Fortunately, I was able to analyse a case just few minutes after it happened. Therefore I realized, that not the Balena OS reboots, but our applicaton, running on it, has restartet. In the journal of the device, I found a huge amount of messages from “balenad”:
Nov 24 07:48:06 d2826e7 c4cbeb3ef8e0[739]: [90B blob data]
Nov 24 07:48:15 d2826e7 ebd8ee3c3e57[739]: Supervisor API: GET /v1/healthy 200 - 3.495 ms
Nov 24 07:48:15 d2826e7 resin-supervisor[1240]: Supervisor API: GET /v1/healthy 200 - 3.495 ms
Nov 24 07:48:15 d2826e7 balenad[739]: fatal error: unexpected signal during runtime execution
Nov 24 07:48:15 d2826e7 balenad[739]: [signal SIGSEGV: segmentation violation code=0x2 addr=0xb6f8e920 pc=0xb6e1f360]
Nov 24 07:48:15 d2826e7 balenad[739]: runtime stack:
Nov 24 07:48:15 d2826e7 balenad[739]: runtime.throw(0x12a35da, 0x2a)
Nov 24 07:48:15 d2826e7 balenad[739]: /usr/lib/go/src/runtime/panic.go:616 +0x60
Nov 24 07:48:15 d2826e7 balenad[739]: runtime.sigpanic()
Nov 24 07:48:15 d2826e7 balenad[739]: /usr/lib/go/src/runtime/signal_unix.go:372 +0x22c
Nov 24 07:48:15 d2826e7 balenad[739]: goroutine 321 [syscall]:
Nov 24 07:48:15 d2826e7 balenad[739]: runtime.cgocall(0xf27fac, 0x13ffe760, 0x129f6d4)
Nov 24 07:48:15 d2826e7 balenad[739]: /usr/lib/go/src/runtime/cgocall.go:128 +0x64 fp=0x13ffe740 sp=0x13ffe728 pc=0x155d8
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/daemon/logger/journald._Cfunc_wait_for_data_cancelable(0x34f85a8, 0x33, 0x0)
Nov 24 07:48:15 d2826e7 balenad[739]: _cgo_gotypes.go:397 +0x38 fp=0x13ffe75c sp=0x13ffe740 pc=0xe4a810
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/daemon/logger/journald.(*journald).followJournal.func1.1(0x34f85a8, 0x33, 0x34f85a8)
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/daemon/logger/journald/read.go:272 >
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/daemon/logger/journald.(*journald).followJournal.func1(0x34f85a8, 0x33, 0x3b, 0x13d6f360, 0x13db6690, 0x13a09658, 0x0, 0x0, 0x13f91640)
Nov 24 07:48:15 d2826e7 balenad[739]: runtime.goexit()
Nov 24 07:48:15 d2826e7 balenad[739]: /usr/lib/go/src/runtime/asm_arm.s:1015 +0x4 fp=0x13ffe7c4 sp=0x13ffe7c4 pc=0x7485c
Nov 24 07:48:15 d2826e7 balenad[739]: created by github.com/docker/docker/daemon/logger/journald.(*journald).followJournal
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/daemon/logger/journald/read.go:268 >
Nov 24 07:48:15 d2826e7 balenad[739]: goroutine 1 [chan receive, 48765 minutes]:
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/cmd/dockerd.(*DaemonCli).start(0x13b92220, 0x13aeccf0, 0x0, 0x0)
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/cmd/dockerd/daemon.go:222 +0x878
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/cmd/dockerd.runDaemon(0x13aeccf0, 0x13aea300, 0x0)
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/cmd/dockerd/docker_unix.go:7 +0x30
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/cmd/dockerd.newDaemonCommand.func1(0x13b088c0, 0x13aea500, 0x0, 0x10, 0x0, 0x0)
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/cmd/dockerd/docker.go:29 +0x50
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/vendor/github.com/spf13/cobra.(*Command).execute(0x13b088c0, 0x138ac098, 0x10, 0x11, 0x13b088c0, 0x138ac098)
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/vendor/github.com/spf13/cobra/comma>
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/vendor/github.com/spf13/cobra.(*Command).ExecuteC(0x13b088c0, 0x13feea0, 0x1055830, 0x13feea8)
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/vendor/github.com/spf13/cobra.(*Command).Execute(0x13b088c0, 0x138a60d8, 0x125131d)
Nov 24 07:48:15 d2826e7 balenad[739]: github.com/docker/docker/cmd/dockerd.Main()
Nov 24 07:48:15 d2826e7 balenad[739]: /yocto/resin-board/build/tmp/work/armv7vehf-neon-poky-linux-gnueabi/balena/18.09.6-dev+git95c7371304f9cef494efe93f0a8ffd53a75eac21-r0/git/src/import/.gopath/src/github.com/docker/docker/cmd/dockerd/docker.go:71 +0x7c
BalenaDeviceJournal.log (174.1 KB)
Any ideas?
