flash error in kali linux
hello, i’ve been using kali linux for quite a week now and i want to change linux distro
linux distro that i wanna change to: Debian 12 (iso image file)
Linux distro i currently use: Kali Linux
bits os: amd64
my os i used to boot into kali linux
Windows
Hi @kalicraft
So am I right in that you are running into some balenaEtcher flash errors when attempting to flash a USB drive with a Debian 12 ISO file on your device running Kali Linux? Could you share the exact error you’re getting, and also maybe try a different USB drive and/or flashing a different ISO image. It could be a balenaEtcher issue, but could also be an issue with the drive itself or the image you’re using. Having the actual error message itself would be helpful.
