Sep 08 12:48:28 ad8a30c NetworkManager[1012]: [1599569308.3719] device (supervisor0): carrier: link connected
Sep 08 12:48:28 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 12:48:31 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 12:51:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 12:51:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 12:51:26 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.601 ms
Sep 08 12:56:26 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.436 ms
Sep 08 13:01:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 13:01:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 13:01:26 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.627 ms
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [info] Applying target state
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568447,“serviceName”:“exchange”,“releaseId”:1512078}}
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service kill {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service kill {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [error] Scheduling another update attempt in 900000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (dd262a38193ac269a8a9e20908f612d13373682b7383890c23c3ed88cc61ef28): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“kill”,“kill”]
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [error] at /usr/src/app/dist/app.js:2:2958395
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (dd262a38193ac269a8a9e20908f612d13373682b7383890c23c3ed88cc61ef28): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“kill”,“kill”]
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service install {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service installed {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:03:27 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:03:28 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:03:38 ad8a30c kernel: supervisor0: port 1(vethc785109) entered disabled state
Sep 08 13:03:38 ad8a30c NetworkManager[1012]: [1599570218.2975] device (vethc785109): released from master device supervisor0
Sep 08 13:03:38 ad8a30c resin-supervisor[26559]: [event] Event: Service exit {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:03:38 ad8a30c resin-supervisor[26559]: [event] Event: Service stop {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:03:39 ad8a30c resin-supervisor[26559]: [event] Event: Service exit {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:03:39 ad8a30c resin-supervisor[26559]: [event] Event: Service stop {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:06:27 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.614 ms
Sep 08 13:11:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 13:11:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 13:11:27 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.368 ms
Sep 08 13:16:27 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.828 ms
Sep 08 13:18:27 ad8a30c resin-supervisor[26559]: [info] Applying target state
Sep 08 13:18:27 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568447,“serviceName”:“exchange”,“releaseId”:1512078}}
Sep 08 13:18:27 ad8a30c resin-supervisor[26559]: [event] Event: Service kill {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [error] Scheduling another update attempt in 900000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (ea86de8c7f3368769d3456529b7eb69c4d7d7b876c9351f34bbd9e5a8aa00e8a): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“start”,“kill”]
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [error] at /usr/src/app/dist/app.js:2:2958395
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (ea86de8c7f3368769d3456529b7eb69c4d7d7b876c9351f34bbd9e5a8aa00e8a): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“start”,“kill”]
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service install {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service install {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service installed {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service installed {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c kernel: supervisor0: port 1(vethf1a0ece) entered blocking state
Sep 08 13:18:28 ad8a30c kernel: supervisor0: port 1(vethf1a0ece) entered disabled state
Sep 08 13:18:28 ad8a30c kernel: supervisor0: port 1(vethf1a0ece) entered forwarding state
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service exit {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service stop {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:18:28 ad8a30c NetworkManager[1012]: [1599571108.6933] device (supervisor0): carrier: link connected
Sep 08 13:18:28 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:18:31 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:21:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 13:21:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 13:21:27 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.804 ms
Sep 08 13:26:28 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 5.205 ms
Sep 08 13:31:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 13:31:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 13:31:28 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.661 ms
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [info] Applying target state
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568447,“serviceName”:“exchange”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service kill {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service kill {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [error] Scheduling another update attempt in 900000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (ab2c89f6a96f05e635d62106c81122f26a73c56922ac4ed53a70707eb19c54b9): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“kill”,“kill”]
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [error] at /usr/src/app/dist/app.js:2:2958395
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service install {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 500) server error - driver failed programming external connectivity on endpoint exchange_2659794_1512078 (ab2c89f6a96f05e635d62106c81122f26a73c56922ac4ed53a70707eb19c54b9): Bind for 0.0.0.0:445 failed: port is already allocated Steps:[“start”,“start”,“kill”,“kill”]
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service installed {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service start {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:33:28 ad8a30c resin-supervisor[26559]: [event] Event: Service started {“service”:{“appId”:1676803,“serviceId”:568449,“serviceName”:“proxy”,“releaseId”:1512078}}
Sep 08 13:33:38 ad8a30c kernel: supervisor0: port 1(vethf1a0ece) entered disabled state
Sep 08 13:33:38 ad8a30c NetworkManager[1012]: [1599572018.6118] device (vethf1a0ece): released from master device supervisor0
Sep 08 13:33:38 ad8a30c resin-supervisor[26559]: [event] Event: Service exit {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:33:38 ad8a30c resin-supervisor[26559]: [event] Event: Service stop {“service”:{“appId”:1676803,“serviceId”:568445,“serviceName”:“controller”,“releaseId”:1512078}}
Sep 08 13:33:39 ad8a30c resin-supervisor[26559]: [event] Event: Service exit {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:33:39 ad8a30c resin-supervisor[26559]: [event] Event: Service stop {“service”:{“appId”:1676803,“serviceId”:568446,“serviceName”:“wildfly”,“releaseId”:1512078}}
Sep 08 13:36:28 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.535 ms
Sep 08 13:41:11 ad8a30c resin-supervisor[26559]: [debug] Attempting container log timestamp flush…
Sep 08 13:41:11 ad8a30c resin-supervisor[26559]: [debug] Container log timestamp flush complete
Sep 08 13:41:28 ad8a30c resin-supervisor[26559]: [api] GET /v1/healthy 200 - 1.382 ms
