Connectivity issues
We have two Raspberry Pi 3b+ sitting in the same location, connected to the same switch by ethernet cable.
One of the two devices keeps loosing connection. Sometimes multiple times a day.
I can’t seem to find any hint to why. The program stops running, but it looks like the connection to the cloud is intact on some of the incidents.
If I look thrugh the log (journalctl -f -n 1000 -a), I stumbled accross this:
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.3271] manager: (supervisor0): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
Dec 22 11:00:18 88a4885 avahi-daemon[1745]: Joining mDNS multicast group on interface supervisor0.IPv4 with address 10.114.104.1.
Dec 22 11:00:18 88a4885 avahi-daemon[1745]: New relevant interface supervisor0.IPv4 for mDNS.
Dec 22 11:00:18 88a4885 avahi-daemon[1745]: Registering new address record for 10.114.104.1 on supervisor0.IPv4.
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <warn>  [1703242818.6492] device (supervisor0): failed to read bridge setting 'vlan_protocol'
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <warn>  [1703242818.6533] device (supervisor0): failed to read bridge setting 'vlan_stats_enabled'
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.6699] device (supervisor0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.6874] device (supervisor0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7061] device (supervisor0): Activation: starting connection 'supervisor0' (79b42fee-f9db-45af-b1b6-fefcfd88eff4)
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7216] manager: (balena0): new Bridge device (/org/freedesktop/NetworkManager/Devices/8)
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7417] device (supervisor0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7554] device (supervisor0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7633] device (supervisor0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Dec 22 11:00:18 88a4885 NetworkManager[1726]: <info>  [1703242818.7786] device (supervisor0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Dec 22 11:21:15 88a4885 timesync-https.sh[1762]: [timesync-https.sh][INFO] Time synchronised via HTTPS.
Dec 22 11:21:15 88a4885 NetworkManager[1726]: <info>  [1703244075.0314] device (supervisor0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Dec 22 11:21:15 88a4885 NetworkManager[1726]: <info>  [1703244075.0330] device (supervisor0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Dec 22 11:21:15 88a4885 NetworkManager[1726]: <info>  [1703244075.0399] device (supervisor0): Activation: successful, device activated.
Dec 22 11:21:15 88a4885 timesync-https.sh[1762]: [timesync-https.sh][INFO] Old time: Fri Dec 22 11:00:18 UTC 2023
Dec 22 11:21:15 88a4885 avahi-daemon[1745]: Joining mDNS multicast group on interface balena0.IPv4 with address 10.114.101.1.
Dec 22 11:21:15 88a4885 avahi-daemon[1745]: New relevant interface balena0.IPv4 for mDNS.
Dec 22 11:21:15 88a4885 avahi-daemon[1745]: Registering new address record for 10.114.101.1 on balena0.IPv4.
Dec 22 11:21:15 88a4885 NetworkManager[1726]: <info>  [1703244075.2508] manager: (br-ca338bde8816): new Bridge device (/org/freedesktop/NetworkManager/Devices/9)
Dec 22 11:21:15 88a4885 timesync-https.sh[1762]: [timesync-https.sh][INFO] New time: Fri Dec 22 11:21:15 UTC 2023
Dec 22 11:21:15 88a4885 timesync-https.sh[2099]: hwclock: can't open '/dev/misc/rtc': No such file or directory
Dec 22 11:21:15 88a4885 bluetoothd[1864]: Path / reserved for Adv Monitor app :1.15
Dec 22 11:21:15 88a4885 bthelper[2087]: [CHG] Controller B8:27:EB:9A:86:DC PowerState: on-disabling
Dec 22 11:21:15 88a4885 bthelper[2087]: Changing power off succeeded
Dec 22 11:21:15 88a4885 bluetoothd[1864]: Adv Monitor app :1.15 disconnected from D-Bus
As you can see it stops responding at around 11:00:18, and then gets rebooted at 11:21:15.
Any ideer to where I need to look?
The other device runs without any problem, with the same code…
Hi, is the switch configured to use VLANs? Could you try to plug the failing device to the same switch port that the working one is on?
Hi @alexgg
Sorry for the late reply, I’m back from holidays now.
I will follow up with the customer, to check the settings in the switch, and try to switch the cables.
