I am trying to install BalenaEtcher on Ubuntu22.04 running on VirtualBox. After installing libfuse2, got errors:
crane@Ubuntu:~/Downloads$ sudo apt install libfuse2
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
libfuse2 is already the newest version (2.9.9-5ubuntu3).
0 upgraded, 0 newly installed, 0 to remove and 21 not upgraded.
crane@Ubuntu:~/Downloads$ sudo ./balenaEtcher-1.18.11-x64.AppImage
[1688235:0902/172013.158805:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[1688235:0902/172013.158885:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
Authorization required, but no authorization protocol specified
[1688267:0902/172013.273400:ERROR:angle_platform_impl.cc(43)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[1688267:0902/172013.277035:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[1688267:0902/172013.277447:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Not initialized.
[1688267:0902/172013.278624:ERROR:gl_surface_egl.cc(1489)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1688267:0902/172013.291729:ERROR:gl_ozone_egl.cc(21)] GLSurfaceEGL::InitializeOneOff failed.
[1688267:0902/172013.441967:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1688235:0902/172013.594999:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[1688301:0902/172013.784039:ERROR:angle_platform_impl.cc(43)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[1688301:0902/172013.784210:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[1688301:0902/172013.787240:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Not initialized.
[1688301:0902/172013.791916:ERROR:gl_surface_egl.cc(1489)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1688301:0902/172013.803238:ERROR:gl_ozone_egl.cc(21)] GLSurfaceEGL::InitializeOneOff failed.
[1688301:0902/172013.931607:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1688309:0902/172014.237385:ERROR:angle_platform_impl.cc(43)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[1688309:0902/172014.259414:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[1688309:0902/172014.273768:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Not initialized.
[1688309:0902/172014.290702:ERROR:gl_surface_egl.cc(1489)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1688309:0902/172014.296997:ERROR:gl_ozone_egl.cc(21)] GLSurfaceEGL::InitializeOneOff failed.
[1688309:0902/172014.380030:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1688321:0902/172014.584328:ERROR:gpu_init.cc(481)] Passthrough is not supported, GL is disabled, ANGLE is
[1688321:0902/172014.749473:ERROR:x11_software_bitmap_presenter.cc(141)] XGetWindowAttributes failed for window 12582915
Language changed to: en
[1688235:0902/172015.323586:ERROR:bus.cc(398)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
packageUpdatable false
ready-to-show: 2.500s
What might go wrong?
Tried another image, it doesn’t run at all.
crane@Ubuntu:~/Downloads$ ls -l
total 293508
-rwxrwxr-x 1 crane crane 99670660 Aug 26 23:09 balenaEtcher-1.18.11-x64.AppImage
-rwxrwxr-x 1 crane crane 93990136 Sep 2 17:22 balenaEtcher-1.7.9-ia32.AppImage
crane@Ubuntu:~/Downloads$ sudo ./balenaEtcher-1.7.9-ia32.AppImage
sudo: unable to execute ./balenaEtcher-1.7.9-ia32.AppImage: No such file or directory
Thank you for your help!
Crane
