Hello friends,
I ran into an issue with my local setup. I’m trying to connect to openBalena that is running on AWS. I’ve followed instructions and did all steps necessary to run containers on a server.
When I try to login to my balena.iot with generated credentials I see the error bellow.
SELF_SIGNED_CERT_IN_CHAIN: request to https://api.balena.iot/login_ failed, reason: self signed certificate in certificate chain
FetchError: request to https://api.balena.iot/login_ failed, reason: self signed certificate in certificate chain
at ClientRequest. (/snapshot/versioned-source/node_modules/node-fetch/index.js:133:11)
at ClientRequest.emit (events.js:203:15)
at ClientRequest.EventEmitter.emit (domain.js:448:20)
at TLSSocket.socketErrorListener (_http_client.js:392:9)
at TLSSocket.emit (events.js:198:13)
at TLSSocket.EventEmitter.emit (domain.js:448:20)
at emitErrorNT (internal/streams/destroy.js:91:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
at process._tickCallback (internal/process/next_tick.js:63:19)
From previous event:
at new Fetch (/snapshot/versioned-source/node_modules/node-fetch/index.js:49:9)
at Fetch (/snapshot/versioned-source/node_modules/node-fetch/index.js:37:10)
at module.exports.fetch.Promise (/snapshot/versioned-source/node_modules/fetch-ponyfill/fetch-node.js:15:12)
at requestAsync (/snapshot/versioned-source/node_modules/balena-request/build/utils.js:327:7)
at requestAsync (/snapshot/versioned-source/node_modules/balena-request/build/utils.js:346:22)
at exports.getRequestAsync (/snapshot/versioned-source/node_modules/balena-request/build/utils.js:396:12)
at /snapshot/versioned-source/node_modules/balena-request/build/request.js:176:14
at Object.module.exports.exports.send (/snapshot/versioned-source/node_modules/balena-request/build/request.js:175:89)
at authenticate (/snapshot/versioned-source/node_modules/balena-sdk/build/auth.js:150:14)
at login (/snapshot/versioned-source/node_modules/balena-sdk/build/auth.js:188:16)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
at Object.authenticate (/snapshot/versioned-source/build/utils/patterns.js:27:10)
at doLogin (/snapshot/versioned-source/build/actions/auth.js:86:33)
at doLogin (/snapshot/versioned-source/build/actions/auth.js:102:20)For help, visit our support forums: https://forums.balena.io
For bug reports or feature requests, see: Issues · balena-io/balena-cli · GitHub
Have any of you seen this before. Please help ![]()
