mtab:
/dev/root / ext4 rw,noatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=469544k,nr_inodes=117386,mode=755 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
proc /proc proc rw,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,mode=755 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
mqueue /dev/mqueue mqueue rw,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
sunrpc /run/rpc_pipefs rpc_pipefs rw,relatime 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=94828k,mode=700,uid=1000,gid=1000 0 0
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Compute Module 3 Plus Rev 1.0
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:1E:E4:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=2f6b54f6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (9184 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 630 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 822 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 26394 entries in 78 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000287] Console: colour dummy device 80x30
[ 0.000918] console [tty1] enabled
[ 0.000976] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001020] pid_max: default: 32768 minimum: 301
[ 0.001378] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001413] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002346] CPU: Testing write buffer coherency: ok
[ 0.002836] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003506] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003674] rcu: Hierarchical SRCU implementation.
[ 0.004489] smp: Bringing up secondary CPUs ...
[ 0.005356] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006291] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.007163] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.007284] smp: Brought up 1 node, 4 CPUs
[ 0.007366] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.007390] CPU: All CPU(s) started in HYP mode.
[ 0.007411] CPU: Virtualization extensions available.
[ 0.008403] devtmpfs: initialized
[ 0.021466] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.021738] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.021786] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.022391] pinctrl core: initialized pinctrl subsystem
[ 0.023270] NET: Registered protocol family 16
[ 0.026227] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.031916] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.031953] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032191] Serial: AMBA PL011 UART driver
[ 0.034739] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.069797] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071728] SCSI subsystem initialized
[ 0.071974] usbcore: registered new interface driver usbfs
[ 0.072050] usbcore: registered new interface driver hub
[ 0.072162] usbcore: registered new device driver usb
[ 0.090301] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
[ 0.100125] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
[ 0.111790] clocksource: Switched to clocksource arch_sys_counter
[ 0.200885] VFS: Disk quotas dquot_6.6.0
[ 0.200996] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.201206] FS-Cache: Loaded
[ 0.201433] CacheFiles: Loaded
[ 0.211474] NET: Registered protocol family 2
[ 0.212292] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.212357] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.212488] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.212693] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.212846] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.212912] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.213242] NET: Registered protocol family 1
[ 0.213834] RPC: Registered named UNIX socket transport module.
[ 0.213861] RPC: Registered udp transport module.
[ 0.213883] RPC: Registered tcp transport module.
[ 0.213904] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.215564] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.218610] Initialise system trusted keyrings
[ 0.218825] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.228818] FS-Cache: Netfs 'nfs' registered for caching
[ 0.229417] NFS: Registering the id_resolver key type
[ 0.229466] Key type id_resolver registered
[ 0.229489] Key type id_legacy registered
[ 0.229520] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.231860] Key type asymmetric registered
[ 0.231890] Asymmetric key parser 'x509' registered
[ 0.231961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.232147] io scheduler noop registered
[ 0.232171] io scheduler deadline registered (default)
[ 0.232367] io scheduler cfq registered
[ 0.232391] io scheduler mq-deadline registered (default)
[ 0.232415] io scheduler kyber registered
[ 0.235603] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.244515] Console: switching to colour frame buffer device 82x26
[ 0.251333] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 0.258164] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.260856] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.266170] vc-sm: Videocore shared memory driver
[ 0.268934] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.284815] brd: module loaded
[ 0.297491] loop: module loaded
[ 0.300552] Loading iSCSI transport class v2.0-870.
[ 0.303763] libphy: Fixed MDIO Bus: probed
[ 0.306276] usbcore: registered new interface driver lan78xx
[ 0.308734] usbcore: registered new interface driver smsc95xx
[ 0.311093] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.341410] dwc_otg 3f980000.usb: base=(ptrval)
[ 0.544063] Core Release: 2.80a
[ 0.546450] Setting default values for core params
[ 0.548900] Finished setting default values for core params
[ 0.751641] Using Buffer DMA mode
[ 0.754051] Periodic Transfer Interrupt Enhancement - disabled
[ 0.756478] Multiprocessor Interrupt Enhancement - disabled
[ 0.758849] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.761196] Dedicated Tx FIFOs mode
[ 0.763897] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
[ 0.768470] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.779372] dwc_otg: Microframe scheduler enabled
[ 0.779430] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.781656] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
[ 0.783866] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 0.786118] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.788373] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.790687] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 0.793006] Init: Port Power? op_state=1
[ 0.795242] Init: Power Port (0)
[ 0.797650] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.802176] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.804588] usb usb1: Product: DWC OTG Controller
[ 0.806952] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
[ 0.809369] usb usb1: SerialNumber: 3f980000.usb
[ 0.812335] hub 1-0:1.0: USB hub found
[ 0.814605] hub 1-0:1.0: 1 port detected
[ 0.817362] dwc_otg: FIQ enabled
[ 0.817368] dwc_otg: NAK holdoff enabled
[ 0.817373] dwc_otg: FIQ split-transaction FSM enabled
[ 0.817384] Module dwc_common_port init
[ 0.817658] usbcore: registered new interface driver usb-storage
[ 0.820105] mousedev: PS/2 mouse device common for all mice
[ 0.823444] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.826062] bcm2835-cpufreq: min=600000 max=1200000
[ 0.828891] sdhci: Secure Digital Host Controller Interface driver
[ 0.831300] sdhci: Copyright(c) Pierre Ossman
[ 0.834097] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.837003] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.839674] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.842721] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.845370] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.848099] usbcore: registered new interface driver usbhid
[ 0.850725] usbhid: USB HID core driver
[ 0.854076] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.858149] [vc_sm_connected_init]: start
[ 0.866842] [vc_sm_connected_init]: end - returning 0
[ 0.870386] Initializing XFRM netlink socket
[ 0.872847] NET: Registered protocol family 17
[ 0.875371] Key type dns_resolver registered
[ 0.878219] Registering SWP/SWPB emulation handler
[ 0.881290] registered taskstats version 1
[ 0.883723] Loading compiled-in X.509 certificates
[ 0.893299] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.895831] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.894256] console [ttyAMA0] enabled
[ 1.902398] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.910679] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.944953] sdhost: log_buf @ (ptrval) (fad07000)
[ 1.999202] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.008355] of_cfs_init
[ 2.013214] of_cfs_init: OK
[ 2.018780] Waiting for root device PARTUUID=2f6b54f6-02...
