I’ve tried different versions of docker, but the issue persists.
The command I’m running is:
balena preload <image filename>.img --app <app id> --commit latest
The output is:
Building Docker preloader image. [========================] 100%
/ Starting preloader container
- Fetching application 1275303
1: Step 1/7 : FROM docker:17.10.0-ce-dind
---> 9769e0f3f9cb
Step 2/7 : RUN apk update && apk add --no-cache python3 parted btrfs-progs docker util-linux sfdisk file coreutils sgdisk
---> Using cache
---> e964730dc1cf
Step 3/7 : COPY ./requirements.txt /tmp/
---> Using cache
---> 8f4cafb6b91f
Step 4/7 : RUN pip3 install -r /tmp/requirements.txt
---> Using cache
---> f98489c14195
Step 5/7 : COPY ./src /usr/src/app
---> Using cache
---> eb27e34808c5
Step 6/7 : WORKDIR /usr/src/app
---> Using cache
---> 639c46386267
Step 7/7 : CMD ["python3", "/usr/src/app/preload.py"]
---> Using cache
---> 60ac9944b9b6
Successfully built 60ac9944b9b6
Successfully tagged balena/balena-preload:latest
Traceback (most recent call last):
File "/usr/src/app/preload.py", line 794, in <module>
PARTITIONS_CACHE[None] = prepare_global_partitions()
File "/usr/src/app/preload.py", line 76, in prepare_global_partitions
return get_partitions(IMAGE)
File "/usr/src/app/preload.py", line 65, in get_partitions
return {p.label: p for p in PartitionTable(image).partitions if p.label}
File "/usr/src/app/preload.py", line 380, in __init__
part = Partition(self, number, **partition_data)
File "/usr/src/app/preload.py", line 165, in __init__
self.label = self._get_label()
File "/usr/src/app/preload.py", line 169, in _get_label
out = file("-s", device).stdout.decode("utf8").strip()
File "/usr/lib/python3.6/site-packages/sh.py", line 1427, in __call__
return RunningCommand(cmd, call_args, stdin, stdout, stderr)
File "/usr/lib/python3.6/site-packages/sh.py", line 774, in __init__
self.wait()
File "/usr/lib/python3.6/site-packages/sh.py", line 792, in wait
self.handle_command_exit_code(exit_code)
File "/usr/lib/python3.6/site-packages/sh.py", line 815, in handle_command_exit_code
raise exc
sh.ErrorReturnCode_1:
RAN: /usr/bin/file -s /dev/loop0
STDOUT:
/dev/loop0: ERROR: cannot read `/dev/loop0' (I/O error)
STDERR:
If you need help, don't hesitate in contacting us at:
GitHub: https://github.com/balena-io/balena-cli/issues/new
Forums: https://forums.balena.io
- Fetching application <app id>%
Any idea what could be causing this issue?
MacOS 10.14.1
Balena 9.3.5
Docker 18.03.1-ce
docker-machine 0.14.0
