I’m developing a node.js application for raspberry pi. In case I have no wifi access, what is the easiest was to get the debug logs of my script. I do have a HDMI display connected and I can login as root, but how do I end up in the docker image and display the logs of the running application? Thanks.
Found an answer to my own (beginner) question. maybe helpful for others.
For some reason, I made the false assumption that these were docker images. Therefore, it was weird that normal dockers commands didn’t work. Found out that balena is used.
