Hello! I’m brand-new to Yocto, but I wanted a bleeding-edge change introduced in the balena-raspberrypi repo.
I was able to successfully build the project and now have the following files in build/tmp/deploy/images/raspberrypi4-64:
act-led-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
act-led.dtbo
act-led-raspberrypi4-64.dtbo
adau1977-adc-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
adau1977-adc.dtbo
adau1977-adc-raspberrypi4-64.dtbo
adau7002-simple-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
adau7002-simple.dtbo
adau7002-simple-raspberrypi4-64.dtbo
ads1015-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
ads1015.dtbo
ads1015-raspberrypi4-64.dtbo
ads1115-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
ads1115.dtbo
ads1115-raspberrypi4-64.dtbo
ads7846-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
ads7846.dtbo
ads7846-raspberrypi4-64.dtbo
akkordion-iqdacplus-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
akkordion-iqdacplus.dtbo
akkordion-iqdacplus-raspberrypi4-64.dtbo
allo-boss-dac-pcm512x-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
allo-boss-dac-pcm512x-audio.dtbo
allo-boss-dac-pcm512x-audio-raspberrypi4-64.dtbo
allo-digione-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
allo-digione.dtbo
allo-digione-raspberrypi4-64.dtbo
allo-piano-dac-pcm512x-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
allo-piano-dac-pcm512x-audio.dtbo
allo-piano-dac-pcm512x-audio-raspberrypi4-64.dtbo
allo-piano-dac-plus-pcm512x-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
allo-piano-dac-plus-pcm512x-audio.dtbo
allo-piano-dac-plus-pcm512x-audio-raspberrypi4-64.dtbo
at86rf233-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
at86rf233.dtbo
at86rf233-raspberrypi4-64.dtbo
audioinjector-addons-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
audioinjector-addons.dtbo
audioinjector-addons-raspberrypi4-64.dtbo
audioinjector-wm8731-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
audioinjector-wm8731-audio.dtbo
audioinjector-wm8731-audio-raspberrypi4-64.dtbo
audremap-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
audremap.dtbo
audremap-raspberrypi4-64.dtbo
bcm2711-rpi-4-b-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtb
bcm2711-rpi-4-b.dtb
bcm2711-rpi-4-b-raspberrypi4-64.dtb
bcm2835-bootfiles
boot.scr
dht11-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dht11.dtbo
dht11-raspberrypi4-64.dtbo
dionaudio-loco-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dionaudio-loco.dtbo
dionaudio-loco-raspberrypi4-64.dtbo
dionaudio-loco-v2-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dionaudio-loco-v2.dtbo
dionaudio-loco-v2-raspberrypi4-64.dtbo
disable-bt-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
disable-bt.dtbo
disable-bt-raspberrypi4-64.dtbo
disable-wifi-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
disable-wifi.dtbo
disable-wifi-raspberrypi4-64.dtbo
dpi18-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dpi18.dtbo
dpi18-raspberrypi4-64.dtbo
dpi24-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dpi24.dtbo
dpi24-raspberrypi4-64.dtbo
dwc2-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dwc2.dtbo
dwc2-raspberrypi4-64.dtbo
dwc-otg-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
dwc-otg.dtbo
dwc-otg-raspberrypi4-64.dtbo
enc28j60-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
enc28j60.dtbo
enc28j60-raspberrypi4-64.dtbo
enc28j60-spi2-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
enc28j60-spi2.dtbo
enc28j60-spi2-raspberrypi4-64.dtbo
extra_uEnv.txt
fe-pi-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
fe-pi-audio.dtbo
fe-pi-audio-raspberrypi4-64.dtbo
goodix-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
goodix.dtbo
goodix-raspberrypi4-64.dtbo
googlevoicehat-soundcard-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
googlevoicehat-soundcard.dtbo
googlevoicehat-soundcard-raspberrypi4-64.dtbo
gpio-ir-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
gpio-ir.dtbo
gpio-ir-raspberrypi4-64.dtbo
gpio-ir-tx-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
gpio-ir-tx.dtbo
gpio-ir-tx-raspberrypi4-64.dtbo
gpio-key-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
gpio-key.dtbo
gpio-key-raspberrypi4-64.dtbo
gpio-poweroff-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
gpio-poweroff.dtbo
gpio-poweroff-raspberrypi4-64.dtbo
gpio-shutdown-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