[ 2.027474] Indeed it is in host mode hprt0 = 00021501
[ 2.099134] random: fast init done
[ 2.110073] mmc1: new high speed SDIO card at address 0001
[ 2.170055] mmc0: new high speed MMC card at address 0001
[ 2.178939] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.186459] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 2.195469] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 2.203938] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (246:0)
[ 2.218123] mmcblk0: p1 p2
[ 2.241829] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.250711] Indeed it is in host mode hprt0 = 00001101
[ 2.268002] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.280689] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.298087] devtmpfs: mounted
[ 2.319918] Freeing unused kernel memory: 1024K
[ 2.342216] Run /sbin/init as init process
[ 2.492135] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 2.505310] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.515957] hub 1-1:1.0: USB hub found
[ 2.522790] hub 1-1:1.0: 5 ports detected
[ 2.814832] systemd[1]: System time before build time, advancing clock.
[ 2.841858] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.966865] NET: Registered protocol family 10
[ 2.975310] Segment Routing with IPv6
[ 2.992196] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.006281] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.019276] smsc95xx v1.0.6
[ 3.022154] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.037731] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.053544] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.080689] systemd[1]: Detected architecture arm.
[ 3.101770] systemd[1]: Set hostname to <raspberrypi>.
[ 3.115590] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:1e:e4:c5
[ 3.171405] uart-pl011 3f201000.serial: no DMA platform data
[ 3.185032] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 3.583270] systemd[1]: Listening on udev Kernel Socket.
[ 3.595501] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.609835] systemd[1]: Created slice User and Session Slice.
[ 3.622146] systemd[1]: Listening on udev Control Socket.
[ 3.633844] systemd[1]: Reached target Swap.
[ 3.644540] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.661317] systemd[1]: Listening on Syslog Socket.
[ 4.267883] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.350844] systemd-journald[106]: Received request to flush runtime journal from PID 1
[ 4.654159] i2c-gpio i2c@0: using lines 43 (SDA) and 42 (SCL)
[ 4.789155] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.792257] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.792277] [vc_sm_connected_init]: start
[ 4.808555] media: Linux media interface: v0.10
[ 4.809837] [vc_sm_connected_init]: installed successfully
[ 4.849993] videodev: Linux video capture interface: v2.00
[ 4.890451] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.898466] bcm2835_audio soc:audio: card created with 8 channels
[ 4.925747] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.973582] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.999312] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.014217] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.014235] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.026965] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.026981] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.038240] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.038257] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.092962] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.126063] Bluetooth: Core ver 2.22
[ 5.126137] NET: Registered protocol family 31
[ 5.126145] Bluetooth: HCI device and connection manager initialized
[ 5.126165] Bluetooth: HCI socket layer initialized
[ 5.126179] Bluetooth: L2CAP socket layer initialized
[ 5.126220] Bluetooth: SCO socket layer initialized
[ 5.157583] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.162017] bt8xxx: loading out-of-tree module taints kernel.
[ 5.168909] BT: Loading driver
[ 5.296327] BT Request firmware: mrvl/sd8887_uapsta_a2.bin
[ 5.309060] mlan: module license 'Marvell Proprietary' taints kernel.
[ 5.309071] Disabling lock debugging due to kernel taint
[ 5.450192] wlan: Loading MWLAN driver
[ 5.699142] random: crng init done
[ 5.699157] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.153784] BT: FW download over, size 616840 bytes
[ 6.720880] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.752987] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.753141] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.795233] BT FW is active(6)
[ 6.814748] BT: Driver loaded successfully
[ 6.820783] CMD_RESP: cmd 0x23a error, result=0x2
[ 6.824326] creating custom regulatory domain failed
[ 6.828784] get_channel when STA is not connected
[ 7.009683] get_channel when STA is not connected
[ 7.010784] get_channel when STA is not connected
[ 7.011964] get_channel when STA is not connected
[ 7.012512] get_channel when STA is not connected
[ 7.014960] get_channel when STA is not connected
[ 7.015831] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.017158] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.017169] Bluetooth: BNEP filters: protocol multicast
[ 7.017184] Bluetooth: BNEP socket layer initialized
[ 8.243973] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 8.246099] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
There are some issues with Bluetooth but no MMC errors
