Hi All,
I am attempting to run a Samba DC on a Resin OS instance inside a container. When I attempt to provision a domain controller I get the error “ProvisioningError: Your filesystem or build does not support posix ACLs, which s3fs requires. Try the mounting the filesystem with the ‘acl’ option.”
The error itself is pretty self explanatory but I have no idea what the correct way to enable posix ACLs on Resin is? According to mount it is running ext4 which means it is certainly possible but reviewing /etc/fstab none of the mounted filesystems correspond.