gpio-shutdown.dtbo
gpio-shutdown-raspberrypi4-64.dtbo
hifiberry-amp-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hifiberry-amp.dtbo
hifiberry-amp-raspberrypi4-64.dtbo
hifiberry-dac-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hifiberry-dac.dtbo
hifiberry-dacplus-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hifiberry-dacplus.dtbo
hifiberry-dacplus-raspberrypi4-64.dtbo
hifiberry-dac-raspberrypi4-64.dtbo
hifiberry-digi-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hifiberry-digi.dtbo
hifiberry-digi-pro-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hifiberry-digi-pro.dtbo
hifiberry-digi-pro-raspberrypi4-64.dtbo
hifiberry-digi-raspberrypi4-64.dtbo
hy28a-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hy28a.dtbo
hy28a-raspberrypi4-64.dtbo
hy28b-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hy28b.dtbo
hy28b-raspberrypi4-64.dtbo
hyperpixel4-pi3-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hyperpixel4-pi3.dtbo
hyperpixel4-pi3-raspberrypi4-64.dtbo
hyperpixel4-pi4-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hyperpixel4-pi4.dtbo
hyperpixel4-pi4-raspberrypi4-64.dtbo
hyperpixel4-square-pi3-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hyperpixel4-square-pi3.dtbo
hyperpixel4-square-pi3-raspberrypi4-64.dtbo
hyperpixel4-square-pi4-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
hyperpixel4-square-pi4.dtbo
hyperpixel4-square-pi4-raspberrypi4-64.dtbo
i2c0-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c0.dtbo
i2c0-raspberrypi4-64.dtbo
i2c1-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c1.dtbo
i2c1-raspberrypi4-64.dtbo
i2c3-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c3.dtbo
i2c3-raspberrypi4-64.dtbo
i2c4-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c4.dtbo
i2c4-raspberrypi4-64.dtbo
i2c5-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c5.dtbo
i2c5-raspberrypi4-64.dtbo
i2c6-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c6.dtbo
i2c6-raspberrypi4-64.dtbo
i2c-gpio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-gpio.dtbo
i2c-gpio-raspberrypi4-64.dtbo
i2c-mux-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-mux.dtbo
i2c-mux-raspberrypi4-64.dtbo
i2c-pwm-pca9685a-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-pwm-pca9685a.dtbo
i2c-pwm-pca9685a-raspberrypi4-64.dtbo
i2c-rtc-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-rtc.dtbo
i2c-rtc-gpio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-rtc-gpio.dtbo
i2c-rtc-gpio-raspberrypi4-64.dtbo
i2c-rtc-raspberrypi4-64.dtbo
i2c-sensor-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
i2c-sensor.dtbo
i2c-sensor-raspberrypi4-64.dtbo
Image.gz
Image.gz-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.bin
Image.gz-initramfs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.bin
Image.gz-initramfs-raspberrypi4-64.bin
Image.gz-raspberrypi4-64.bin
iqaudio-dac-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
iqaudio-dac.dtbo
iqaudio-dacplus-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
iqaudio-dacplus.dtbo
iqaudio-dacplus-raspberrypi4-64.dtbo
iqaudio-dac-raspberrypi4-64.dtbo
iqaudio-digi-wm8804-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
iqaudio-digi-wm8804-audio.dtbo
iqaudio-digi-wm8804-audio-raspberrypi4-64.dtbo
justboom-dac-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
justboom-dac.dtbo
justboom-dac-raspberrypi4-64.dtbo
justboom-digi-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
justboom-digi.dtbo
justboom-digi-raspberrypi4-64.dtbo
kernel_modules_headers.tar.gz
kernel_source.tar.gz
mcp23017-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp23017.dtbo
mcp23017-raspberrypi4-64.dtbo
mcp23s17-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp23s17.dtbo
mcp23s17-raspberrypi4-64.dtbo
mcp2515-can0-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp2515-can0.dtbo
mcp2515-can0-raspberrypi4-64.dtbo
mcp2515-can1-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp2515-can1.dtbo
mcp2515-can1-raspberrypi4-64.dtbo
mcp3008-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp3008.dtbo
mcp3008-raspberrypi4-64.dtbo
mcp3202-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp3202.dtbo
mcp3202-raspberrypi4-64.dtbo
mcp342x-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mcp342x.dtbo
mcp342x-raspberrypi4-64.dtbo
midi-uart0-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
midi-uart0.dtbo
midi-uart0-raspberrypi4-64.dtbo
