Considering Upgrading to PureOS From Linux
Presently running Linux Mint 20.x. I’m considering installing PureOS.
What happens to my existing data, on a seperate drive; What is the learning curve in the change over; Will the same software applications run on PureOS, that I’ve already been using. For example: Open Office; Brave; Htop?
Thank you for all your considerations,
silverfox.
PureOS is a debian-based distro, so it should support OpenOffice, Brave, etc. Some of those binaries might not run out of the box, so you would need to compile those from source.
