Container stuck continuously restarting
Hi
I’m using balenaOS 2.32.0+rev2 development build.
I’ve got a problem where my containers are stuck in a loop and are continuously restarting
[Logs] [2019-4-16 17:27:21] Installed service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:21] Starting service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:21] Started service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:22] Killing service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:23] Service exited ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:23] Killed service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:23] Installing service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:23] Installed service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:23] Starting service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:24] Started service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:25] Killing service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:25] Service exited ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
[Logs] [2019-4-16 17:27:25] Killed service ‘nginx sha256:295c7be079025306c4f1d65997fcf7adb411c88f139ad1d34b537164aa060369’
I’ve simplified my docker-compose.yml file down to this (I don’t think my issue is related to not using a balena base image, I’m using an x86 machine)
version: ‘2.1’
networks: {}
volumes:
resin-data: {}
services:
nginx:
image: nginx:1.14.2
ports:
- “80:80”
Looking at the journalctl output for resin-supervisor, shows these messages being logged every few seconds:
Apr 16 16:28:02 25171d6 resin-supervisor[1907]: Replacing container for service nginx because of config changes:
Apr 16 16:28:02 25171d6 resin-supervisor[1907]:   Array Fields:  expose
I don’t think that this is environment variable related, because if I remove the “ports” block from my docker-compose.yml file, then the container starts up OK and doesn’t get restarted.
If I do this then I’m not sure how to forward ports into the container?
Is this a known issue? Does anyone have any ideas?
This happened to us as well
Upgrading to 2.32
An nginx service in docker compose file kept restarting with the error quoted above
Nginx also reported an inability to create/open /var/run/nginx.pid, this was a red herring
I changed to use
expose:
  - '80'
instead of
ports:
  - 80:80
and the infinite restart stopped
can anyone comment on the cause? it is extremely confusing to troubleshoot from the symptom :stuck_out_tongue:
This issue was seen on BalenaOS 2.32.0+rev2.prod.
I have now “worked around” this issue by downgrading to BalenaOS 2.31.2.
Same story, all our containers with port mappings in the docker-compose config are restarting constantly on 2.32.0+rev2.prod
@peterl, @jotham, @thiver, thank you for reporting this issue. I believe this issue is an instance of:
Quoting the issue:
When an EXPOSE instruction is used in a Dockerfile , and an overlapping expose or ports instruction is also used in the docker-compose.yml file, the supervisor will restart the app container in a loop.
The temporary workaround is to remove the overlapping setting from either the Dockerfile or the docker-compose.yml file.
A supervisor code fix has already been merged and is in the process of integration with a new balenaOS release. The whole process (with OS testing for all the different device types) usually takes a couple of weeks.
Hi @pdcastro, thanks for your response.
All my restarting containers did indeed have an EXPOSE instruction in the Dockerfile itself, while having a ports instruction in the docker-compose.yml file.