midi-uart1-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
midi-uart1.dtbo
midi-uart1-raspberrypi4-64.dtbo
miniuart-bt-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
miniuart-bt.dtbo
miniuart-bt-raspberrypi4-64.dtbo
mmc-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mmc.dtbo
mmc-raspberrypi4-64.dtbo
modules-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.tgz
modules-raspberrypi4-64.tgz
Module.symvers
mpu6050-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mpu6050.dtbo
mpu6050-raspberrypi4-64.dtbo
mz61581-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
mz61581.dtbo
mz61581-raspberrypi4-64.dtbo
os-release
papirus-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
papirus.dtbo
papirus-raspberrypi4-64.dtbo
piscreen-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
piscreen2r-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
piscreen2r.dtbo
piscreen2r-raspberrypi4-64.dtbo
piscreen.dtbo
piscreen-raspberrypi4-64.dtbo
pisound-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pisound.dtbo
pisound-raspberrypi4-64.dtbo
pitft22-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pitft22.dtbo
pitft22-raspberrypi4-64.dtbo
pitft28-capacitive-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pitft28-capacitive.dtbo
pitft28-capacitive-raspberrypi4-64.dtbo
pitft28-resistive-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pitft28-resistive.dtbo
pitft28-resistive-raspberrypi4-64.dtbo
pitft35-resistive-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pitft35-resistive.dtbo
pitft35-resistive-raspberrypi4-64.dtbo
pps-gpio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pps-gpio.dtbo
pps-gpio-raspberrypi4-64.dtbo
pwm-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pwm-2chan-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
pwm-2chan.dtbo
pwm-2chan-raspberrypi4-64.dtbo
pwm.dtbo
pwm-raspberrypi4-64.dtbo
qca7000-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
qca7000.dtbo
qca7000-raspberrypi4-64.dtbo
resin-data.img
resin-image
resin-image-initramfs-raspberrypi4-64-20201210235456.rootfs.cpio.gz
resin-image-initramfs-raspberrypi4-64-20201210235456.rootfs.manifest
resin-image-initramfs-raspberrypi4-64-20201210235456.testdata.json
resin-image-initramfs-raspberrypi4-64.cpio.gz
resin-image-initramfs-raspberrypi4-64.manifest
resin-image-initramfs-raspberrypi4-64.testdata.json
resin-image-raspberrypi4-64-20201211013047.rootfs.docker
resin-image-raspberrypi4-64-20201211013047.rootfs.hostapp-ext4
resin-image-raspberrypi4-64-20201211013047.rootfs.license.manifest
resin-image-raspberrypi4-64-20201211013047.rootfs.manifest
resin-image-raspberrypi4-64-20201211013047.rootfs.resinos-img
resin-image-raspberrypi4-64-20201211013047.rootfs.tar
resin-image-raspberrypi4-64-20201211013047.testdata.json
resin-image-raspberrypi4-64.docker
resin-image-raspberrypi4-64.hostapp-ext4
resin-image-raspberrypi4-64.license.manifest
resin-image-raspberrypi4-64.manifest
resin-image-raspberrypi4-64.resinhup-tar
resin-image-raspberrypi4-64.resinos-img
resin-image-raspberrypi4-64.tar
resin-image-raspberrypi4-64.testdata.json
rotary-encoder-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rotary-encoder.dtbo
rotary-encoder-raspberrypi4-64.dtbo
rpi-backlight-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-backlight.dtbo
rpi-backlight-raspberrypi4-64.dtbo
rpi-cirrus-wm5102-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-cirrus-wm5102.dtbo
rpi-cirrus-wm5102-raspberrypi4-64.dtbo
rpi-dac-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-dac.dtbo
rpi-dac-raspberrypi4-64.dtbo
rpi-display-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-display.dtbo
rpi-display-raspberrypi4-64.dtbo
rpi-eeprom
rpi-ft5406-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-ft5406.dtbo
rpi-ft5406-raspberrypi4-64.dtbo
rpi-poe-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-poe.dtbo
rpi-poe-raspberrypi4-64.dtbo
rpi-proto-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-proto.dtbo
rpi-proto-raspberrypi4-64.dtbo
rpi-sense-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-sense.dtbo
rpi-sense-raspberrypi4-64.dtbo
rpi-tv-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rpi-tv.dtbo
rpi-tv-raspberrypi4-64.dtbo
rra-digidac1-wm8741-audio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
rra-digidac1-wm8741-audio.dtbo
rra-digidac1-wm8741-audio-raspberrypi4-64.dtbo
sc16is750-i2c-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
