Hi guys, i need some help i have this issue when i try to push my aplication mongo to balena.
[Debug] Setting device state…
[Debug] Sending target state: {“local”:{“name”:“local”,“config”:{“SUPERVISOR_POLL_INTERVAL”:“60000”,“SUPERVISOR_INSTANT_UPDATE_TRIGGER”:“true”,“SUPERVISOR_LOCAL_MODE”:“true”,“SUPERVISOR_CONNECTIVITY_CHECK”:“true”,“SUPERVISOR_LOG_CONTROL”:“true”,“SUPERVISOR_DELTA”:“false”,“SUPERVISOR_DELTA_REQUEST_TIMEOUT”:“30000”,“SUPERVISOR_DELTA_APPLY_TIMEOUT”:“0”,“SUPERVISOR_DELTA_RETRY_COUNT”:“30”,“SUPERVISOR_DELTA_RETRY_INTERVAL”:“10000”,“SUPERVISOR_DELTA_VERSION”:“2”,“SUPERVISOR_OVERRIDE_LOCK”:“false”,“SUPERVISOR_PERSISTENT_LOGGING”:“false”,“HOST_FIREWALL_MODE”:"",“HOST_DISCOVERABILITY”:“true”,“SUPERVISOR_VPN_CONTROL”:“false”,“HOST_CONFIG_gpu_mem”:“16”,“HOST_CONFIG_enable_uart”:“1”,“HOST_CONFIG_dtoverlay”:"“vc4-fkms-v3d”",“HOST_CONFIG_arm_64bit”:“1”,“HOST_CONFIG_dtparam”:"“i2c_arm=on”,“spi=on”,“audio=on”",“HOST_CONFIG_disable_splash”:“1”},“apps”:{“1”:{“name”:“localapp”,“commit”:“localrelease”,“releaseId”:“1”,“services”:{“1”:{“environment”:{},“labels”:{},“container_name”:“mongodb”,“restart”:“always”,“privileged”:true,“networks”:{“default”:{“ipv4_address”:“172.28.0.45”}},“volumes”:[“mongo-db:/data/db”,“config-mongo:/etc/mongod.conf.orig”],“ports”:[“27017:27017”],“imageId”:1,“serviceName”:“mongodb”,“serviceId”:1,“image”:“local_image_mongodb:latest”,“running”:true}},“volumes”:{“mongo-db”:{},“config-mongo”:{}},“networks”:{“default”:{“ipam”:{“driver”:“default”,“config”:[{“subnet”:“172.29.0.0/24”}]}}}}}},“dependent”:{“apps”:,“devices”:}}
[Debug] Sending request to http://20.90.84.189:48484/v2/local/target-state
[Info] Streaming device logs…
[Debug] Sending request to http://20.90.84.189:48484/v2/local/device-info
[Live] Watching for file changes…
[Live] Waiting for device state to settle…
[Debug] Device state not settled, retrying in 1000ms
[Live] Cleaning up device…
[Debug] Cleaning up done.
[Warn] Connection to device lost
Retrying “Streaming logs” after 1.0s (1 of 1000) due to: DeviceConnectionLostError: Connection to device lost
ECONNRESET: socket hang up
Error: socket hang up
at createHangUpError (_http_client.js:332:15)
at Socket.socketOnEnd (_http_client.js:435:23)
at Socket.emit (events.js:203:15)
at Socket.EventEmitter.emit (domain.js:448:20)
at endReadableNT (_stream_readable.js:1145:12)
at process._tickCallback (internal/process/next_tick.js:63:19)
