Hi @daniel.rusev,
Did this issue ever cause problems again? Is there anything that you did in order to resolve the issue?
We are sporadically experiencing a similar problem and are thinking of changing to the balena-cli, however, as we run our deployments in CircleCI it is a change we keep putting off as will likely take longer than expected. If the change were likely to sort the problem it would be an easy decision to make.
Henry
Could you provide some more specific timescales on these errors? Also a dump of them to make sure they are the same and not something else?
Hi @richbayliss,
I am going to create a different post as in looking at the above issue they are actually different. The above gets no such image for an image held on dockerhub whereas the build failures I am experiencing are for images of a mid-layer.
@richbayliss and anyone else interested,
I have created another topic for Build fails with error - no such image in order to capture the issue we are facing, where intermediate images cannot be found by the builder.
Hi, we are currently investigating the issue and we’ll get back to you once it’s resolved. Thanks for reaching out!
