I’m having some trouble with accessing /dev/dri/card0 or /dev/dri/card1
When using the Raspberry Pi CM4 IO Board, the /dev/dri devices are missing.
Using DT Overlay "vc4-fkms-v3d" does not make a difference, and using SSH to the host OS shows that /dev/dri does not exist.
Attaching a display (not possible for the project in production) & even attempting to run the balenablocks/xserver example is also unsuccessful.
Is there a configuration option that I am missing? There does not seem to be any information on being able to enable & access DRI.
Thanks in advance
