When I execute balena info on hostOS, I am seeing this result:
Can I customize the Docker Root Dir from a service?
Hi, can you tell us about your use case?
Hi, @karaxuna
I have been pulling out my hair out with an issue.
What I want to achieve is to get KubeEdge running as a balena service.
I have created a symlink on KE service to use the balena binary on hostOS:
ln -s /var/run/balena.sock /var/run/docker.sock
So KubeEdge is running, but the deploy application cannot be launched as it needs a permission to /var/lib/docker directory on hostOS:
/var/lib/docker to a container? Of course, I know it’s impossible. But any exceptional case?
Docker Root Dir(say /data/, which is shared?) we can get KubeEdge working?Cheers
This is duplicate of Bind mount custom directory , please see response there.
