trying to run mmcli from an application but I’m getting stuck with the following error:
error: couldn't get bus: Could not connect: No such file or directory
I’m setting export DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket on the script calling mmcli
Tried 3 images so far, all with same result:
resin/raspberrypi3-alpine
resin/raspberrypi3-debian
resin/raspberrypi3-python:slim
Thank you!
