Hello, I am interested in launching a container with the Balena (Docker) socket mounted inside. I know there is a label for this, yet when I try to start the container w/ this configuration, I get this error:
Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"rootfs_linux.go:58: mounting \\\"/var/run/balena-engine.sock\\\" to rootfs \\\"/var/lib/docker/aufs/mnt/756dcc99fbbf574084de617ece9a4347198b7232bf7d83371f4d3bc20a539078\\\" at \\\"/host/run/balena-engine.sock\\\" caused \\\"stat /var/run/balena-engine.sock: no such file or directory\\\"\"": unknown
The /var/run/balena-engine.sock file is on the host OS, so I’m not sure what this is complaining about exactly. Is this possibly a bug?
My fleet is using a docker-compose file, which looks like this:
version: "2.1"
services:
k3s:
build: ./k3s
container_name: k3s
tmpfs:
- /run
- /var/run
ulimits:
nproc: 65535
nofile:
soft: 65535
hard: 65535
privileged: true
network_mode: host
restart: always
volumes:
- rancher_etc:/etc/rancher
environment:
- K3S_URL=${K3S_URL}
- K3S_TOKEN=${K3S_TOKEN:?err}
labels:
io.balena.features.balena-socket: '1'
io.balena.features.kernel-modules: '1'
io.balena.features.firmware: '1'
io.balena.features.sysfs: '1'
Update: writing this made me reflect on the fact that my fleet is specifying /var/run as a tmpfs mount, which is probably the problem. Will verify that this goes away if I remove that.
