Connecting Raspberry Pi to a DSI Display Without HDMI
Hi everyone,
I recently worked on integrating a Raspberry Pi with a native DSI display instead of using a traditional HDMI monitor. After some testing, I found that understanding the DSI interface and the software configuration process makes the setup much easier.
Some important considerations include:
  • Understanding the difference between HDMI and DSI interfaces
  • Selecting a display that supports the Raspberry Pi DSI connector
  • Enabling the required display overlays in the boot configuration
  • Checking kernel driver compatibility
  • Matching display resolution and timing parameters
  • Testing touch functionality if the panel includes a capacitive touchscreen
For industrial HMI devices and embedded projects, DSI displays can reduce cable complexity while providing a compact solution compared with HDMI displays.
I collected the complete setup process, hardware considerations, configuration examples, and common troubleshooting methods in a technical guide that may help other Raspberry Pi developers:
How to Connect Raspberry Pi to a DSI Display
Hope it helps anyone working on embedded display integration. If anyone has experience with custom DSI panels or industrial LCD modules, I’d also be interested in hearing your suggestions.
That’s interesting and well done. I have no need for what you have done but, I thought I’d relay what I’ve done with an old Pi400 and the screen off an old Asus tablet. I was wondering what to do with my old tablets because I can’t install any system worth speaking about (such a shame to waste perfectly good electronics). So, I came across a YouTube video of someone buying a drive board for the screen taken from the tablet from Aliexpress if I remember correctly. I found the correct part number for the screen once I disassembled the tablet and Aliexpress had a drive board along with connectors and interface board with an HDMI connector which takes the output from the Pi400 (or any Pi or virtually any HDMI output from anything I suppose). Once connected and powered up (you need an independent supply for the screen interface board) my old tablet screen is fully functional as a display for my Pi or whatever. Now what to do with it…?
