘resin’ 'master’
Pushing to gh_clayshek@git.resin.io:gh_clayshek/pifleetapp.git
21:37:42.251072 run-command.c:626
trace: run_command: ‘C:\Program Files (x86)\PuTTY\plink.exe’ ‘gh_clayshek@git.resin.io’ ‘git-receive-pack ‘’‘gh_clayshek/pifleetapp.git’’’’
$ GIT_SSH_COMMAND=“ssh -v” GIT_TRACE=2 git push resin master
21:38:31.524890 git.c:328
21:38:31.530891 run-command.c:626
trace: run_command: ‘ssh -v’ ‘gh_clayshek@git.resin.io’ ‘git-receive-pack ‘’‘gh_clayshek/pifleetapp.git’’’'
OpenSSH_7.5p1, OpenSSL 1.0.2k 26 Jan 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to git.resin.io [54.165.162.194] port 22.
debug1: Connection established.
Hi, so the issue is solved now?
Yes, solved for me by taking Pageant out of the picture for ssh key management. Would still exist if I went back to using Pageant, so remediated might be a better word, but all good now. Thank you for the help!
Glad it’s working. Enjoy resin!
I get the same issue and confirm it is using git on windows with putty pageant. Using pageant to manage keys works with every every other git server server I use, (bitbucket, github, gitlab). It is also the default for the popular widows git client tortise git.
I guess it is a lower priority to fix but would be nice someday and may cause some windows users confusion and make it harder to give resin.io a go.
