Hi all,
I’m facing some issue in Artik 520 module , When i power ON the board , the artik module is continously resetting. The LED for Reset is always ON. Actually i should be always OFF. kindly give ur suggestion
thank you
Hi all,
thank you
Have you run through the getting started guide?
It would be good to see if the issue is still present with the stock ARTIK image as that would point to a hardware issue.
