Download Error of image on Raspberry pi B
I had created an image that takes suddenly too long to download to Raspberry Pi B.
That image I had successfully built it before and deployed in within normal time period.
I changed only some code in my application without editing Dockerfile.template.
At about 55% i get this error :
Failed to download application ‘registry2.resin.io/…’ due to ‘failed to register layer: Untar error on re-exec cmd: fork/exec /proc/self/exe: cannot allocate memory’
Downloading application ‘registry2.resin.io/…’
and the download begins again from the start…
I also pushed some new code to master.
I am using resinOS 2.
Thank you.
I solved the problem putting on the fleet configuration RESIN_SUPERVISOR_DELTA=1.
But I would like to learn why this is happening.
Hey @macvag, which exact resinOS version are you using? The deltas indeed cut down on the image size, there might have been a memory pressure for some images on the less-resourceful Raspberry Pi devices. Using kill-then-download update strategy might also have worked, I guess. :mag_right:
Have you encountered this issue since? If it happens again, we could look at the device and see what’s going on. In general, though, deltas are a better way forward in pretty much all respects (we have a lot of improvements going into deltas recently, both on the backend and on the devices).
