Dear Balena,
thank you for your time and energy to handle questions like mine. It’s very much appreciated. I love your product and we are building great things with it.
We are deploying drones globally running containerized ROS2 nodes. Each docker container running a single ROS2 node respectively.
Currently we have the desire to have drones and base stations communicate with each other in the most ROS-like fashion. This to avoid translation layers and custom interfaces. All this over 4G.
We stumbled upon a solution like this (SOLUTION 3 paragraph): Connecting Remote Robots Using ROS2, Docker & VPN | Husarnet
and especially excited about a deployment like this:
version: '2.3'
services:
color_controller:
build:
context: ../../
dockerfile: eg6/dev1/Dockerfile
volumes:
- ./cyclonedds.xml:/cyclonedds.xml
command:
- bash
- -c
export CYCLONEDDS_URI=file:///cyclonedds.xml
ros2 run my_demo_pkg color_controller
network_mode: service:husarnet
move_controller:
build:
context: ../../
volumes:
command:
- bash
- -c
ros2 run my_demo_pkg move_controller
husarnet:
image: husarnet/husarnet
restart: unless-stopped
volumes:
- /var/lib/husarnet # This will persist your Husarnet Client keys, thus IP of the container will be stable/the same between (re)boots
sysctls:
- net.ipv6.conf.all.disable_ipv6=0 # Husarnet is using IPv6 for the internal connections
cap_add:
- NET_ADMIN
devices:
- /dev/net/tun
env_file:
- ./.env # create .env file in the same folder as Dockerfile and specify HOSTNAME and JOINCODE there
However in your balena docker-compose definition, you specifically mention that the
is incompatible. I was wondering if that is (still) the case or if there is some other workaround available?
They do propose a solution where we compile their VPN/networking code in every container, but that feels less modular and portable. So that’s not the first choice.
Greetings and thank you for your time.
