Raspbian GNU/Linux 10 (buster) has the following permissions:
crw-rw---- 1 root video 243, 0 Oct 26 07:17 /dev/vchiq
Using the Raspberry Pi 4 production image, /dev/vchiq has the following permissions:
crw------- 1 root root 243, 0 Aug 6 07:25 /dev/vchiq
Can you please allow users in the video group access to this device in your image? I’m unable to get a non-root user to run omxplayer
The workaround that I have in place is:
Entering the HostOS Terminal and running:
chmod 777 /dev/vchiq
and then restarting the container / service in question. This is reset after every reboot of the host.
kaisoz
November 2, 2020, 11:33am
5
Hi!
Unfortunately, adding such change would require a operating system update to include it so is not a trivial task.
However, you can automate your workaround in a custom boot script as described here: Custom Boot Action/Script
Thanks for your message!
alexgg
November 2, 2020, 11:40am
7
Hi, a better way to achieve this would be to add a custom udev rule that will change the device node permissions on detection. See https://www.balena.io/docs/reference/OS/configuration/#udevrules on documentation about customer udev rules.
Thank you @alexgg & @kaisoz for taking a look!
I’ve gone off and implemented this approach and it works well:
# Edit/add the UDEVRULES variable to add your UDEV rules
# Please don't change the line just below this:
declare -A UDEVRULES
# * Step 1: `jq -sR . < rulefilename` and replace the outside the outside double quotes " with single quotes '
# * Add a new line as UDEVRULES[rulename]='<the contents of the previous step>'
# * To add multiple rules, create multiple lines with different rulenames
# * An example rule is just below.
# UDEVRULES[20-something]='ACTION==\"add\", SUBSYSTEM==\"net\", ATTRS{idVendor}==\"7392\", ATTRS{idProduct}==\"7811\", NAME=\"extAP\"\n'
UDEVRULES[20-vchiq]='SUBSYSTEM==\"vchiq\",GROUP=\"video\",MODE=\"0660\"'
# Whether or not restart the engine if the supervisor restart failed.
FORCE_SUPERVISOR_RESTART="no"
# End of script configuration
set -o errexit -o pipefail
Thank you!
