controllino after update
hi, i have update the Supervisor version and Host OS version on 4 controllino. Result? not working, packet-forwarder ERROR: [main] failed to start the concentrator
{“diagnose_version”:“4.23.1”,“checks”:[{“name”:“check_balenaOS”,“success”:true,“status”:“Supported balenaOS 2.x detected”},{“name”:“check_container_engine”,“success”:true,“status”:“No container_engine issues detected”},{“name”:“check_localdisk”,“success”:true,“status”:“No localdisk issues detected”},{“name”:“check_memory”,“success”:true,“status”:“92% memory available”},{“name”:“check_networking”,“success”:true,“status”:“No networking issues detected”},{“name”:“check_os_rollback”,“success”:true,“status”:“No OS rollbacks detected”},{“name”:“check_supervisor”,“success”:true,“status”:“Supervisor is running & healthy”},{“name”:“check_temperature”,“success”:true,“status”:“No temperature issues detected”},{“name”:“check_timesync”,“success”:true,“status”:“Time is synchronized”},{“name”:“check_under_voltage”,“success”:true,“status”:“No under-voltage events detected”},{“name”:“check_service_packet-forwarder”,“success”:false,“status”:“User service ‘packet-forwarder’ is restarting unexpectedly, count: 45”},{“name”:“check_service_multiplexer”,“success”:true,“status”:“User service ‘multiplexer’ is running & healthy”},{“name”:“check_service_gateway-config”,“success”:false,“status”:“User service ‘gateway-config’ is restarting unexpectedly, count: 20”},{“name”:“check_service_helium-miner”,“success”:false,“status”:“User service ‘helium-miner’ is restarting unexpectedly, count: 1”},{“name”:“check_service_diagnostics”,“success”:true,“status”:“User service ‘diagnostics’ is running & healthy”},{“name”:“check_service_dbus-session”,“success”:true,“status”:“User service ‘dbus-session’ is running & healthy”}]}
I Need a update !!! New Host OS version!!!
Hello @Ondevento could you please share what device type are you using?
controllino
@Ondevento could you please share a screenshot of the balenaCloud dashboard with your device?
Thanks for sharing @Ondevento now i understand that you are using a Raspberry Pi 4 as the device type.
What OS and supervisor versions were you running before?
could you please confirm that there are no device variables needed to start the concentrator?
I don’t remember, maybe the 6.5.1+rev1
I expect this is an issue of the packet-forwarder application instead of balena @Ondevento
Is there anything in the helium forums to fix that?
I don’t know if it’s due to that. Helium firmware hasn’t changed, it’s just updated the OS and supervisor
could you please try to flash a new sd card with the previous balenaOS version?
I don’t want to get in the middle of your discussion, but…
I have recently ran into problems when updating to balenaOS 6.5.x , seems like the OS is not detecting/initializing correctly GPIO.
Check out the sys/class/gpio between version balenaOS 6.4.x and balenaOS 6.5.x
Best
LS
I don’t know what to do
I would like to avoid… if possible, the hardware is installed on an antenna pole
What differences are there that I could change manually between version 6.4 and 6.5?
I can’t log in to the card, but I can only operate via Balena Cloud
i have flashed the sd with supervisor16.12.0 and balena os 6.3.23 .Now working… at the same i have other 3 hardware with the same problem. with 6.4 not work… anyione have a solution? the hardware not is simple to flash..
