Edge IoT Mesh Project
New to balenaCloud but have been playing with a few rpis for a few days. First of all I am very impressed by the work the balena team has put together. I have tested other OTA platforms but none come close to the easiness getting started.
I am looking for some architectural advice specific to the project I am working on.
Basically the project requires 2 or more types of nodes. Let’s think of them as SuperNodes (aka Fog Control Node) and regular Nodes (aka Fog Cell).
Regular Nodes are tasked with acquiring data and performing actions, while SuperNodes provide core infrastructure on the same VLAN.
SuperNodes are primarily high RAM, high Storage (like an RPI 4 8GB with SSD)
Nodes are any kind of lower spec devices down to an RPI Zero
If I understand balena correctly that means 1 project with 2 or more fleets one per node type.
I’d like the first SuperNode on a VLAN to establish the basic infrastructure like MQTT and eg a local InfluxDB instance amongst other things. In the future I can see HA requirements to have at least 2 or more SuperNodes per install that may require some level of coordination.
Any regular Node that joins the VLAN should be looking for a SuperNode and join the local group/mesh. In most cases the nodes will be sending sensor data into the MQTT broker.
I’d like to detect the capabilities of a Node and auto configure as much as possible. Think various HATs that enable sensors and or other IO. Does that require multiple fleets per HAT type?
Already looking at balenaDash & Sense as building block patterns.
Are there any best practices to consider or things to avoid? How do Nodes best look for a SuperNode on the local network? Have to assume DHCP and changing IP addresses on reboot. For example Is there any MQTT based registry that works well in this environment? Other fog computing patterns to consider with balena?
Sorry for the multiple questions - trying to frame out the basics.
Hi Oliver,
Interesting use case and thread! :slight_smile:
I’ll try and work through some of your questions:
So, you’ll need two code bases (FogControl and FogCell, let’s say) which will each have a fleet on balenaCloud with the SuperNodes and Nodes running in them, respectively. You can make the fleets with the lowest common architecture, so for instance a RPi4 will run in a RPiZero fleet. As long as your code runs the appropriate executables for each architecture, this will be fine:
As an example, our sensor block has a multi-arch manifest added to the pre-built images, and therefore supports armv7 and aarch64 as you can see in the tags here:
https://hub.docker.com/layers/balenablocks/sensor/latest/images/sha256-2758edba618849453f53a24433c4fc93fd451b56e4a9ff546a3df72449704951?context=explore
If you were to use this in your docker-compose, you would add just reference the latest tag and the appropriate image will be pulled into your fleet:
This is an architectural decision for you to make, IMO. If there is enough commonality between different node types, then it may make sense to add support for all the different HW configurations, and then attempt to dynamically use the attached HW on a specific node. Again, you can see something akin to this in our sensor block linked above: it tries to detect what sensors are attached to the device, and load them dynamically.
If there is a wide difference between HW configurations, or it’s not possible to dynamically load the correct configuration, then this would probably necessitate a separate fleet for each codebase.
Hope this helps,
Phil
Phil,
Much appreciated. I have some tiny beginnings running on two fleets that share the same codebase for now. Using a dynamic framework I can load a lot of extensions dynamically at runtime.
Only when needing extra containers I might have to truly separate controller nodes from regular ones.
Is there a way to decide which containers to startup dynamically at the node level? eg if a controller starts up and cannot find an MQTT broker on the local VLAN it would decide to start and register its own instance - preferably as a dedicated container on its node.
Same for a controller node that detects lots of local fast storage: it could spin up an influxdb container and register it for the rest of the fleet.
Even looking at migrating different microservices after the fact to different nodes as they become available.
Oliver
Hi again Oliver!
Yes, but I think you’ll need to do it the other way around: start the MQTT container and stop it if it’s not needed. All of the containers in your docker-compose will be started when the device boots. There is no logic anywhere to decide if to start a container. But you can change the restart policy on a service so that it doesn’t restart if stopped. You can then make the code in the service decide whether to run, or exit. In your case I think the MQTT service would start, try to find another MQTT broker and exit if it does.
It’s not impossible to achieve this, in multiple ways. I’ve known people to dynamically pull and run docker containers from inside other containers. However, in my experience, this puts a lot of responsibility of pulling, running, restarting, managing onto the user code, when there is a balena engine and supervisor there to do it for you. I think my approach to this would be to wrap an InfluxDB installation in some code, which checks an environment variable to decide if it should run or not. I would then manipulate that variable from the service that’s deciding if it should run the DB or not.
Again, all things are possible. :slight_smile:
I’ve been using dapr.io lately, and I think it could be a good option for you to explore here. It simplifies microservice placement, service discovery and communication, and has component bindings for things like influxDB.
Phil