sc16is750-i2c.dtbo
sc16is750-i2c-raspberrypi4-64.dtbo
sc16is752-spi1-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
sc16is752-spi1.dtbo
sc16is752-spi1-raspberrypi4-64.dtbo
sdhost-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
sdhost.dtbo
sdhost-raspberrypi4-64.dtbo
sdio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
sdio.dtbo
sdio-raspberrypi4-64.dtbo
sdtweak-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
sdtweak.dtbo
sdtweak-raspberrypi4-64.dtbo
smi-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
smi-dev-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
smi-dev.dtbo
smi-dev-raspberrypi4-64.dtbo
smi.dtbo
smi-nand-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
smi-nand.dtbo
smi-nand-raspberrypi4-64.dtbo
smi-raspberrypi4-64.dtbo
spi0-cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi0-cs.dtbo
spi0-cs-raspberrypi4-64.dtbo
spi1-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi1-1cs.dtbo
spi1-1cs-raspberrypi4-64.dtbo
spi1-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi1-2cs.dtbo
spi1-2cs-raspberrypi4-64.dtbo
spi1-3cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi1-3cs.dtbo
spi1-3cs-raspberrypi4-64.dtbo
spi2-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi2-1cs.dtbo
spi2-1cs-raspberrypi4-64.dtbo
spi2-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi2-2cs.dtbo
spi2-2cs-raspberrypi4-64.dtbo
spi2-3cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi2-3cs.dtbo
spi2-3cs-raspberrypi4-64.dtbo
spi3-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi3-1cs.dtbo
spi3-1cs-raspberrypi4-64.dtbo
spi3-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi3-2cs.dtbo
spi3-2cs-raspberrypi4-64.dtbo
spi4-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi4-1cs.dtbo
spi4-1cs-raspberrypi4-64.dtbo
spi4-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi4-2cs.dtbo
spi4-2cs-raspberrypi4-64.dtbo
spi5-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi5-1cs.dtbo
spi5-1cs-raspberrypi4-64.dtbo
spi5-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi5-2cs.dtbo
spi5-2cs-raspberrypi4-64.dtbo
spi6-1cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi6-1cs.dtbo
spi6-1cs-raspberrypi4-64.dtbo
spi6-2cs-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi6-2cs.dtbo
spi6-2cs-raspberrypi4-64.dtbo
spi-gpio35-39-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi-gpio35-39.dtbo
spi-gpio35-39-raspberrypi4-64.dtbo
spi-gpio40-45-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi-gpio40-45.dtbo
spi-gpio40-45-raspberrypi4-64.dtbo
spi-rtc-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
spi-rtc.dtbo
spi-rtc-raspberrypi4-64.dtbo
system-connections
tinylcd35-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
tinylcd35.dtbo
tinylcd35-raspberrypi4-64.dtbo
tpm-slb9670-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
tpm-slb9670.dtbo
tpm-slb9670-raspberrypi4-64.dtbo
uart0.dtbo
uart1.dtbo
uart2-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
uart2.dtbo
uart2-raspberrypi4-64.dtbo
uart3-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
uart3.dtbo
uart3-raspberrypi4-64.dtbo
uart4-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
uart4.dtbo
uart4-raspberrypi4-64.dtbo
uart5-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
uart5.dtbo
uart5-raspberrypi4-64.dtbo
u-boot.bin
u-boot-raspberrypi4-64-2019.01-r0.bin
u-boot-raspberrypi4-64.bin
vc4-fkms-v3d-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
vc4-fkms-v3d.dtbo
vc4-fkms-v3d-raspberrypi4-64.dtbo
vc4-kms-v3d-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
vc4-kms-v3d.dtbo
vc4-kms-v3d-raspberrypi4-64.dtbo
VERSION
VERSION_HOSTOS
vga666-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
vga666.dtbo
vga666-raspberrypi4-64.dtbo
w1-gpio-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
w1-gpio.dtbo
w1-gpio-pullup-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
w1-gpio-pullup.dtbo
w1-gpio-pullup-raspberrypi4-64.dtbo
w1-gpio-raspberrypi4-64.dtbo
waveshare-sim7600-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
waveshare-sim7600.dtbo
waveshare-sim7600-raspberrypi4-64.dtbo
wittypi-1-5.4.58+git0+4592a09478-r0-raspberrypi4-64-20201210235456.dtbo
wittypi.dtbo
wittypi-raspberrypi4-64.dtbo
I’d like to generate a .img file so I can flash the new OS to an SD card. How can I do this? I searched for quite a bit online but haven’t found anything helpful. How are you all generating these .img files on your end?
